Overclock.net › Forums › Intel › Intel Motherboards › $235.19...best sb motherboard on newegg
$235.19...best sb motherboard on newegg - Page 2
post #11 of 17
Originally Posted by Blue Destroyer View Post
Bahh...guess I have to wait for extreme4 or sabertooth or some others to come in stock I guess...
I'd just wait until June before you buy...I mean, you already have a good rig...stick with it for just a bit longer.
Who knows, they may even launch new boards by then
Kamtastic II
AMD Athlon II X4 630 Gigabyte GA-MA790GP-UD4H Visiontek 4850 512MB Reference 8GB A-Data DDR2 800
750GB Caviar Black Currently Samsung 20x SH2022 Windows 7 Ultimate x64 2 x Samsung Synchmaster 226BW
Logitech G11 OCZ 700w GameXStream Thermaltake V9 Black Edition Razer Copperhead
Kamtastic II
post #12 of 17
Originally Posted by AsanteSoul View Post
because there arent any! Other than the ud7 and maximus iv extreme which supposedly has the ability to do so...i have the m4e and i think u need to occupy the 1st pci slot in order to utilize the 16x bandwidth with the lower pci slots
don't lie, p8p67 ws revolution does x16 x16 way cheaper then ud7
Gene-Z Dedi
(7 items)
Captain America
(6 items)
CPUMotherboardRAMHard Drive
i7 2600k @ 5.2 Ghz Asus Maximus IV Gene-Z Gskill 2133 4GB Caviar Black
CoolingOSPower
Corsair H100 Arch x64 OCZ 650 Watt
CPUCPUMotherboardGraphics
Intel Xeon E5-2650 Intel Xeon E5-2650 ASUS Z9PE-D8 WS XFX 6870
RAMOS
32 GB Samsung Arch Nix
Gene-Z Dedi
(7 items)
Captain America
(6 items)
CoolingOSPower
RAMOS
post #13 of 17
Originally Posted by BigFrank View Post
If you do not plan on crossfiriring or sli I would just get the ASUS P8P67.
If you do want to in the future I would look into the ASUS PRO board.
If you plan on doing some serious OCing I would get the ASUS Deluxe.
/Thread.
post #14 of 17
the gigabyte p67a ud5 b3 is in stock on superbiiz the last time i checked... (around the same price 230ish or the ud4 which is 189 plus shipping)
To tell you the truth i am a sucker for the color scheme and the huge amount of power phases gigabyte boards have with the p67 chipsets.
The features of the gigabyte boards compared respectively with their asus counterparts basically have the same features minus the uefi bioses and Bluetooth... instead they have higher amounts of power phases so i am assuming they have a better potential to overclock more stably and to generally overclock more especially if your going to be cooling subzero.
Galbus
(21 items)
Intel Core i7-6700K 8M Skylake Quad-Core 4.0 G... ASUS ROG MAXIMUS VIII EXTREME LGA 1151 Intel Z1... 3x MSI GeForce GTX 1080 Founders Edition  2x [Trident Z] F4-3600C16D-16GTZKW 16-16-16-36...
Hard DriveHard DriveOptical DriveOptical Drive
Plextor M8Pe AIC 1TB PCI-Express 3.0 x4 MLC Int... Plextor M8Pe AIC 1TB PCI-Express 3.0 x4 MLC Int... LG BH16NS40 Blu-ray Card Reader: Rosewill RDCR-11003 - 3.5" 74-in-1...
CoolingOSMonitorKeyboard
Custom Ultra cool passive heatsink Microsoft Windows 10 Pro 64-bit ViewSonic XG2703-GS Black 27" 4ms (GTG) IPS G-S... Das Keyboard 4 Professional Mechanical Keyboard
PowerCaseMouseMouse Pad
CORSAIR AXi Series AX1500i Digital 1500W 80 PLU... Corsair Obsidian 750D Black Aluminum / Steel AT... Logitech G900 Chaos Spectrum Logitech
AudioOtherOtherOther
onboard Canon i-SENSYS LBP7680Cx (5089B014) Duplex 9600... Canon imageFORMULA DR-F120 (9017B002) 600 dpi U... Brother Personal Plain Paper Fax Machine, FAX-575
Galbus
(21 items)
post #15 of 17
Gotta order through newegg. $100 newegg gift card...either that or a mb shipped under $135.19 from somewhere else
Haf of an 2500K
I5 2500K MSI GD65 GTX 580 Windforce G Skill ECO
Hard DriveOSKeyboardPower
64GB A-Data SSD+500GB F3 Win7 Razer Blackwidow 750W Black Edition
CaseMouseMouse Pad
HAF 932 Razer Deathadder X-Trac Ripper
Haf of an 2500K
CaseMouseMouse Pad
post #16 of 17
For what its worth, Of the 3 P67 boards Ive had, This Sabertooth is by far the best.
post #17 of 17
then i recommend waiting until they have either the p8p67 pro in stock or atleast a ud4 b3 in stock....
I don't know abt msi boards since i have heard not so good things about them comming back from amd.
To Be honest Newegg doesn't have much in stock in terms of p67 boards... so you're very limited... i think most of the asus boards are out of stock except the matx p8p67 asus they have.
I would wait man... unless if you're seriously itching then go for the higher end msi ones they have
Galbus
(21 items)
Galbus
(21 items)
  Back to Forum: Intel Motherboards
