Overclock.net › Forums › Components › Monitors and Displays › 21,5 vs 27
21,5 vs 27
post #1 of 16
Hey guys,
I was wondering if I would notice a difference between an 21,5 1080p screen and 27inch 1080p screen?
Cheers
Rocket Science
(14 items)
i7 2600K 4.8GHz Asus Sabertooth P67 2x 6950 2GB CrossFire G.Skill 8GB
Hard DriveOSPowerCase
Intel 510 250GB+Samsung 1TB Windows 7 64bit Corsair HX850W NZXT Phantom
Audio
Sony RF865RK
Rocket Science
(14 items)
Audio
Sony RF865RK
post #2 of 16
Of course you would, but neither one is necessarily better - it depends how close you would be to it and the differences between the monitors besides size.
And just because I found this immediately on Google...:
post #3 of 16
Originally Posted by Cmdr.Shephard View Post
Hey guys,
Cheers
Seriously? One screen is bigger thats what u would notice!
Primo
(15 items)
I7-7700k Asus Maximus Hero ix Evga GTX 1080 ACX 3.0 G-Skill F-43200C15D-16GTZKW
Hard DriveHard DriveCoolingCooling
Samsung 850 Evo Corsair Neutron  Ek Supremacy CSQ clean OCOOL 360mm radiator
CoolingCoolingOSKeyboard
OCOOL 360mm radiator Ek -FC1080 GTX  Windows 10 CM Storm
PowerCaseMouse
Evga 750 watt Phanteks Enthoo Primo Roccat Kone Optical
Primo
(15 items)
PowerCaseMouse
post #4 of 16
Is there anything like quality losses in sharpness, smaller/bigger pixels? etc
Rocket Science
(14 items)
Audio
Sony RF865RK
Rocket Science
(14 items)
Audio
Sony RF865RK
post #5 of 16
Aint the resolution the same 1920x1080, does this mean that the image is streched out? So same amount of space on the screen?
Rocket Science
(14 items)
Audio
Sony RF865RK
Rocket Science
(14 items)
Audio
Sony RF865RK
post #6 of 16
It's the same amount of pixels over a larger area. If you have good eyesight or sit close to the screen, the 21.5" would probably be fine. Otherwise, the 27" might be a better bet.
post #7 of 16
Yes, it's the same amount of screen space. It's simply bigger which also means pixels will be bigger, making things less sharp if you sit close to the monitor.
(10 items)
4670k + EK Supremacy Asus Maximus VI Hero Sapphire 290x + EK wb 16GB
CoolingMonitorKeyboardPower
EK CoolStream XTX 360 (x2) Dell U2311 (x2) CM Storm Trigger CM V1000
CaseMouse
HAF Stacker Logitech G9
(10 items)
CaseMouse
post #8 of 16
yea the 21.5 would look sharper, while the 27 would be better from a greater distance if you like to kick back in a chair while playing games......also it might need AA for a better picture
X5680@4.8GHz 192x25x1.47v EVGA X58 Classified(E759) EVGA GTX980 Ti SLI @1515/8400 6x4GB GSkill Ripjaws@1540 8-8-8-20-2T-1.55v
Hard DriveHard DriveHard DriveCooling
Corsair Force GT 120GB/OS Corsair Force LS 60GB/PAGE Toshiba 4TB/GAMES CPU-EK Supremacy
CoolingCoolingCoolingCooling
MB-EK FB Classified GPU-EK FC TitanX/Backplates Rad-Swiftech 360mm MCR-320/Pump Rad-Barrow 280mm
CoolingCoolingCoolingOS
Ram-Corsair 2x60mm Resevoir-Barrow 250x50mm Misc-6x120mm/2x140mm/NZXT Sentry,Barrow 3/8 fit... Windows 10 Pro x64
Seiki 50'' 3840x2160 30hz Logitech G110 EVGA Supernova G2 1300 Lian Li PC-A77F
MouseMouse PadOtherOther
Logitech G9x Xtrac Ripper XL Logitech G27 Logitech G940
Other
Xbox One controller
Other
Xbox One controller
post #9 of 16
I'd take the 27". Though I do use a 15.4" 1920x1200 display on my laptop... I use a 24" 1920x1200 display at work, and I wouldn't mind it being a little bit bigger.
post #10 of 16
I'm truly sorry, but seriously can people stop making stupid posts like this.. No ****, we're talking about size over here 27 > 21.5 sweeeeeet, hit the little search button or just type in google for christ sake before you waste 8 people's times responding to your post. // Rage, sorry.
Intel I7 870 2.93 GHZ @ 4008MHZ 1.375 24/7 Stable MSI Big Bang Fuzion EVGA Nvidia GTX 460 + ATI 5750 1GB | HYDRA LOGIX! CORSAIR DOMINATOR 2 x 2Gb 1600
Hard DriveOSMonitorKeyboard
60GB Vertex 2 / 2 640 WD Black Cavier 64mb Raid 0 Windows 7 64 Bit Viewsonic 20.1 1680x1050 Logitech G15
PowerCaseMouseMouse Pad
Thermaltake Toughpower 850 watts Thermaltake Shark Modded Razer Diamondback Plasma Steelseries 5L
  Back to Forum: Monitors and Displays
