Overclock.net › Forums › Cooling › Water Cooling › 85 deg!!!
85 deg!!!
post #1 of 20
I am cooking! I have slowly o/c my i7-950 to 3.8 ghz, then run the intel burn test, prime does not get that far, my cpu alarm heat warning alarms comes on. This happens at any time during the day, I have reset my H70 with Arctic silver 5, MY idle temp with Real Temp is 60 deg c. Other members has reported the load is about what my idle is, where do I start again. Please unfry me!!
http://valid.canardpc.com/show_oc.php?id=1631620
HaF eXpectant
(17 items)
i7 950 x58a-ud5  Gigabyte HD6950 o/c to HD6970 4g Ddr3 Kingston Hyper X 2000mhz
120gig OCZ V2 os drive 2 x Samsung  samsung 2 t/b Samsung SH-B083LBlu-Ray Combo
CoolingOSMonitorKeyboard
Noctura D14 Win 7 64bit Pro Asus VE278 27" Gigabyte Cheapie
PowerCaseMouseMouse Pad
Antec New true blue 750w Coolermaster Haf X Tron Razer Tron Razer
Audio
On Board
HaF eXpectant
(17 items)
Audio
On Board
post #2 of 20
try reseating your H70.
Black Edition
(17 items)
AMD Athlon X4 870K @ 4.50 ASUS A68HM-Plus FM2+ EVGA GeForce GTX 760 Crucial Ballistix Sports (8GB.) (DDR3-1600)
SanDisk SSD Plus 240GB. Toshiba (500GB.) Hitachi Deskstar (500GB.) WD Ultra Passport
Optical DriveCoolingOSMonitor
Samsung DVD Burner 24X SH-224DB/BEBE Cooler Master Hyper T4 Windows 10 Pro x64 Samsung S23A350H 23" 1080p
Logitech G105 Gaming Keyboard CORSAIR CX series CX600M 600W Thermaltake V3 Black Edition Logitech G300s Gaming Mouse
Audio
ASUS DG 5.1 DD
Black Edition
(17 items)
Audio
ASUS DG 5.1 DD
post #3 of 20
Make sure you got the seat right. The mounting system kinda sucks.
post #4 of 20
60 degree idle makes it sound like the pump isn't even running.That's ridiculous.I built an i3 rig last week and it idled at 25 with the stock intel cooler.
My System
(14 items)
I5-750 4.3@1.375v Asus Maximus III Formula Asus ENGTX465 4gb G Skill 2000 Mhz.Trident @2133 9-9-9-27
OCZ VERTEX 2 50GB SSD/WD 500GB Blue/WD640GB Black Samsung DVD/RW Corsair H-50 Windows 10 home 64 Bit Retail
ASUS 24"1080P LED Asus VE248H Abs M1 Cooler master silent pro 600 modular M600 RS-60... Lian Li Lancool PCK-58
MouseMouse Pad
Steelseries Kinzu no
My System
(14 items)
MouseMouse Pad
post #5 of 20
Make sure the pump is connected to a fan header without any speed throttling. The pump needs to run at 100% at all times.
post #6 of 20
85deg on an h70 at 1.2V just doesnt sound right. I'm pumping 1.4v into my 1055t and I'm loading at 50ish (yes I know the architecture is completely different). Re seat your H70. make sure both the copper base and the cpu are completely clean before applying more paste. Tighten the screws to the max!!! Also make sure the tubes arent bending too much. Also check your motherboard isnt running the pump at under 1400rpm. This can happen if you have smart fan features enabled in your BIOS.
Intel Core i5 3570k EK Supreme Nickel Asus P8Z77-I Deluxe MSI GTX 680 EK FC680+ Nickel Mushkin Redline 8GB CL7 1600MHz
Hard DriveOSMonitorKeyboard
Intel 520 120GB Windows 8 Pro Media Centre Dell U2412M Steelseries 6GV2
Seasonic SS-520FL Bitfenix Prodigy (White) Steelseries Sensei Various Steelseries + Nokia
Audio
Shure SRH440
Audio
Shure SRH440
post #7 of 20
Thanks in the meantime I have reset the CMOS, run Prime for 6 minutes only as the temps were +-85 c, it is warm here in Brisbane, Australia, at 25 c at 12:26 pm, maybe time to sleep then reseat the H70, is the Arctic Silver OK to use with the H70?
HaF eXpectant
(17 items)
Audio
On Board
HaF eXpectant
(17 items)
Audio
On Board
post #8 of 20
make sure the fans on the radiator are mount the right way.
not >| |<
but
<| |< or >| |>
if that makes sense.
plug pump into the PWR_FAN for 12v.
Verde [WIP]
i7 2600k @ 4.5gHz w/ HT ASUS P8P67 Pro Gigabyte 460GTX OC 8gB Kingston HyperX
Samsung F3 1tB [RAID1] + WD Green 2tB [RAID5] Windows 7 [x64] Acer 24" [1920x1200] MX 5500
PowerCaseMouse
Corsair HX850W CM 690 II Adv [Modded] Logitech MX Revolution
Verde [WIP]
PowerCaseMouse
post #9 of 20
AS5 is just fine.
Black Edition
(17 items)
Audio
ASUS DG 5.1 DD
Black Edition
(17 items)
Audio
ASUS DG 5.1 DD
post #10 of 20
Yes, arctic silver is fine to use with the H70.
You really shouldn't be going above 70C load with the overclock you have right now. Is there any way you could plug the pump header into the power supply directly?
Labor of Love
(14 items)
2600k @ 5.0 GHz/1.42v ASUS P8P67 Pro MSI GTX 670 OC 20 GB/1600/7-7-7-24
Hard DriveHard DriveOptical DriveOS
120GB Vertex SSD Western Digital 1TB None! Ubuntu 12.04/Win8/OSX 10.8.2
27" 1440p X-Star OCN Mechanical - MX Browns Seasonic X-560 800D w/RX480 top mounted
Mouse
Logitech USB Generic
Labor of Love
(14 items)
Mouse
  Back to Forum: Water Cooling
