Overclock.net › Forums › AMD › AMD CPUs › 1055t 0c?
1055t 0c?
post #1 of 8
i cannot get any temp programs to tell me my temp on my phenom x6 1055t. real temp shows 0C, speedfan shows 0C....what the heck, do i need to RMA this dam cpu already?
Haf of an 2500K
I5 2500K MSI GD65 GTX 580 Windforce G Skill ECO
Hard DriveOSKeyboardPower
64GB A-Data SSD+500GB F3 Win7 Razer Blackwidow 750W Black Edition
CaseMouseMouse Pad
HAF 932 Razer Deathadder X-Trac Ripper
Haf of an 2500K
CaseMouseMouse Pad
post #2 of 8
No, that's just a bad core temp. Look for a socket temp or something that seems to change with the CPU's load in Hwmonitor etc, that's your real temp and the one that you need to watch. Happens with me.
The Butthurt Box
(21 items)
Intel Core i5 2500K P67 Professional AMD Radeon HD 6950 unlock NVIDIA GeForce GTX 460 2gb
RAMRAMHard DriveHard Drive
G.Skill Ripjaws G.Skill Ripjaws Intel X25-V Seagate Barracuda
WD Goflex USB 3.0 24x DVD R/W DL Win7 Ultermate 64 Acer 20in 1600x900
MonitorMonitorMonitorKeyboard
Compaq 20in 1600x900 17in Dell 1280x1024 19in Gateway 1280x1024 Razer Blackwidow mech w/ cherry MX blues
PowerCaseMouseAudio
Kingwin LZ-750 HAF 932 + sound activated lights Logitech G500 Rosewill USB headset
Pentium 4 3.2ghz w/ HT HP Intel IGP 4gb Mushkin DDR2
Hard DriveOSPowerCase
80gb sata WinXP Pro HP OEM HP Small form factor
The Butthurt Box
(21 items)
PowerCaseMouseAudio
post #3 of 8
EDIT: Check your BIOS and get a good idea of the idle temp, then go in windows and find the temp that looks the same. thats your cpu temp.
The Butthurt Box
(21 items)
PowerCaseMouseAudio
The Butthurt Box
(21 items)
PowerCaseMouseAudio
post #4 of 8
well bios shows 35c on cpu/core. speedfan has temp1 at 34C, temp2 at 29C and temp3 at -128C. is there any other program that monitors the temps better for amd?
Haf of an 2500K
CaseMouseMouse Pad
Haf of an 2500K
CaseMouseMouse Pad
post #5 of 8
Temperature sensors on the Thubans are unreliable (my 1055t displays temps of 4c - 29c).
The temperature displayed in the BIOS is the most accurate.
Phenom II X6 1055T Biostar TA890GXB HD XFX HD 5770 @ 950/1350 Kingston 4GB HyperX DDR3
Hard DriveOSMonitorKeyboard
WD 1TB Caviar Black SATA 6Gb/s Windows 7 Professional x64 Acer X223W 1680x1050 Razer Lycosa
PowerCaseMouse Pad
Thermaltake Toughpower XT 575W HAF 932 Steelseries QcK
PowerCaseMouse Pad
post #6 of 8
CoreTemp?
/hwaw
(20 items)
Intel Core i7 3770k @ 4.3ghz 1.160v ASRock Z77 Extreme6 Gigabyte R9 290 Windforce Sapphire R9 290
2x4gb Samsung RAM @ 2000mhz 9-10-9-28 1.425v OCZ Vertex 4 Hitacho Deskstar Crucial M550
CoolingCoolingCoolingOS
Corsair H80 (CPU) Thermalright Spitfire (GPU) Gelid Icy Vision (GPU) Windows 7 Ultimate 64-bit
MonitorMonitorKeyboardPower
BENQ GW2450 Asus PB278Q Cooler Master Quickfire Rapid Seasonic 750w
CaseMouseMouse Pad
Black Interior HAF 932 Roccat Kone  Artisan Hien Hard
/hwaw
(20 items)
CaseMouseMouse Pad
post #7 of 8
ok, asus pc probe works. reading cpu as 31C and when i ran prime 95, went to 37c after a min. atleast i can monitor it this way. Now, can anyone tell me why at default settings, my 1055t is overclocked? suppose to be 2.8ghz and even in bios it shows 3.26???
Haf of an 2500K
CaseMouseMouse Pad
Haf of an 2500K
CaseMouseMouse Pad
post #8 of 8
Do you possibly have core unlock enabled in BIOS? In that case you wanna disable that and it should show temps
Slave
i7 3770k Asus Maximus Gene V iGPU HD 4000 16GB DDR3 Crucial Ballistix 1600 Mhz
OSMonitorKeyboardPower
W7 x64 Dell U2412M Filco Majestouch 2 BeQuiet! Dark Power Pro 750w
Open on the desk lol
Slave
  Back to Forum: AMD CPUs
