Overclock.net › Forums › Overclockers Care › Overclock.net Folding@Home Team › 6806 EUE's, anyone else?
post #1 of 13
Anyone else been getting repeated EUE's on 6806's? I'm guess this is an issue my the units, not my card, because they're all failing before 1%. The card is stable, increasing voltage did not help.
Finally an update
(14 items)
i7 7700k MSI Z270 Pro Carbon Zotac GTX1060 6gb GSkill TridentZ 16gb (3200mhz)
Samsung 960 Evo Samsung 850 EVO 250gb WD Blue 500gb x2 RAID0 ASUS DVDRW
CoolingOSMonitorKeyboard
Thermalright Venemous-X Windows 10 Acer H257HU 1440p Razor Blackwidow
PowerCase
Seasonic X650 Coolermaster Storm Scout
Finally an update
(14 items)
PowerCase
post #2 of 13
No problem here, are you getting the same 6806?
Check the RGC of the unit to make sure.
If not then try stock clocks and see if it was just that the ones being sent out are a little more demanding.
i7 930 4.0ghz 1.27v EVGA E758 3-Way (black/gray) Evga GTX 480 / Evga 9800gtx+ (physx&folding) Corsair Dominator 6gb 1600 8-8-8-24
Hard DriveOSMonitorPower
x25-M SSD 80gb + 1TB F3 + 2x2TB WD Green Win 7 64bit Viewsonic 20" + Samsung 40" Corsair 1000w
Haf 932 (modded) - Now caseless
post #3 of 13
Tried stock clocks, same problem. Insta-fail. Seems like it fails right around when it should be posting 1% (about a minute in).
Finally an update
(14 items)
PowerCase
Finally an update
(14 items)
PowerCase
post #4 of 13
Did you check if its the same 6806 (run gen clone)?
If any case delete the queue.dat file & work folder and see if that works.
post #5 of 13
No issues here.
post #6 of 13
i am not face any EUE on all fermi WU with both my card..
My On Off Hobby
(15 items)
Alienware M15x
i7 740QM P55 GTX 260m 4GB DDR 3
500GB DVD RW Win 7 HP 64bit 15inch HD resolution
PowerCase
150Watt dell Magnesium alloy
My On Off Hobby
(15 items)
Alienware M15x
PowerCase
post #7 of 13
Yes, every one is identical.
Project: 6806 (Run 3987, Clone 2, Gen 10)
Will try that.
Finally an update
(14 items)
PowerCase
Finally an update
(14 items)
PowerCase
post #8 of 13
That has never happen to me but does to everyone, I really wonder what the cause is.
Edit - 12k.
post #9 of 13
Congrats.
Didn't work. Still downloading the exact same unit and failing it immediately. The first 470 has yet to download that particular unit.
Finally an update
(14 items)
PowerCase
Finally an update
(14 items)
PowerCase
post #10 of 13
Delete the same things and change the machine ID.
  Back to Forum: Overclock.net Folding@Home Team
