Overclock.net › Forums › Cooling › Water Cooling › 58O wb issue
58O wb issue
post #1 of 5
First i have had the block installed and it worked. Second it works with the stock cooler. Third my other 580 works fine.
Now when install the block i get device manager error 43. Are the screws too tight/loose or what? i am stumped. Even tried 2 mobos.
Mixed Bag
i7 6950X 4600Mhz ASUS Rampage V Edition 10 1080 Ti FE HyperX 12-13-13 @2400Mhz
Hard DriveCoolingOSMonitor
Samsung 850 EVO Corsair H100i GTX Windows 10 x64 ASUS ROG PG279Q Black 27"
Corsair K95 RGB EVGA SuperNOVA 1000 P2 Corsair Air 540 Corsair RGB
Mouse Pad
Some naked Anime with a plump butt
Mixed Bag
Mouse Pad
post #2 of 5
Screws should be just where they are start to tighten a little you sure nothing is making contact where it shouldn't and have all the pads in place.
Sounds to me if the stock cooler is fine then something is making contact where it shouldnt or it's getting to hot somewhere.
a member I bought one of my 480's from with a EK block missed putting some of the pads on the little chips, easy mistake but I'm glad I checked his work, LOL
Mostly For Gaming
(15 items)
i7-4820K EK cooled ASUS x79 680, EK cooled G.skill 16GB
512GB 840 Pro  ASUS DVD Burner 3 Loops which consist of 7 Waterblocks, 4 Radia... 8.1pro 64bit
ZR30w S-IPS 2560x1600 Ɠ19 SILVERSTONE ST 1500W Custom
MouseMouse PadAudio
Ɠ500 Ɍocketfish SENNHEISER
Mostly For Gaming
(15 items)
MouseMouse PadAudio
post #3 of 5
The weird thing is I can boot through this card with the WB installed and it works fine with the Standard Adapter, but as soon as I install the Drivers I get error 43.
Even if this is the only card installed.
Mixed Bag
Mouse Pad
Mixed Bag
Mouse Pad
post #4 of 5
Update, okay the problem was the physical waterblock. IDK if it was weight size or what, but with that card the block would not work.
You may have guessed, but I took the WB off the 580 and tried it on the one that worked and what do you know it works.
Now I know I have had both cards working at the same time before, so now I am going to try and install the WB I removed on the other card and see if both work.
Okay, that's my 4AM update.
Mixed Bag
Mouse Pad
Mixed Bag
Mouse Pad
post #5 of 5
Alls well that ends well. Apparently my EK blocks aren't switchable between cards .
Mixed Bag
Mouse Pad
Mixed Bag
Mouse Pad
  Back to Forum: Water Cooling
