Overclock.net › Forums › Intel › Intel CPUs › 2720qm vs. 2820qm
2720qm vs. 2820qm
post #1 of 5
Does anyone have benchmarks for these 2 processors? Is there a good reason the 2820qm is $200 more than the 2720qm? I am trying to decide between the two, and right now I am leaning toward the 2720qm.
post #2 of 5
Ok, by 2720 and 2820 you mean the mobile i7s correct? I think the only difference between these 2 is that the 2720 runs at 2.2 ghz and the 2820 2.3....but i could be wrong. All in all i would say get the 2720.
P.S : in the future please use i7 in the name if thats what you're referring to:cool:
ElevenShiftySix
i5 750 3.7Ghz @ 1.275V Gigabyte GA-P55-UD5 MSI GTX 670 2GB 2x2GB A-Data 1600 Cas 8
Hard DriveOSMonitorPower
640GB WD Caviar Blue Windows 7 Home Premium x64 HP w2338h 1920x1080 Corsair VX550
CaseMouse
NZXT Phantom White Steelseries Xai
ElevenShiftySix
CaseMouse
post #3 of 5
Yes, the mobile processors. Also the 2820 has an 8MB cashe, and the 2720 has a 6MB cashe. That and the difference in Hz are the only differences.
Edited by thecubemaster - 1/11/11 at 8:28pm
post #4 of 5
Actually, with Turbo, it's 3.0Ghz vs 3.1Ghz (full four cores).
So, 100Mhz (3%) and 2MB of cache extra for, I believe, twice the price.
Your choice.
White Phoenix
i7-2600k Gigabyte P67A-UD7-B3 GTX 480 SLi G.Skill 16GB (4x4GB) 1600/CL7
Crucial C300 256GB LG 6x BD-RW/HD-DVD Windows 7 SP1 Ultimate 64-bit Dell 'PLP' - 2007FP | 3007WFP-HC | 2007FP
Logitech G510 Silverstone 1000w [80A]-Rail Antec p190 (Modded) Logitech G700
Mouse Pad
Steelpad SteelSeries Experience I-2
White Phoenix
Mouse Pad
post #5 of 5
ok, this was exactly what i was wondering about as well. how high goes the 2920xm on all cores then? (without any oc)
CLEVO m860-TU
CPUGraphicsRAMHard Drive
t9600 M9800 GT 4GB 320GB
OSMonitorKeyboardMouse
Windows 7 Ultimate 64bit 1920 x 1200 X6 Sidewinder Microsoft Sidewinder
CLEVO m860-TU
  Back to Forum: Intel CPUs
