Overclock.net › Forums › Graphics Cards › AMD/ATI › 4650 running as hot as the sun
post #1 of 17
Sometimes when im doing gaming example GTA 4 the temps slowly increase to 99c i was gonna overclock the card now i wont cause it will get to millons of degree's.
post #2 of 17
Custom fan profile? And can you link us the exact card?
Looking at them...they have wimpy coolers Open up CCC (Catalyst Control Center) and under "ATI Overdrive" (Or AMD overdrive lol), manually set the fan speed above what I assume to be the mediocre stock setting.
Little Black Box
(18 items)
Vostro
(7 items)
Galaxy S4
(7 items)
i5 6600k AsRock Fatal1ty Z170 ITX EVGA GTX 980 SC G. Skill Trident Z 16GB(2x8GB)
Samsung 830 64GB Samsung 840 Evo 120GB Seagate ST 2TB Seagate ST 500GB
CoolingOSMonitorMonitor
Corsair H60 Win 10 Pro Planar PX2710MW AOC U2868PQU
Rosewill RGB80 Corsair HX850 Corsair Obsidian 250D Logitech M705
Mouse Pad
XTrac Ripper XL
Core 2 Duo T5670 Dell OEM Intel GMA 950 3Gb DDR2-667
Hard DriveOSMonitor
WD Scorpio Blue 250Gb Linux Ubuntu 12.10 x64 15.4" Tru-Bright 1280x800
Snapdragon 600 MSM8960 Adreno 320 2GB LPDDR
Hard DriveOSMonitor
16GB+16GB Jelly Bean 4.2.2 JDQ 1080p
Little Black Box
(18 items)
Vostro
(7 items)
Galaxy S4
(7 items)
Mouse Pad
XTrac Ripper XL
Hard DriveOSMonitor
Hard DriveOSMonitor
post #3 of 17
http://www.newegg.com/Product/Produc...-829-_-Product
It's that version but its DDR2 and not GDDR2 and doesnt have a low-profile bracket
Edited by topog_z - 3/12/11 at 9:08am
post #4 of 17
Hmm...remove the heatsink and see how the TIM is? It might need replacing.
Little Black Box
(18 items)
Vostro
(7 items)
Galaxy S4
(7 items)
Mouse Pad
XTrac Ripper XL
Hard DriveOSMonitor
Hard DriveOSMonitor
Little Black Box
(18 items)
Vostro
(7 items)
Galaxy S4
(7 items)
Mouse Pad
XTrac Ripper XL
Hard DriveOSMonitor
Hard DriveOSMonitor
post #5 of 17
Is your computer prebuilt? How is the airflow in that case?
@above: I wouldn't remove the heatsink at this time because that would void the warranty.
Current i5 Rig
(14 items)
Core i5-760 (4.0ghz @ 1.28v) GIGABYTE P55-USB3 Asus GTX 770 DirectCU II OC 2GB 4GB DDR3 (XMS3 1600)
Corsair Force 3 120gb + 2.5TB HDDs LG Noctua NH-D14 Windows 7 Home Premium x64
23" Acer X233H + 19" GNR Logitech G110 OCZ ModXStream Pro 700W Coolermaster 690
MouseMouse Pad
Logitech G500 Razer Sphex
Current i5 Rig
(14 items)
MouseMouse Pad
post #6 of 17
Things to check:
- good case airflow / fans, not clogged with dust
- update to new driver version
- room temp excessively high?
- fan on video card working?
- TIM on video card as mentioned above
If it's a new card and all of the above are in check you may want to RMA.
post #7 of 17
Use Manual fan control via the CCC when your going to put on your game just bump it up to whatever % you find the noise tolerable.
If i ever got a GPU without manual fan control i'd return it the same day lol, ie auto = fail.
post #8 of 17
Forgot it might be pre-built If it is, look to RMA.
Little Black Box
(18 items)
Vostro
(7 items)
Galaxy S4
(7 items)
Mouse Pad
XTrac Ripper XL
Hard DriveOSMonitor
Hard DriveOSMonitor
Little Black Box
(18 items)
Vostro
(7 items)
Galaxy S4
(7 items)
Mouse Pad
XTrac Ripper XL
Hard DriveOSMonitor
Hard DriveOSMonitor
post #9 of 17
Before you try dissecting the thing, have you tryed the same game with manual fan control? thats normal temps for auto, my gpu doesn't hit 50c ..ever on 30% manual control, if i left it on auto it would hit 100c & the fan driver would just say "coolbeans"
post #10 of 17
to say the sun is 99c is an understatement to say the very least lol.
anyway, check that the heatsink is on properly and check that the fan is working correctly
:3
(10 items)
2600k Asus P8Z77-I Deluxe GTX 680 2GB 16GB Corsair vengeance
Hard DriveOSMonitorPower
2x 250GB HyperX Windows 7 SP1 x64 Benq G2420HD XFX 650W
CaseAudio
lian li pc-q08b On-board
phenom II X4 955 C3 @ 4.2ghz 1.4v ASUS M4A79T Deluxe Radeon HD 5870 crossfire 940/1300 8GB corsair ddr3 1600mhz 7-8-7-20@1.75v
Hard DriveCoolingCoolingOS
120GB Kingston HyperX SSD, 250gb HDD x3 +660Gb 5870 Accelero Xtreme Corsair H100  win 7 ultimate 64bit (stipped to bone)
MonitorPowerCase
Benq G2420HD XFX Pro 650W (sleeved) (seasonic in disguise) Bitfenix Colossus
(10 items)
CaseAudio
MonitorPowerCase
  Back to Forum: AMD/ATI
