Overclock.net › Forums › Intel › Intel CPUs › 980-x OC
980-x OC
post #1 of 29
Okay so started to OC my 980x so far this is what I have, what do you think?
156x29 = ~4.5Ghz
Vcore = ~1.38
QPI = ~1.35
CPUPLL = ~1.87
Highest Core temp at about 52c after 1hour of Large ftts Prime95
So far stable through 1 hour of Small Ftts, 1 hour of Large Ftts
...next step for me is 36hrs of blend.
Edit: Batch 3035B799
HT is Disabled
Mixed Bag
i7 6950X 4600Mhz ASUS Rampage V Edition 10 1080 Ti FE HyperX 12-13-13 @2400Mhz
Hard DriveCoolingOSMonitor
Samsung 850 EVO Corsair H100i GTX Windows 10 x64 ASUS ROG PG279Q Black 27"
Corsair K95 RGB EVGA SuperNOVA 1000 P2 Corsair Air 540 Corsair RGB
Mouse Pad
Some naked Anime with a plump butt
Mixed Bag
Mouse Pad
post #2 of 29
I'm not going to comment on disabling ht- every time I see it I want to throw my monitor at someone.
Any particular reason you're not just using multiplier for your oc? Also that's a big increase in pll. What's that about? I'm not being sarcastic, I'm actually curious.
Edited by Eno75 - 12/30/10 at 4:01pm
DireWolf
980X Asus P6T Deluxe V2 GTX 460 6G Patriot
80GB Intel X-25; 1.5TB WD LG DVD Windows 7 Ultimate 64 24T Syncmaster
PowerCaseMouse
850W Corsair HAF X G500
DireWolf
PowerCaseMouse
post #3 of 29
I have always found best results with a 1.87 PLL intel recomends between 1.8-1.88
You do know that HT is old tech right? The i7 just reintroduced it from Intel and it is shown to effect 3d performance negativley.
I run mainly 3d apps and have no need to run 12 threads when I only have 6 cores. If I wanted 12 cores I would have bought 2 proccessors each with 6 cores.
Edited by tconroy135 - 12/30/10 at 4:22pm
Mixed Bag
Mouse Pad
Mixed Bag
Mouse Pad
post #4 of 29
gotta make sure the IMC is up to speed as well! that can add a LOT of performance if it is clocked high. anywhere from 3.6-4Ghz on the IMC should be just fine. (although it needs more QPI/VTT)
EDIT:
pl0x? I would really like to know if this is the truth or just hogwash.
The 775 Legend
E8600 @ 5.8 -- 1.736v Rampage Formula! GTX550ti Vmod! OCZ D9's @ 1200+ cas 5
OSMonitorPowerCase
XPEEEEEEEEEEEEEEEEEEEEEEE XGA 800x600 TR2-RX 850W Neoprene sheet
The 775 Legend
OSMonitorPowerCase
post #5 of 29
EDIT:
http://vr-zone.com/articles/does-cor....html?doc=6160
It'll help your benchmarks lol
Mixed Bag
Mouse Pad
Mixed Bag
Mouse Pad
post #6 of 29
2+ year old article running Vista.
Drunken Monkey
i7 980x @ 4500 Mhz HT on Evga Classified 760 5870 tri-fire Corsair 6 gig, 2100 Mhz Cas 7
Intel X25-m (4) raid 0 LG dvd win 7 64 bit HP 30"
saitek eclipse III PC power & cooling 1200 Mountain Mods Ascension CYO horizontal mobo Razer deathAdder
Mouse Pad
Razer
Drunken Monkey
Mouse Pad
Razer
post #7 of 29
Judging by the people I've been seeing it from I'm assuming AMD had something to do with it. Hey, if a guy wants to blast a thousand bucks on a processor he doesn't need with a technology he won't use that's his decision. Even the link he provides says nothing about affecting 3D applications- in fact quite the opposite. I digress.
Anyway, back to the point- this guy apparently knows everything so I'm pretty sure he doesn't need any help.
DireWolf
PowerCaseMouse
DireWolf
PowerCaseMouse
post #8 of 29
Why don't you stay away from my forums since you are seemingly a degenerate.
Oh wait here is another article about HT
http://www.xbitlabs.com/articles/cpu...0_7.html#sect0
18% performance loss in left 4 dead 2. (This game was probably made in 1980 though right?)
You are obviously a fool, I hope you cure cancer folding.
Mixed Bag
Mouse Pad
Mixed Bag
Mouse Pad
post #9 of 29
... Sorry but ... why the hell did you bought a 980X ... if in the end... you are disabled multi threading that means you really don't need computing power... u just need speed right?
eheheh
But... well, QPI voltage is tad high ... :x usally ... the higher the QPi voltage is, the "lower" the PLL needs to be.
i'm running mi 930 @ 4.2, 1.26v @ cpuz ( 1.28 bios ), my Qpi is 1.255 or 1.275 don't remember and my PLL is 1.7 ( lower than the default 1.8 )
post #10 of 29
eheheh
My ram recomends 1.35 QPI I could lower it so far four hours on custom blend no problems and temps under 60c. I might trying pulling the PLL down, but I don't want to cause instability.
I certainly did not disable multi-threading. I am running a 6 core processor with 6 threads. I am just not running a 6 core processor that is attempting to run 2 threads over 1 core.
Most people, especially with almost no rep, really have no technical understanding of what is going on inside their machine.
Edited by tconroy135 - 12/30/10 at 6:32pm
Mixed Bag
Mouse Pad
Mixed Bag
Mouse Pad
  Back to Forum: Intel CPUs
