Overclock.net › Forums › AMD › AMD - General › 820 Spiked to 87c
820 Spiked to 87c
post #1 of 7
I have been running prime blend for 5 1/2 hours. then my temp max on CPUid HW monitor shows a max temp of 87c but pretty much constant at 47c. can someone explain
Project#1
(14 items)
965BE MA790X-UD4P HD 4850 512mb 256-bit OCZ Platinum 4GB (2 x 2GB)
Hard DriveCoolingOSMonitor
Western Dig. 500gb mugen scythe 2 windows 7 64-bit 27in Asus
PowerCase
Rosewill 530watt 80+ Antec 300 series
Project#1
(14 items)
PowerCase
post #2 of 7
Might be a bug, happens to me sometimes on HWMonitor (sometimes even across the board)
post #3 of 7
Is there a way to check this? I ran a blend test all night with a max temp after i cleared of 49c. This only pops up when blend is passing 1024k. I dont wanna burn up my chip due to max temp @ 76c. But if my temp really got to 86c wouldnt the bios shut down my pc?
Project#1
(14 items)
PowerCase
Project#1
(14 items)
PowerCase
post #4 of 7
It might or it might not. I ran my 555 BE at 75c (max of 58c) without the PC shutting down. I didn't have my heat-sink on properly.
Use CoreTemp and see if you get the same result.
CPUGraphicsGraphicsRAM
Intel i7 3630QM HD 7970M HD 7970M 2x4GB 1333MHz
Crucial M4 256GB mSata Seagate Momentus 750GB Western Digital Scorpio Blue 500GB DVD Burner
OSMonitorMonitorKeyboard
Windows 7 64-Bit Ultimate 17.3" 1920x1080 Matte Screen Auria 27" 2560x1440 Back-lit Clevo Keyboard
Power
330 Watt Power *BRICK*!
Power
post #5 of 7
Core temp wont display anything
(?) <-- thats all i see next to Temp
downloaded everest unlimited- working and recording temps. Im going to run blend for another hour, see if i get the same spike in there.
Edited by SpR-b - 4/16/11 at 6:31am
Project#1
(14 items)
PowerCase
Project#1
(14 items)
PowerCase
post #6 of 7
how can i check temp logs in everest?
Project#1
(14 items)
PowerCase
Project#1
(14 items)
PowerCase
post #7 of 7
If your cpu hit that high of a temp it would throttle or shut off.
  Back to Forum: AMD - General
