Overclock.net › Forums › AMD › AMD CPUs › 1090t OC
1090t OC
post #1 of 8
Can someone please take a look at my rig and tell me what i would need to do to be able to run atleast 4ghz i would prefer 4.2ghz because im having alot of trouble getting anything stable.
Work in Progress
AMD Phenom II X6 1090T@4.2ghz(1.5v)NB 3ghz(1.35v) GA-890FXA-UD7 Radeon HD 5870 x2 Crossfire Kingston 1333 DDR3 4gb
Hard DriveOSMonitorPower
1TB western digital + 160gb western digital Windows 7 64bit Philips 23" LCD @ 1920 x 1080 COOLER MASTER SILENT PRO GOLD 1000W
COOLER MASTER HAF X
Work in Progress
COOLER MASTER HAF X
post #2 of 8
You may try to get to 4GHz in 2 ways.
The simpler one is start increasing the CPU multiplier one at a time and try to boot into windows. When you can no longer load windows, increase voltage a little and try again.
The other way is increasing both CPU multiplier and FSB. For that you want to lower your RAM speed to the lowest possible and with the timings set to its spec, and start increasing speeds and try to boot into windows. whenever fail, increase voltage and try again, until you have a satisfiable result.
Post your progress and we'll be here to assist in what we can
BTW, have you ever tried to OC it?
I need upgrades
(21 items)
Phenom II X6 1090T Foxconn A79A-S PNY GTS450 XLR8 KVR800D2N6/2G
WD2500AAKS WD3200AAKS WD10EARS WD3200JB
Optical DriveOptical DriveCoolingOS
Asus DRW-1608P2 Asus DRW-1608P2 Corsair H70 Ubuntu Server 10.10 x64
OSMonitorKeyboardPower
Windows 7 Professional x64 SP1 ASUS VW193S Logitech EX100 LC-Power 650W
CaseMouseAudioAudio
Coolermaster Stacker 830 SE Logitech EX100 Creative Audigy 2 ZS Creative i-Trigue L3450
I need upgrades
(21 items)
CaseMouseAudioAudio
post #3 of 8
Set the CPU multiplier to x20 and the CPU voltage to 1.5V. Literally that easy! Then check your temps. You may need a big jump in voltage to get to 4.2GHz, and most likely will not be able to achieve that while maintaining safe operating temperatures with the H70.
The Beast
Phenom II x6 1090T 4.2GHz Gigabyte 890FXA-UD5 MSI Twin Frozr III 6950 2gb 8GB (2x4GB) GSkill Ripjaws 1333
Samsung Spinpoint F4 320GB, 2TB ASUS DVD/CD RW Windows 7 3x HP 2311x
PowerCase
XFX 750W AzzA Hurrican 2000
The Beast
PowerCase
post #4 of 8
its my first time OC'ing and yes i have tried OC'ing just with no luck, i have monitored temps all thoughout my failure and stayed within safe limits, its just confusing for a beginer like me because when it fails to be stable im not 100% sure what is making it fail,
Work in Progress
COOLER MASTER HAF X
Work in Progress
COOLER MASTER HAF X
post #5 of 8
try what ttaylor0024 just suggested above, you should have no problems
I need upgrades
(21 items)
CaseMouseAudioAudio
I need upgrades
(21 items)
CaseMouseAudioAudio
post #6 of 8
i hear everyone say that i cant run 4.2ghz of an h70, im not so sure about that i ran p95 @ 4.2 with 1.5v and nb 3000mhz with 1.3v for 30mins before my pc frooze and still didnt hit 55c socket temp 51 was highest i had with core temps only reaching around 48c, most if the time my cpu sat at 48c (socket temp)
Work in Progress
COOLER MASTER HAF X
Work in Progress
COOLER MASTER HAF X
post #7 of 8
That sounds about right for the voltage. Every chip & motherboard is different, and require different voltages to achieve different levels of performance. 30mins of P95 is not near enough to call it stable, as you already know. If you can get that, bump the CPU voltage up a notch, and try it again. Just make sure your temps are good
For me, it takes 1.55V to get 4.2GHz, and its not 100% stable, still working on perfecting it
The Beast
PowerCase
The Beast
PowerCase
post #8 of 8
If you haven't seen/read through this thread I'd advise giving it a good looking over as it contains all the basics of "how to over clock" as well as giving you a good path to follow.
http://www.overclock.net/amd-general...ing-guide.html
Every chip has different requirements and demands and while asking others for settings may get you there, they probably won't be the optimal settings for your individual setup. It's always best to have the basic knowledge and your end results will be far better. OC'ing takes time and should be in stages while making small changes between testing. I'd recomend starting out by studying this guide than as you have trouble just ask for help with a particular problem area. That's my
Ryzen Build
(20 items)
Bruce
(14 items)
R7 1800x Crosshair VI Hero Diamond 7970 GSkill FlareX F4-3200C14D-16GFX
Samsung 960 EVO NVMe Samsung 840 SSD Corsair GT SSD WD 2TB Black
Hard DriveCoolingCoolingCooling
WD 4TB Red EK-FB Asus C6H Monoblock XSPC GPU Razor WB XSPC RX 360
CoolingCoolingCoolingCooling
XSPC RS 360 XSPC EX140 D5 Vario Gentle Typhoon AP-15 1850 rpm
OSMonitorPowerCase
Win 10 Pro Asus VE248H x2 EVGA 850 G2 Xigmatek Elysium
FX 6350 Asus M5A99FX Pro R2.0 GTX220 G.Skill Ripjaws X F3-17000CL9D-8GBXLD 9-11-9-28...
Samsung 840 Pro WD20EFRX 64M Red x4 raid 10 WD5001AALS Blk Asus DRW-24B1ST
CoolingOSMonitorKeyboard
Hyper 212 Evo R2 Windows Server 2008 R2 Standard Asus  Logitech MK300
PowerCase
Corsair HX500 Corsair 330R Titainium
Ryzen Build
(20 items)
Bruce
(14 items)
OSMonitorPowerCase
PowerCase
  Back to Forum: AMD CPUs
