Overclock.net › Forums › Graphics Cards › AMD/ATI › 4970x2 VS. 5770
4970x2 VS. 5770
post #1 of 4
i dont need DX11 (tho it would be nice) and ive heard the 4870x2 smokes the 5770 in CF is it worth it or wait till 5970 goes down in price and how much of a performance increase would i get and the 4870x2 needs a 650W and ive got a Corsair TX650W will it be fine
Edited by AMDGamer101 - 2/3/11 at 7:55pm
i5 4670k @4.4GHz asrock extreme 4 z87 atx Nvidia GTX 1080 Founders Edition  klevv 8gb urbane 2400MHZ
Hard DriveHard DriveHard DriveCooling
1TB 5400RPM Intel SSD 330Series 60GB  Sandisk SSD Plus 120GB Boot Drive XSPC Raystorm D5 EX240 Water Cooling, koolance ...
OSMonitorKeyboardPower
Windows 10 Pro 64-Bit ASUS MX279H  Saitek Eclipse III Corsair TX650W
CaseMouseAudio
thermaltake x9 Snow  Razer DeathAdder 2013 Logitech 5.1 X530
CaseMouseAudio
post #2 of 4
A 4870x2 is pretty close to the 5870, and two 5770s is pretty close to a 5870. I don't think that the 4870x2 smokes two 5770s at all. If anything the two 5770s would beat the 4870x2 and you would have directx 11.
post #3 of 4
4870 itself is a bit faster than 5770.
But CFX Scaling on 5000 series are better than 4000 series (and 6000 series are even better).
So, I'd say they are equal in performance. But HD 5770 have some great advantages.
- 2x HD 5770 use significantly less power than HD 4870 X2
- You can use Eyefinity in HD 5770
- HD 5770 supports DX11
- HD 5770 runs cooler than HD 4870 X2
HD 5970 is okay but why not getting 2x HD 6850 instead of single HD 5970?
Their performance are very close each other.
HD 5970 is an old card and you might get a bit problem when asking about warranty if something bad happen to your card.
AMD Ryzen 7 1700 3.7 GHz ASRock AB350 Pro4 PowerColor Radeon R9 290 4GB GDDR5 2x 8GB Crucial DDR4 2666 MHz
Samsung SSD 960 EVO 250 GB Samsung Spinpoint HD103SJ 1TB Seagate Barracuda ST4000DM001 4TB OCZ Vendetta 2
Windows 10 Professional LG 25UM58-P 2560x1080 60Hz Power Logic Xenon Sabre Seasonic P760
CaseMouse
D-Vito 911 Cooler Master CMStorm Sentinal Advance II
CaseMouse
post #4 of 4
Idk man ive been told to stay away from two card solutions cause of problems but i want to do the CF 5770 how much of a performance increase will i see cuz my CPU right now on GTA4 is like 41% cuz my card is bottlenecking it frown.gif same with others like BFBC2.ETC and how do u avoid problems, just keep drivers updated or what cuz i do that all the time and are the drivers the same ones or CF drivers??
CaseMouseAudio
CaseMouseAudio
  Back to Forum: AMD/ATI
