Overclock.net › Forums › Graphics Cards › AMD/ATI › 104c VRM temps 5850
104c VRM temps 5850
post #1 of 7
I run furmark stability test for 21min total.
is 104c VRM too much(?)
All three VDCC are at 100c+
I have a saphhire 5850 with Accelero S1 Rev.2 +120mm scythe.
~14mins VRM is at 100c, for some reason there is a 10s gap where gpu load is at 80% maybe bcs I clicked the gpu-z window(?).
after additional 7min total 21min the VRM is 104c.
the 3mins before end the temp is around 103c couple of 102 and 104c.
last minute is going to 104c, with other words furmark vrm did not stabilize.
Edited by grandpatzer - 1/16/11 at 3:11pm
Gaming Rig
(15 items)
I7 5820k Stock clocks Gigabyte X99 UD4 2x EVGA GTX 1080 FE SLI  Corsair 64GB (4x16GB) DDR4 2133MHz CL13 Vengean...
Hard DriveCoolingOSMonitor
Intel 530 M.2 SSD 180GB OS + Samsung 850 EVO st... Mugen 4 push pull Win 7 64bit home prem Acer 27" XG270HU 144hz TN + LG Oled 4k TV
PowerCaseMouseMouse Pad
EVGA T2 1600W Fractal XL R2 CM Xornet Steelseries Qck+ 45cm black
Audio
Sennheiser RS185 wireless headphones
Gaming Rig
(15 items)
Audio
post #2 of 7
you did the biggest mistake of your life by getting accelero for hd 5000. the vrm heats up like hell. and those tiny heatsinks from ac doesn't help.
i had one 5870, placed small ram heatsinks of vrms. temps hit 130C during 1min furmark run. then i bought vrm r4. they dropped to sub 50s.
either return to stock cooler or buy a thermalright vrm r3,r4 or r5. i don't know if thermalright VRM cooler is compatible with the accelero though.
Edited by Nautilus - 1/16/11 at 4:34pm
BACI DESTROYER
(15 items)
6700K @ 4.7 w/ EK Monoblock ASUS Maximus Gene VIII NVIDIA TITAN X Pascal w/EK Waterblock & Backplate 32GB Gskill DDR4 3200Mhz
Hard DriveHard DriveCoolingOS
Samsung 950 Pro NVMe 512GB 2x3TB 7200RPM HDDs EK Revo D5, Nemesis GTS 420 + 280 rads, 5x 14cm... Linux Mint 18.1 Cinnamon
ASUS SWIFT PG279Q 1440p 165Hz Razer Blackwidow Chroma Corsair RM1000x Fractal Design Define S
MouseMouse PadAudio
Razer DeathAdder Chroma Razer Sphex Schiit Stack DAC&AMP + JBL LSR305 Studio Monitors
BACI DESTROYER
(15 items)
MouseMouse PadAudio
post #3 of 7
First off, the Volterra PWM can handle temps of up to 125C and still be 100% stable. Secondly, no game is ever going to stress your card as much as Furmark. There is nothing to worry about
Beast
(14 items)
Dell XPS Faptop
(8 items)
Alura :)
(11 items)
i7 4790k Asus Z97 Pro WIFI-AC Sapphire Nitro Radeon R9 Fury Tri-X OC+  G.Skill 4 x 8GB F3-2133C9D-16GXH
2 x Intel 730 480GB SSD in RAID 0 Asus DRW-24B1ST/BLK/B/AS Noctua NH-D15 Winblows 10 Pro x64
Pixio PX277 Logitech G510 Seasonic SS-660XP2 Fractal Design R4 Blackout
MouseMouse Pad
Logitech G500 Xtrac Ripper
Core 2 Duo T5250 @ 1.5ghz Dell 0N6705 Mobile Intel 965 Express 2 x 2GB Hyundai/Kingston DDR2 533mhz
OCZ Summit 60GB SSD Slot Load DVD-RW Windows 7 Ultimate x64 13.3 inch 1280x800
i5 2500k Asus P8Z68-V Pro MSI R7970 Lightning BE 2 x 4GB G.Skill Ripjaws 2133mhz
Mushkin Enhanced Chronos 240GB and WD Black 1TB Asus DRW-24B1ST Cooler Master Hyper 212 EVO Windows 7 Ultimate x64
MonitorPowerCase
Hannspree 24 inch Thermaltake Tough Power TP-750P 750W Gold Cooler Master HAF 932
Beast
(14 items)
Dell XPS Faptop
(8 items)
Alura :)
(11 items)
MouseMouse Pad
MonitorPowerCase
post #4 of 7
ty for info, would adding another 5850 make any bad difference or is it still good to go
assuming both cards hold 105c from 21min of furmark.
Gaming Rig
(15 items)
Audio
Gaming Rig
(15 items)
Audio
post #5 of 7
umm i don't think so dopamin. i saw with my own eyes that playing 30 mins of empire total war (sea battle) caused my card stop working and show driver failure. later i found out from gpu-z logs that vrm temps was over 120C. that was when i had little ram sinks on vrm.
but of course my card was 5870 not 5850.
BACI DESTROYER
(15 items)
MouseMouse PadAudio
BACI DESTROYER
(15 items)
MouseMouse PadAudio
post #6 of 7
I think gaming will not go past 100c, I'm holding my thumbs up to not have higher VRM temps soon when I crossfire
Gaming Rig
(15 items)
Audio
Gaming Rig
(15 items)
Audio
post #7 of 7
fwiw, I have installed typhoon@660-880rpm bottom fan in case and moved the other typhoon 660-880 closer to the VRM.
now the peak VRM for the saphire is 69c and core 60c after 45min of DIRT 2.
Gaming Rig
(15 items)
Audio
Gaming Rig
(15 items)
Audio
  Back to Forum: AMD/ATI
