Overclock.net › Forums › Intel › Intel CPUs › 44c idle i5 2500k?
44c idle i5 2500k?
post #1 of 14
Jusy built my new rig and when I go into the BIOS it says my cpu is at 44c; surely that is higher than normal?
Pretty sure I installed the hyper212+ correctly,
Using the AC MX-2 Thermal paste
What's wrong with it?
i5 2500k P8p67 pro Rev3 MSI Gtx560Ti Twin FrozerII 8gb XMS3
1tb f3 M4 ssd LG GH22NS50.AUAA 22x SATA DVDRW Drive Hyper 212+
OSPowerCase
Windows 7 650w Antec TruePower New NZXT Phantom Black
OSPowerCase
post #2 of 14
I would suggest using another program or two to check temps. RealTemp and HWmonitor are the two that I use.
real temp http://www.overclock.net/downloads/3...l#post12522270
hwmonitor http://www.cpuid.com/softwares/hwmonitor.html
Temp do seem a little high, maybe try re-seating the CPU cooler. What voltage do you have it set at?
Also if you didnt know already there is a CM 212+ thread here that might be worth browsing through http://www.overclock.net/air-cooling...plus-club.html
Edited by BigFrank - 3/5/11 at 12:11pm
Like a Bausss...
i5-2500K @ 4.7ghz 1.416v ASUS P8P67 PRO XFX Radeon HD 6950 (unlocked to 6970) G.SKILL Ripjaws 4 x 2GB 1600MHz 7-8-7-24
Hard DriveOSPowerCase
OCZ Vertex 2 120GB Win 7 Home Prem. x64 XFX 850W Black Edition CM 690 II Adv.
Mouse
Razer Abyssus
Like a Bausss...
Mouse
Razer Abyssus
post #3 of 14
Still at stock settings, I currently can't connect to the internet on it (am on another computer) I actually did reseat the cpu before but the temps stayed the same
OSPowerCase
OSPowerCase
post #4 of 14
Managed to get onto the internet here is the CPUID
OSPowerCase
OSPowerCase
post #5 of 14
Temps are fine man..
Bios puts like a 60% load on cpu IIRC.. Higher temps than idle are normal in bios
post #6 of 14
Temps are fine. Looks good!
Like a Bausss...
Mouse
Razer Abyssus
Like a Bausss...
Mouse
Razer Abyssus
post #7 of 14
Thanks a bunch mate +rep
OSPowerCase
OSPowerCase
post #8 of 14
Now over clock that i5!!!!
Like a Bausss...
Mouse
Razer Abyssus
Like a Bausss...
Mouse
Razer Abyssus
post #9 of 14
Haha think i'll wait until april when I get my case before I do any overclocks
OSPowerCase
OSPowerCase
post #10 of 14
nah.....case isn't going to make a difference.
Like a Bausss...
Mouse
Razer Abyssus
Like a Bausss...
Mouse
Razer Abyssus
  Back to Forum: Intel CPUs
