Overclock.net › Forums › Cooling › Water Cooling › 922 and watercooling setup.
post #1 of 7
This is a simple wc-setup i build for my friend some time ago.
He bought a Haf 922, Gigabyte udr3, i7-950, Gtx 570 and Ek 240mm wc kit.
Block for gtx is coming soon.
There only 18mm space between the rad and ram, so i had to put the yate loons at the top of the case pushing air inside through the rad. Temps are fine thought, even that it's oc'd to 4.2Ghz with 1.31v
I was wondering after installing the gtx to the loop, i should add a 120mm rad after the cpu? So far i've seen several ppl say that 240mm rad should be enough for cpu+gpu loop..
But he was planning to get another 570 later on and wc it too.. so, would a 240+120mm rad be enough or should there be another 240mm rad?
For the 240mm at the roof, would there be any use to install ultra slim fans for a push/pull setup? I haven't been able to find any other than scythe ultra slim 120mm fans and they are pretty low on cfm.. they're 12mm thick.
Edited by donrapello - 1/28/11 at 12:49am
570X
(22 items)
i7-7800x Asus Strix X299-E Evga GTX 1080 TI G.Skill Trident Z RGB
Samsung Evo 960 Samsung 840 Crucial MX100 WD Blue
CoolingCoolingCoolingCooling
Koolance 380i EK XTX 360 EK X-RES + D5 EK-FC Titan X
OSMonitorKeyboardPower
Windows 10 Acer XB271HU Ducky Shine 3 EVGA Supernova G3 650
CaseMouseMouse PadAudio
Corsair 570x Ducky Secret M RGB Zowie G-TF Creative ZXR
AudioAudio
Sennheiser HD650 Antlion Modmic 4
570X
(22 items)
AudioAudio
post #2 of 7
A 240 + a 120 should be able to handle the load, but I am not really sure as to the deltas. You may loose a bit of performance from the loop with that. I ran a 965 BE and a 5850 using the same config for a while and the loop was not saturated. But in this case the components put out more heat.
E IV
(16 items)
Intel i5 3570K ASRock Z77 OC Formula Nvidia Zotac GTX 770 Gskill Trident 2400 Mhz
Hard DriveHard DriveHard DriveOS
Samsung 840  OCZ Vertex 2 Seagate 7200 Windows 8
22" Benq Logitech Antec HCP 850W Caselabs SM8
MouseMouse PadAudioAudio
Logitech G400 Razer Asus Xonar DGX Microlabs C Series
E IV
(16 items)
post #3 of 7
adding 120 will definetly help especially if you are overclocking.
also about slim fans, well you if can find them, change the top ones to slim ones too.
and use the current 2 for 120.
Intel i3 540 P7H55M-Pro XFX 6770 OCZ Platinum
OCZ Vertex 2E  Samsung F4 Maxtor DiamondMax 23 LG Super-multi Drive
CoolingOSMonitorKeyboard
Coolermaster Hyper212+ Microsoft Windows 7 Professional 64-bit LG W2361V Razer Tarantula
PowerCaseMouseMouse Pad
Corsair CX430v2 Coolermaster Elite 335 Logitech MX518 Roccat Taito
AudioAudioAudio
Asus Xonar DG Logitech Z523 2.1 Speakers Sennheiser PC350 Headset
AudioAudioAudio
post #4 of 7
Those Yate Loons at the roof have 77cfm airflow.. and those slims have only 19-20cfm.
So i wonder if they are powerful enough to push air as the roof grill is also between the fans and rad, if i change the top fans to slims too?
How about the future addon for another 570? 240+120 or 240+240?
240+120 could be used as internal, but for another 240mm rad, it should be installed external because the lack of space
I guess buying another 240 rad would be more future wise..?
Pump is ek-dcp 4.0, would it be enough for a loop with 2x240, Cpu & 2xGpu blocks?
It's beginning to sound a bit too much for me..
I never should have told him to go under water, but it still is fun
570X
(22 items)
AudioAudio
570X
(22 items)
AudioAudio
post #5 of 7
this res is 150 advanced ek?
cool looking lc
post #6 of 7
@ prznar1
Yeah, it's EK-Multioption RES X2 - 150 Advanced
570X
(22 items)
AudioAudio
570X
(22 items)
AudioAudio
post #7 of 7
240 can handle CPU+GPU but with high speed fan push pull. If he wants a quite system then get another 120.
Ishimura
(21 items)
Silent Knight
Intel Core i7 3770K @ 4.6GHz ASRock Z77E-ITX eVGA GTX 1080 Ti Hybrid AVEXIR Blitz 1.1 16GB DDR3-2400MHz
Hard DriveHard DriveCoolingCooling
SanDisk Ultra II 960GB Toshiba X300 5TB Corsair H100i GTX eVGA Hybrid Water Cooler
4x GentleTyphoon AP-15 Windows 10 Pro 64-Bit Philips Brilliance BDM4065UC 4K Razer BlackWidow Chroma
eVGA SuperNOVA 750 G3 Define Nano S Logitech G502 Proteus Core PECHAM Gaming Mouse Pad XX-Large
AudioAudioAudioAudio
Audioengine D1 DAC Mackie CR Series CR3 Audio-Technica ATH-M50 Sennheiser HD 598
Audio
Sony XB950BT
AMD Phenom II X4 955 @ 4.2GHz ASUS M4A79XTD EVO AMD Radeon HD 7970 3GB @ 1200/1500 2x 4GB G.SKILL Ripjaws X DDR3-1600
Hard DriveHard DriveHard DriveCooling
OCZ Agility 3 60GB WD Caviar Green 1.5TB 2 x Seagate Barracuda 2TB XSPC Raystorm
CoolingCoolingOSPower
EK-FC7970 XSPC RS360 Windows 10 Pro 64-Bit Corsair TX750
NZXT Switch 810
Ishimura
(21 items)
Silent Knight
Audio
Sony XB950BT
NZXT Switch 810
  Back to Forum: Water Cooling
