Overclock.net › Forums › Graphics Cards › Graphics Cards - General › 4890 to ???
4890 to ???
post #1 of 19
So, I am planning to upgrade my GPU soon, probably sometime next month. I don't plan on getting a new monitor anytime soon, so 1680x1050 is going to be my max resolution I will be gaming at. I am currently playing BC2, FFXIV and Civ V. I can max everything out on these, but I seem to get drops in FPS when there's alot going on. I would like to minimize that as much as possible. My budget is $300 at the moment, but that could change depending on my tax return amount. So I would just like to get others opinions on where I should go with this upgrade? I have been looking at several cards, but I just want to see what everyone thinks. Everything else in my sig rig will be staying the same until next July.
post #2 of 19
wellif you want to stay with ati get the 6970.
if you want to go nvidia get a gtx570
its that simple.
you want a REAL upgrade not some half assed jump in performance. get at least 2x performance jump.
ಠ-ಠ
(15 items)
i5 2500K ASUS P8P67 Deluxe EVGA GTX580 Mushkin DDR3 Silverline Stilletto(4x4)16GB 1333MHz
Hard DriveHard DriveOptical DriveOS
WD Caviar BLACK  Kingston V200 2x LG DVD RAM w/ lightscribe Win7 Pro 64-bit
BenQ XL2410T 23.6" 120Hz LED LCD Razer Lycosa ENERMAX REVOLUTION 850W CM HAF 922M
MouseMouse PadAudio
Razer Mamba ALLSOP high precision mousepad Creative Labs X-fi Titanium HD
ಠ-ಠ
(15 items)
MouseMouse PadAudio
post #3 of 19
6950.
Core i7 920 4.2GHZ @1.325 (HT on) Asus Rampage II Extreme X58 None. 6GB corsair i7 dominator CAS7 DDR3 Elpida Hypers
2X WD 500GB Caviar black Raid-0 + 1TB Caviar Green Samsung superwrite master Windows 7 X64 home premium SP1 Samsung Syncmaster 2243
Razor Lycosa + Das keyboard II Themaltake toughpower 1200watt Coolermaster HAF X Razor Deathadder 3500Dpi
Mouse Pad
none.
Mouse Pad
none.
post #4 of 19
6950
Blue Box
(15 items)
i5 2500k Asus P8P67 Sapphire 7950 Dual X  8gb gskill ripjaws x-1600
500 gb seagate Sony Corsair H60 Windows 7 Ultimate 64bit
22 inch V7 1680x1050 Steelseries Shift Keyboard Antec Neo eco 620w Cm 690 w/ 5 140mm fans
MouseMouse PadAudio
Logitech mx518 random Altec lansing
Blue Box
(15 items)
MouseMouse PadAudio
post #5 of 19
At that resolution, anything in the 460/6870+ range would be more than enough. I'd say a 570 or a 6950 if you really want to spend close to your budget. You probably won't need that much power now for that resolution, but good for a little future proofing.
post #6 of 19
Yeah im sure he will get a new monitor in the future and big monitors like the 2gb vram on the 6950
Blue Box
(15 items)
MouseMouse PadAudio
Blue Box
(15 items)
MouseMouse PadAudio
post #7 of 19
Thanks for the input keep it coming. I have been leaning towards the 6950, as it seems like a pretty good price/performance card. Originally I had been thinking the 6870, but for $50 more, I can just get the 6950. Still not 100% sure the extra cash is worth the small bump in performance. Thoughts on that?
post #8 of 19
Agreed.
For 1680x1050 a 4890 should STILL be quite sufficient, however if you're inclined to upgrade for the heck of it then you shouldn't need more than a 6850/70 (and that would still be overkill a bit).
If you do plan on upgrading your display or perhaps adding a second for eyefinity et. al then a 6950 would just be in your budget.
There's a Gigabyte model on Newegg for $299 shipped plus an additional $20 rebate.
Stugots III
(16 items)
i7 3770K @ 4.5GHz ASUS Maximus V Gene EVGA GTX 780 SC 2x8GB G.Skill 2133MHz
250GB 850-EVO | 1TB EZEX | 2TB F4 It BURNS! H100i | NB Pros Windows 10 Pro x64
ASUS VE258Q Filco Majestouch I Seasonic X-560w Fractal Arc Mini R2
MouseMouse PadAudioAudio
Logitech G502 Vengeance MM200 HT Omega eClaro SHURE SRH-840 | Audioengine A2+S8
Stugots III
(16 items)
post #9 of 19
gtx 580 tri sli...
how about a gtx 560 when they release?
First Build
Phenom II x2 555 @ 3.8GHz MSI 870 G45 Crossfire Sapphire 5770's 950/1300 Crucial 4x1GB DDR3 1333
Western Digital 320GB / Western Digital 250GB Lite-On multi burner Windows 7 Ultimate 64 bit Sceptre 22" widescreen
Razer Lycosa OCZ ModXStream 600w Modular Rosewill Challenger Razer Deathadder
Mouse Pad
Howies Game Shack Mouse Pad
First Build
Mouse Pad
post #10 of 19
6950 or Gtx 470/465/460 (CUDA Rocks bro)
Or
Gtx 570 (Open box + sale)?
Ninja EDIT: Yes IT IS Possible
Edited by tryagainplss - 12/24/10 at 10:14am
Intel Pentium E5400 G31TM-P31 (MS-7529) NVIDIA GeForce GTS 250 Kingston (generic 6-6-6-18 @ 400mhz)
Seagate 250GB (ST3250318AS) Liteon CD/DVD-RW x22 Cooler Master Hyper 212 Plus Ubuntu 10.10 x86 / Windows 7 Ultimate x86 Dual-...
Acer X193HQ Genius KB 110 Corsair HX450 Something Generic
MouseMouse Pad
Genius Netscroll 120 $4 Mousepad from CD-R King
MouseMouse Pad
  Back to Forum: Graphics Cards - General
