Overclock.net › Forums › Consumer Electronics › HDTV › 42" as monitor
42" as monitor
post #1 of 6
I just bought [ http://www.newegg.com/Product/Produc...27&Tpk=42ld550 ] at bestbuy on Monday, for the same price. So far its great, minus the fact some of my MKVs will not stream audio because apparently its unsupported. Not really my issue though.
I currently have the TV connected with a DVI to HDMI adapter. MY 5970 has a mini display port on the back, what would be the best mini display port to hdmi converter and would I see better quality? Right now it looks great, and even better if i play files from my NAS directly through the TV and not my PC. But I feel like its being held back by the DVI to HDMI, because my refresh rate is only 60Hz when the TV can support more.
Is this correct? Or would I note see a quality increase with a mini displayport to hdmi converter?
Nighthawk Redux
(17 items)
Intel Core i7 3820 RAMPAGE IV EXTREME Asus NVIDIA GeForce GTX 690 G.SKILL Sniper Gaming Series
Corsair Force Series GT WD Caviar Black ASUS 24X DVD Burner Corsair H100
OSMonitorKeyboardPower
Windows 7 42" LG 42LD550 Logitech G19 Corsair AX850
CaseMouseMouse PadAudio
Antec DF-85 Logitech G500 X-Trac Ripper XL Asus Xonar Essence STX
Audio
Blue Yeti Pro Microphone
Nighthawk Redux
(17 items)
Audio
post #2 of 6
There will not be any difference in quality, so I wouldn't recommend wasting your money on an adapter.
TV's cannot support more then 60hz input, even the 240hz ones.
SUPERPWN
(12 items)
Core i5 4670K Asus z87-Pro MSI GTX 1080 Aero 32GB DDR3 Gskill Ripjaws
Hard DriveOSMonitorMonitor
4TB Seagate Windows 8 x64 Overlord x270 OC HP ZR27
MonitorKeyboardPowerAudio
Asus PG279Q G-Tune Topre Realforce 800w Yulong D100 DAC with Denon D7000 headphones
SUPERPWN
(12 items)
post #3 of 6
i got my 42 plasma hooked to pc. HUGE DELAY not made for pc gameing , well for connection use the hdmi one. Go on amazon get a mini to hdmi I got a 6 foot for 6 dollars i think. Owell Good luck.
Dyslexia
(16 items)
Dyslexia
(16 items)
post #4 of 6
That's too bad. I have a 46" Sony and there is no lag at all.
Did you make sure to turn off all the image processing? That can cause input lag.
SUPERPWN
(12 items)
SUPERPWN
(12 items)
post #5 of 6
Running an LG 42" LCD over HDMI just fine. Games work great too. But like Crazy9000 said, 60hz is the highest you can go.
post #6 of 6
^ Ok cool, and yeah... not sure why your TV is lagging, but mine is perfect. I just wanted to know if there would be any quality difference (as far as Hz goes) with the mini dp to hdmi. I'll more than likely get an adapter but no time soon, thanks guys.
Nighthawk Redux
(17 items)
Audio
Nighthawk Redux
(17 items)
Audio
  Back to Forum: HDTV
