Overclock.net › Forums › Cooling › Water Cooling › 240 Rad
240 Rad
post #1 of 6
I have a Corsair 800D and am installing a 320 radiator with three fans on the top. I have the PSU and was thinking to put the pump as well at the bottom but wanted to know if I would be able to fit a 240 radiator at the bottom with the PSU and pump there or at least just the PSU.
Yogi
i7-970 Asus Rampage III Extreme Evga GTX 570 Super Talents 2000MHZ Cas 7
C300 128GB - 2x WD 2TB Green & Samsung 500GB Lite-On Blu-ray Burner Windows 7 Ulitmate x64 LG 47LX6500
Das Keyboard Model S SeaSonic 750W 80+ Gold Corsair Obsidian 800D logitech Performance Mouse MX
Mouse Pad
Razer Dual
Yogi
Mouse Pad
Razer Dual
post #2 of 6
I believe you can fit the 240mm rad at the bottom with the PSU depending on the PSU size, but not with the pump also, you can mount the pump on the false floor.
post #3 of 6
Where would the false floor be, right on top of the PSU and radiator? BTW I'm gonna have that 250m res from frozencpu you.
Yogi
Mouse Pad
Razer Dual
Yogi
Mouse Pad
Razer Dual
post #4 of 6
You can get rid of the HDD cage at the bottom and put a 240 there but you'd have to mod it.
What about hanging it off the back?
New
(11 items)
2500k @5ghz Asus P8P67 Evo 6970 @ 1000/1450 8GB Ripjaws DDR31600 Cas8
Hard DriveCoolingOSMonitor
Samsung 850 Pro 128GB + WD 1TB XSPC Rasa,RX360,D5 w/EK top,Ek150 res,AP-15's 7 Pro Asus VW266H
KeyboardPowerCase
G11 AX850 Corsair 800D
New
(11 items)
KeyboardPowerCase
post #5 of 6
You just have to cut a hole in the bottom for the 240 radiator, and then drill a hole on the side panel for some extra intake air.
EDIT: Yes, that is the false floor. The metal plate that separates the motherboard area from the PSU area. However you can fit the pump and reservoir into that spot easily. I would get a top for the pump ( if you don't have one already) and then use a male to male fitting to directly connect them.
Labor of Love
(14 items)
2600k @ 5.0 GHz/1.42v ASUS P8P67 Pro MSI GTX 670 OC 20 GB/1600/7-7-7-24
Hard DriveHard DriveOptical DriveOS
120GB Vertex SSD Western Digital 1TB None! Ubuntu 12.04/Win8/OSX 10.8.2
27" 1440p X-Star OCN Mechanical - MX Browns Seasonic X-560 800D w/RX480 top mounted
Mouse
Logitech USB Generic
Labor of Love
(14 items)
Mouse
post #6 of 6
You know that floor that seperates the area where the PSU is and the rest of the case, that would be considered the false floor.
  Back to Forum: Water Cooling
