Overclock.net › Forums › Graphics Cards › NVIDIA › 448 bit memory interface??????????????????????
post #1 of 40
http://www.newegg.com/Product/Produc...82E16814133348
are those specs right? If it is this has to be the fasts card for the money, the specs are incredible. 256 bit cards are fast, but 448 is restarted, and at 110$ ***?????? Are these specs correct??
E6420 @ 2.8GHz 1405FSB GIGABYTE GA-P31-S3G Diamond HD 4870 512MB 2x 1GB Crucial Ballistix tracers DDR2-800
Hard DriveOSPowerCase
250GB SATA3 WD XP Ultra 600 Watt Moded Centurion 530
post #2 of 40
It's running GDDR3, they have to compensate for the comparitively low memory speed (as opposed to GDDR4/5) by making the memory bus higher.
WC Rig
e7500 4.2ghz @ 1.29v (2500k soon) Gigabyte EP45-DS3P Sapphire 5850 Xtreme 8GB Corsair XMS2 DDR2-800 @945
WD 500gb, Seagate 1tb SATA DVD-RW Windows 7 x64 Acer X222W
PowerCase
Corsair TX650 Coolermaster HAF 932
WC Rig
PowerCase
post #3 of 40
Those specs are correct and it's a hell of a card for a hundred bucks
Core I7 2600K - 4.8Ghz 1.324v Gigabyte P67 UD7 EVGA GTX 570's In SLI 4GB Corsair Dominators DDR3 2000
Hard DriveMonitorPowerCase
Corsair F60, WD Black 500GB Asus 27" MT276HE XFX 850W Black Edition Antec 1200
post #4 of 40
Is this even English?
My System
Core i7-930 D0 3.8Ghz ASUS P6T SE PowerColor HD5870 1GB 6GB Corsair Dominator XMS3 8-8-8-20 1200Mhz
Hard DriveOSMonitorPower
1TB Wester Digital Windows 7 Home 64bit Acer 23" XFX 850w Black Edtion
HAF 932
My System
HAF 932
post #5 of 40
Equivalent to a 4870 or so... Outperforms a 5770 though but won't touch a GTX 460, 5850 or 6870.
The Wtfer
Core i7 2600K ASUS P8Z68-V PRO EVGA GTX 465 w/ 470 Shaders/Memory/Clocks 8GB G.Skill DDR3 1866
Samsung F3 1TB LG 22X DVD±R DVD Burner Windows 7 Professional 64-Bit Dell U2311H + LG W2242S
PowerCase
Corsair 750TX Coolermaster RC-692 Advanced
The Wtfer
PowerCase
post #6 of 40
Please refrain from excessive symbol usage; it doesn't do anything for your question/argument.
As others have said, the higher memory bus is required for GDDR3. The GTX 260 was a badass card, and it really still is; $110 new is killer.
post #7 of 40
damn, memory interface is the only spec that really matters, and this ones got one of the highest. Memory speed doesnt mean anything without high ass bus
it doesnt matter. memory interface is the most important spec. if its low it will bottle neck and suck. This has to be one of the fasts cards of all time
Edited by IIowa - 12/26/10 at 7:21pm
post #8 of 40
-_- Bus speed isn't all that matters.
Black Sand
i7 2600k @ 4.8GHz ASUS Maximus IV Extreme-Z EVGA GTX 580 SLI 8GB Corsair Dominator GT @ 1885 MHz
60GB Mushkin Callisto Deluxe +1TB WD Caviar Black Windows 7 Home Premium ASUS VW246 Corsair HX-850
HAF 932
Black Sand
HAF 932
post #9 of 40
it really is, anything lower will bottle neck. Thats why only the highest card of a set is worth anything. they only give the highest card they make high ass bus. thats why lower cards are so terrible, 126 bus is like a type righter. you would be better off with a rock and chisel then a 126 bus card
post #10 of 40
...wow....
Why don't you just pick up a 2900XT then?
They had a 512 bit memory bus!
Waiting on X399
AMD Phenom II B57 @ X4 3.9 Gigabyte 790FXTA-UD5 Sapphire Radeon 290 8 GB G.Skill 2133
Hard DriveCoolingOSKeyboard
250 GB 840 EVO Noctua NH-D14 Windows 10 Logitech K350
PowerCaseMouseMouse Pad
Seasonic x750 Corsair 600T Logitech G100s Razer Goliathus Speed
Audio
Plantronics Gamecom 788
Waiting on X399
Audio
  Back to Forum: NVIDIA
