Overclock.net › Forums › AMD › AMD CPUs › 9750 question
9750 question
post #1 of 7
hey guys i currently have the rig in my sig and i recently purchased BFBC2 and its the first real game that puts my computer to the test, idk if i updated it but i have a GTX 470 now and i set all my graphics to high and was playing online after a game i was using the tanks and my cpu temp was at 67C max on coretemp, is that bad for intense gaming? i usally idel at 36-38
btw: have my fan controler set all my fans to max during gaming and my case has excellent cable managment.
Edited by Lq Cloud - 1/25/11 at 9:06pm
First rig
AMD Phenom ii 965 @ 4.4ghz 1.45v Biostar TA890FXE EVGA GTX 470 4GB GSkill Ripjaw X series
Hard DriveMonitorPowerCase
500GB WD 7200rpm Sata ACER 24" G245H 620w SeaSonic Modular PSU CM Scout Sniper
First rig
post #2 of 7
Yes 67 while gaming i would say is pretty warm. I would imagine you could hit 80 on something like p95
post #3 of 7
that's too hot mine was barely hitting 40C overclocked with my cheap cooler, i would reseat the cooler with some fresh thermal paste.
Tha Beast!
(15 items)
Intel Core i7 4770K 4.4Ghz 1.25V ASUS Z87 Sabertooth EVGA GTX 1080 FTW2 iCX 2126/11GHz 16GB DDR3 2400Mhz
Hard DriveHard DriveCoolingOS
Kingston 480GB SSD HGST 2TB Corsair H100i Windows 10 Home 64-bit
AOC I2269VW-B 22" Razer BlackWidow Ultimate 2014 Corsair HX650 Corsair Vengance C70 Gunmetal
MouseMouse PadAudio
Razer Deathadder 2013 Razer goliathus Sound Blaster X-FI Xtreme Audio PCIe
Tha Beast!
(15 items)
MouseMouse PadAudio
post #4 of 7
i have done that twice now,
is this a good cpu cooler
http://www.newegg.ca/Product/Product...82E16835103065
can you buy an extra fan
First rig
First rig
post #5 of 7
Yes, that's a very good budget cooler. But you really should consider a CPU upgrade too. That first generation Phenom chip is holding you back pretty decently.
Junkyard
(18 items)
NAStradamous
(12 items)
HTPC01
(16 items)
Intel i5 2320 @ 3.1GHz MSI B75MA-E33 HIS HD7970 3GB @ 1050 / 1700, 1.17v Patriot 2x4GB DDR3-1066
Crucial MX100 256GB WD Green 2TB DVDRW Corsair H50 Push / Pull
CoolingOSMonitorMonitor
NZXT 120mm fans strapped to stock 7970 cooler Windows 10 Pro Dell 3007WFP Dell 2007FP
Dell 2007FP Cheap Toshiba (R.I.P. Ducky) PC Power & Cooling Silencer MKIII 950w Cheap Garbage (free)
MouseAudio
Logitech G602 Yardsale Special
Intel Core i5 3330 Asus H61 MSI GTX 750Ti Low Profile 2x4GB Hynix DDR3-1333
60GB Kingston SSD 1TB Seagate Samsung DVDRW CoolerMaster Gemin II
OSMonitorKeyboardPower
Windows 8.1 + Steam Big Picture / Plex HT 50" Insignia LED 1080p Logitech Rosewill Green 530w
CaseMouseAudioOther
Silverstone HTPC Logitech Pioneer 2.0 tower speakers + 135w RMS Rosewill MCE Remote
Junkyard
(18 items)
NAStradamous
(12 items)
HTPC01
(16 items)
MouseAudio
CaseMouseAudioOther
post #6 of 7
that cooler is pretty much a clone of mine, but with a little better performance i say go for it, but i don't think you can do push/pull like mine but a couple zip ties and some elbow grease goes along way.
Tha Beast!
(15 items)
MouseMouse PadAudio
Tha Beast!
(15 items)
MouseMouse PadAudio
post #7 of 7
It'll do push / pull just fine. Mine doesn't at stock either, but like you said, zip ties go a long way .
But I'd still say get just the cooler, and save for a better CPU instead of 2 fans.
Junkyard
(18 items)
NAStradamous
(12 items)
HTPC01
(16 items)
MouseAudio
CaseMouseAudioOther
Junkyard
(18 items)
NAStradamous
(12 items)
HTPC01
(16 items)
MouseAudio
CaseMouseAudioOther
  Back to Forum: AMD CPUs
