Overclock.net › Forums › AMD › AMD CPUs › 1075t OC help
1075t OC help
post #1 of 25
I am very new at OC i am using the ASUS M4A79XTD EVO MOBO I only really want to OC to is 3.5 it has a auto 10% OC feature in bios it gets me to 3.3 I've tried so many setting and I get nothing it doesn't boot and resets bios wondering if anyone else could give some insight please feel free
If anymore info is needed please ask
My System
(14 items)
AMD Phenom II X6 1075t ASUS M4A79XTD EVO SAPPHIRE Radeon HD 7950 3GB 384-bit GDDR5 ( 111... G.Skill 8GB DDR3
Western Digital Caviar Blue WD3200AAKS 320GB 7200 LG 22X DVD±R DVD Burner CORSAIR CWCH60 Hydro Series H60 High Performanc... Windows 7 x64 ultimate
MonitorPowerCase
47" Vizio LCD 3D 1080p  Thermaltake Black Widow 850W Wicked Power COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP
My System
(14 items)
MonitorPowerCase
post #2 of 25
Your default cpu multiplier is 15. Try raising that to 17. And raise the fsb to 210 (from default 200). Keep the cpu vcore to the default offset value for now. See if the PC boots up. Try a few hours of prime95 to see if the OC is stable.
First try this and then we will go forward from here.
Phenom II X4 955BE ASUS M4A88TD-V-EVO/USB3 MSI GTX 560Ti TwinFROZR II OC Corsair XMS3 2x2GB 1600MHz C9
Hard DriveOSMonitorPower
2x500GB Seagate Windows 7 Ultimate 32bit Samsung 20" B2030 Corsair TX650 V2
CM HAF932 (painted black)
post #3 of 25
Dont understand why people oc on the fsb with a BE processor.
Put your multiplier to 19x and leave FSB at 200mhz.
CPUv @ 1.45v
CPU-NB @ 1.4v
NB @ 1.3v
try playing around, safe value for 1075t CPUv is 1.5 (or higher with 55c or less load) Do not forget that thuban processors like their CPU-NB over CPUv
Gaming 2016
(17 items)
Intel i7 6700K Gigabyte Z170M-D3H MSI GTX1070 8G ARMOR Kingston HyperX FURY DDR4
Hard DriveHard DriveHard DriveCooling
Samsung 840 Evo Samsung 850 Evo Seagate SHHD Cooler Master Nepton 240M
OSMonitorKeyboardPower
Windows 10 Pro XB321HK Logitech 710 Corsair RM550x
CaseMouseMouse PadAudio
Cooler Master Silencio 352 Logitech G500 Razer Goliathus Presonus Eris 4.5
Gaming 2016
(17 items)
post #4 of 25
d cant move multi higher then 15
My System
(14 items)
MonitorPowerCase
My System
(14 items)
MonitorPowerCase
post #5 of 25
For stability of course. All chips can not handle a very high cpu multiplier, hence getting support of the fsb ( just a lil bit, 10/15).
post #6 of 25
1075T is not a BE. Raising fsb is only way to OC.
Hasn't stopped me though (for benching purposes only) http://valid.canardpc.com/show_oc.php?id=1631416.
I'm stable at 4.2 right now.
FX-8120, and a bunch more AM3/AM2+ Crosshair V, Crosshair IV Lots of green Dominator GT
RAMRAMHard DriveCooling
Dominator GT Perfect Storm M4 64Gb Dihydrogen monoxide, Carbon dioxide, Liquid Nit...
CoolingCoolingOSPower
OCN Marksman pot k|ngp|n F1 Dark pot Stripped Xp Antec 1200W HCP
Dimastech Hard
Dimastech Hard
post #7 of 25
i have it booting doind manual settings
fsb 220,
ht multiplier 8x,
cpu vid 1.4625,
nb vid 1.15,
ddr volt 1.7,
nb volt 1.1,
ht volt 1.26
My System
(14 items)
MonitorPowerCase
My System
(14 items)
MonitorPowerCase
post #8 of 25
What is your ram rated for, and what are you running it at with 220 fsb?
Originally Posted by rtc05 View Post
oh sry im at 3.3 and rated? sry i feel like i shouldnt be oc if i cant answer some questions lol
What speed is the ram rated at? like 1333MHz or 1600MHz for example. Or what model did you buy exactly.
Edited by just_nuke_em - 2/2/11 at 12:24am
Dimastech Hard
Dimastech Hard
post #9 of 25
My System
(14 items)
MonitorPowerCase
My System
(14 items)
MonitorPowerCase
post #10 of 25
ok so after looking through this site i have found someone using this set up for 1055t to get 3.5ghz steady and stable and thats what im getting
CPU Ratio 14
Turbo Disabled
CPU Bus Freq 250
PCIE 100
Dram Freq 1000CPU
NB Freq 1750
HT Link Auto
CPU Voltage 1.4
CPU NB Voltage 1.3625
CPU UDDA Auto
Dram Voltage 1.7
HT V Auto
NV v. Auto
NB 1,8 Auto
SB V. Auto
i am using the 1075t this is working just fine im getting no higher then 54 degrees using prime95 so i guess my next question is is there anything anyone knows i need to change since its from a 1055t set up to make it cooler or even higher clock speed at same temp?
My System
(14 items)
MonitorPowerCase
My System
(14 items)
MonitorPowerCase
  Back to Forum: AMD CPUs
