Overclock.net › Forums › Intel › Intel CPUs › 12500k, failed prime95 blend test
post #1 of 16
Hello, I was able to passed the prime95 small fft test, and the intel burn test, 20 runs at high, however, my computer will BSOD running prime blend test in about 3 hours. How do I fix it?
i2500k at 4.5G
Turbo ratio on all core to 45
Internal PLL overvoltage, ON
LLC, AUTO
VRM fix frequence, 350
Phase control and duty control, EXTREME
CPU voltage, OFFSET MODE
CPU PLL voltage, 1.72
I have the PNY Optima 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 RAM.
post #2 of 16
Well, you don't really need the VRM Fixed Frequency since you're not at a very high overclock. Even at high overclocks it doesn't improve anything in most cases.
Onto the main topic, Try upping the DRAM Voltage or VCCIO Voltage. In most cases I'd say when Blend fails its memory related.
The Wtfer
Core i7 2600K ASUS P8Z68-V PRO EVGA GTX 465 w/ 470 Shaders/Memory/Clocks 8GB G.Skill DDR3 1866
Samsung F3 1TB LG 22X DVD±R DVD Burner Windows 7 Professional 64-Bit Dell U2311H + LG W2242S
PowerCase
Corsair 750TX Coolermaster RC-692 Advanced
The Wtfer
PowerCase
post #3 of 16
What are you memory timings, speed, and voltage?
HTPC
(8 items)
i7-3930k MSI X79MA-GD45 Powercolor 7950 G Skill
Hard DriveCoolingCoolingCooling
Samsung 830 Swiftech Apogee XT Rev. 1 EK-FC HWLabs Black Ice GTX 240 and a Koolance HX-CU72...
CoolingCoolingOSOS
MCP 35X and a MCP 350 Koolance 401x2 Opensuse 12.1 Windows 7
KeyboardPowerCase
Ducky OCN with cherry blues Antec True Power New 650W Cooler Master CM690 II
i5-750 Gigabyte p55-ud2 GTX 430 G Skill
Hard DriveOSPowerCase
Samsung HD204UI Fedora 15 Corsair CX-430 Silverstone GC04
HTPC
(8 items)
CoolingCoolingOSOS
KeyboardPowerCase
post #4 of 16
9-9-9-24, 1.5v, 1333
post #5 of 16
my ram voltage is at 1.5v now, how much should i up it to?
post #6 of 16
It might not be your RAM as you are running it at the rated specs. You might try either upping the core voltage or lowering the overclock to see if that gives you stability.
HTPC
(8 items)
CoolingCoolingOSOS
KeyboardPowerCase
HTPC
(8 items)
CoolingCoolingOSOS
KeyboardPowerCase
post #7 of 16
Just to be sure it isn't a lack of voltage to your RAM, set the RAM voltage to 1.55v and give it another run.
My System
Core i5-2500k @ 5.0Ghz 1.480v Asus P8P67 Radeon HD 4850 Gskill Sniper (2x4GB) DDR3-1600 CL9
OSPowerCase
Windows 7 64bit Antec TruePower New 650 Antec Nine Hundred Two v3
My System
OSPowerCase
post #8 of 16
more vcore .. just press + and f10 and exit if u can prime for 3 hours then id suggest going up 1 incriment only .. bsod are caused in prime due to not enough vcore or ram v.
Intel i5 7600k @ 5Ghz, 1.312v Asus Prime Z270-AR msi GTX 1080 32GB Corsair Vengeance DDR4 3Ghz
Hard DriveCoolingOSMonitor
Transcend SSD220S 120GB  Corsair H80i V2 Windows 10 Pro 64bit AOC AG322FCX 32" Curved LED 144hz 1920x1080
Razer Blackwidow Ultimate Antec Quattro 1000w Thermaltake Versa N27 msi Gaming series
Mouse PadAudio
Razer Goliathus Steelseries Siberia V2
Mouse PadAudio
post #9 of 16
However, I would like to set the vcore to offset mode, cause when the pc is idle, it's is the low 1.0x range.
And I just passed the intel burn test with 30 runs at high setting.
post #10 of 16
IBT isn't testing socket 1155 CPUs very well. Blend seems to be the best stress tester so far. Increase vcore and retest.
Gaming PC / HTPC
(17 items)
Bedroom PC
i7 7700k Asus Prime Z270-A GB Auros-X 1080 Ti G-Skill (2x8gb) 3000mhz
Samsung 850 Western Digital 5900rpm Seagate 7200rpm LG 22x DVD Burner
CoolingOSMonitorKeyboard
Noctua NH-D14 Win 10 x64 Pro LG 55" 4k B6 OLED Microsoft Desktop 400
PowerCaseMouseMouse Pad
Corsair TX750 V2 NZXT Source 210 Microsoft Desktop 400 Black
Audio
Custom Surround 5.1
Intel 2120T Biostar H61MH Intel HD 2000 G-Skill F3-12800CL9D-8GBXL
Samsung Evo 128gb Asus 24x DVD Burner Stock Win 10 x64
LG 40" 1080p HP Wireless Keyboard/Mouse Silverstone 400W ST40F-ES Silverstone ML03B
Other
Linksys WMP600N Wireless Card
Gaming PC / HTPC
(17 items)
Bedroom PC
Audio
Custom Surround 5.1
Other
  Back to Forum: Intel CPUs
