Overclock.net › Forums › AMD › AMD CPUs › 965BE c2
965BE c2
post #1 of 8
What kind of overclocks are people getting wiht the 965BE c2 version?
Comp
3770K EVGA Z77 FTW Two 6970s Xfired 950 MHz/ 1450 MHz +20 8 gigs DDR3 1600mhz
SSD 1)Blue ray player 2) DVD writter Linux from scratch 24in Gateway
Its a keyboard 1200 Danger Den Doublewide yes
Mouse Pad
Jack Skellington (overclocked)
Comp
Mouse Pad
post #2 of 8
Around 3.8-3.9 without ridiculous votls I believe.
Intel i3 540 P7H55M-Pro XFX 6770 OCZ Platinum
OCZ Vertex 2E  Samsung F4 Maxtor DiamondMax 23 LG Super-multi Drive
CoolingOSMonitorKeyboard
Coolermaster Hyper212+ Microsoft Windows 7 Professional 64-bit LG W2361V Razer Tarantula
PowerCaseMouseMouse Pad
Corsair CX430v2 Coolermaster Elite 335 Logitech MX518 Roccat Taito
AudioAudioAudio
Asus Xonar DG Logitech Z523 2.1 Speakers Sennheiser PC350 Headset
AudioAudioAudio
post #3 of 8
What a bout those 6 core ones, what are people getting with those?
Comp
Mouse Pad
Comp
Mouse Pad
post #4 of 8
Depends on which one..
1055T get to like 3.8-4.0.
1090T and 1100T, I have seen people getting 4.3- 4.5Ghz.
AudioAudioAudio
AudioAudioAudio
post #5 of 8
what is the difference between the 1090t and 1100t?
Comp
Mouse Pad
Comp
Mouse Pad
post #6 of 8
The stock multi thats it they are the same chip
The 1055t will do 4Ghz - 4.2Ghz - I took mine up to 4.6Ghz
The 1090t will clock a little better due to the unlocked multi but that is the only difference
post #7 of 8
Yeah i just hit this wall with my 965 it wont budge over 3.8 and was just exploring other options.
Comp
Mouse Pad
Comp
Mouse Pad
post #8 of 8
Its a C2 - 99% of them top out at 3.8ish
The C3 stepping was a great step forward as most will do 4Ghz 4.2Ghz
The Thuban E0 stepping that the X6's are based on is even better
  Back to Forum: AMD CPUs
