Overclock.net › Forums › Intel › Intel CPUs › 41c Idle
41c Idle
post #1 of 16
41c Idle
Is this ok, i run my Q8400 2.66ghz @ 3.5ghz
my temp never really moves from that, only increases by maybe a degree Celsius maybe when rendering that is all.
post #2 of 16
Have you ever seen it go under 41°C?
Also, can you run the "Small FFTs" test in Prime95 for 10 minutes? This will show us the maximum temperature.
It's a computer!
(20 items)
i5-2500K @ 4.5GHz (1.368-1.384V fixed voltage) ASUS P8P67 EVO B3 (UEFI ver. 1850) GTX 780 ASUS DirectCU II (1228 / 6300, 1.180V) G.SKILL Ripjaws X 8GB (2 x 4GB) 1866MHz, CL9
250 GB Samsung 840 EVO (C:\) 250 GB Samsung 840 EVO (D:\) 150 GB WD VelociRaptor Toshiba 3TB P300
Optical DriveOptical DriveCoolingOS
Samsung SH-S243N 24x DVD Burner Samsung SH-S203N 20X DVD Burner Thermaltake Frio Win 7 Home Premium x64 SP1 Retail
AOC G2460PG (24" 1920 x 1080 144Hz G-SYNC) Filco Majestouch 104-key Cherry MX Blues w/NKRO Corsair HX650 (Bronze, ordered on 12-12-2009) CM 690
MouseMouse PadAudioAudio
Intellimouse Optical (1.1A) 1000Hz polling rate Basic, but premium round X-Fi Titanium HD Klipsch ProMedia 2.1 (with 16 AWG Monster Cable...
It's a computer!
(20 items)
post #3 of 16
It doesnt move, even under heavy load? That sounds more like a stuck sensor than anything else to me. You should be getting at least a 10C shift (probably more) from idle to full load with your current setup.
All Fear the TLAM
(19 items)
Core i7 860 EVGA P55 Micro GTX 670 16Gb Geil
Agility3 Western Digital Black Western Digital Green Western Digital Blue
Hard DriveCoolingOSMonitor
Western Digital Blue Corsair H80 Windows 8 Pro Iinc 28"
Acer 19" Black Widow Ultimate Corsair 650HX Silverstone FT03
MouseMouse PadAudio
Logitech PerformanceMX Rocketfish Hard Swan D2.1se's
All Fear the TLAM
(19 items)
MouseMouse PadAudio
post #4 of 16
No, ive actually never seen it go under 41c, even after i took my old zalman tunnel flower off to replace with my cm-v8. Should i maybe load back up stock settings and see if anything different?
never see it move really on when rendering videos. But if its reading 41c and above why not 41c and under?
post #5 of 16
Sounds like a stuck sensor to me maybe?
The Wtfer
Core i7 2600K ASUS P8Z68-V PRO EVGA GTX 465 w/ 470 Shaders/Memory/Clocks 8GB G.Skill DDR3 1866
Samsung F3 1TB LG 22X DVD±R DVD Burner Windows 7 Professional 64-Bit Dell U2311H + LG W2242S
PowerCase
Corsair 750TX Coolermaster RC-692 Advanced
The Wtfer
PowerCase
post #6 of 16
Sensors are definately stuck. They will only show movement when the cpu is put under load. Realtemp has a feature wich allows you to test the sensors. Might be worth to give it a go.
Rosso Illuminato
X4 955 Asrock 790 4870 1 gb XMS
1.5 tb dvd rw 7 premium Samsung Syncmaster T200
Dell Corsair TX650 Antec 300-R Logitech generic crap
Rosso Illuminato
post #7 of 16
what are your temps after 10 minutes of prime?
post #8 of 16
Attached file is 10 minutes of small FFT prime on, with sensor test on.
Can someone analyse this for me please so i know whats going on, because my temp readings do actually change at appropriate times, like when you would expect them too... but they dont budge much
~Much thanks, Rhys
post #9 of 16
~Much thanks, Rhys
Yeah, I definitely say that sensor is stuck. If I recall it was a quite common occurrence on some Core 2's.
The Wtfer
PowerCase
The Wtfer
PowerCase
post #10 of 16
It cant really be that dangerous can it? its no big deal really is it?
and is there any way i get un-stick the sensor? maybe taking it out then putting it back in? Thanks for your input
p.s- still dont get how it can be stuck when the temps are increasing and decreasing?
  Back to Forum: Intel CPUs
