Overclock.net › Forums › Components › Power Supplies › 550w psu
550w psu
post #1 of 8
will this be able to power my system witha gtx 560 instead of my 250?
under the radar
(17 items)
i5 2500k gigabyte ga-z68x-ud4-b3 MSI GTX 970 Gaming 4g 8gb corsair vengeance
Plextor SSD samsung spinpoint f3 1TB samsung spinpoint f3 1TB Western Digital black 1TB
CoolingOSMonitorKeyboard
silver arrow windows 7 ultimate 64bit samsung s23a950D Ducky shine 3 year of the snake
PowerCaseMouseMouse Pad
Corsair AX1200 corsair 650D razer deathadder Steelseries QCK
Audio
asus xonar essence stx
under the radar
(17 items)
Audio
post #2 of 8
yeah you should be fine. Take a look at this link it shows a 560 running in a full stress test with an i7965. That cpu draws more power than yours so I don't see any problems.
The Build
Intel Core i7-920 Bloomfield @ 4.2 GHz ASUS P6X58D Premium Dual Unlocked ASUS ATI HD6950s G.SKILL 6GB DDR3 1600
Intel X25-M 2.5" 80GB SSD and 1TB WD Caviar Black Pioneer Blu-ray Disc/DVD/CD Writer Windows 7 Ultimate x64 Dell u2711
Razer Arctosa Thermaltake ToughPower XT 750W Thermaltake Element S Razer Lachesis
The Build
post #3 of 8
sweet as cause ive put down the volts on my cpu from stock 1.245 to 1.1 and can probs go a bit lower too
under the radar
(17 items)
Audio
under the radar
(17 items)
Audio
post #4 of 8
lol I realized I forgot to add the link. Here ya go. http://www.guru3d.com/article/radeon...60-ti-review/4
The Build
The Build
post #5 of 8
You need to post what exact 550W unit (brand and model number) you're talking about.
post #6 of 8
A quality 550w PSU can easily handle a GTX560.... so which 550w PSU?
Once again...
i7 920 [4.28GHz, HT] Asus P6T + Broadcom NetXtreme II VisionTek HD5850 [900/1200] + Galaxy GT240 2x4GB G.Skill Ripjaw X [1632 MHz]
Hard DriveOSMonitorKeyboard
Intel X25-M 160GB + 3xRAID0 500GB 7200.12 Window 7 Pro 64 Acer H243H + Samsung 226BW XARMOR-U9BL
Antec Truepower New 750W Li Lian PC-V2100 [10x120mm fans] Logitech G9 X-Trac Pro
Once again...
post #7 of 8
its only 1 that came with my case but alot better then my 700w psu i brought not long ago... its called sunpro so not a good 1
under the radar
(17 items)
Audio
under the radar
(17 items)
Audio
post #8 of 8
Well it doesn't help when your case is "standard", whatever that means.
SunPro is among the worst power supply manufacturers around, on par with Leadman and Linkworld and Keerda. You're looking at an appallingly poor 250W half bridge unit with Canicon caps (or similar), no transient filter, and a +12V capacity in the single digits.
The CoolerMaster is better, even if it's one of their crap units.
  Back to Forum: Power Supplies
