Overclock.net › Forums › AMD › AMD Motherboards › 870a-ud3
870a-ud3
post #1 of 14
well i'm having a few issues with this motherboard at the moment.
i just bought it, it's a gigabyte GA-870A-UD3, rev 2.1. i got it to make a computer for my mother and at the same time, swap over some of my stuff into her new computer and get new stuff for mine.
one of the changes was taking out my gigabyte 5830 vid card and putting it in to her computer while i get a 6950.
anyway, when the 5830 is plugged in to her computer, the screen wont come on. no matter how many times i take it out and put it back in, nothing changes.
i put my 6950 into her computer and the screen works.
i put the 5830 in to my computer (i have a GA-890fx-ud5 rev 2.0 board) and it works fine.
does anyone know what could be the problem? it doesnt appear as if the 5830 is faulty - i've been using it for a fair while and it still works on my computer. i'm not totally convinced it's the MB either - my 6950 works on it fine.
any suggestions? i'm kinda lost for answers. the only thing i can think of is putting in a new bios and hope that helps, however i dont know what version bios is on the board - i forgot to check lol
energy efficient
Phenom II X2 555BE @ 3.57 Gigabyte 890FX-UD5 Gigabyte 5830 @ 860/1100 OCZ 1600CL8 BE @1680
1TB Hitachi Samsung Windows 7 64-bit Acer 23" 16:9
PowerCase
Thermaltake 600w Thermaltake Element
energy efficient
PowerCase
post #2 of 14
well i upgraded the 870 bios to the F4 bios, still no change. the 5830 card still doesnt work in the computer but my 6950 does
any thoughts???
energy efficient
PowerCase
energy efficient
PowerCase
post #3 of 14
uninstall all display drivers Then put the 5830 back in.
Main Rig
(12 items)
R7 1800x ASUS Prime 370 Pro RX 480 Corsair Dominator
Samsung 850 Pro  None Windows 10 Pro HP w19e: 1440x900 | Sony KDL40S-5100 1920x1080
CMStorm Quick Fire. CM 1050w  Cooler Master Cosmos II Roccat Kone XTD (Optical)
Main Rig
(12 items)
post #4 of 14
no point. post screen doesnt even show on the monitor with the 5830 installed. i havent installed any display drivers anyway, just leaving the stocko windows one going (ie everything is huge on the screen - vga?)
energy efficient
PowerCase
energy efficient
PowerCase
post #5 of 14
i can suggest you do is make sure you are running the latest bios version
and if thats not the issue maybe RMA?
Main Rig
(12 items)
Main Rig
(12 items)
post #6 of 14
everything is latest bios - that's why i'm so confused. a friend thought it might have been because of different PCIe versions, but surely not. the MB's both say 2.0 on them, however the cards are 2.1, well support 2.1. i'm sure that's not the problem otherwise i'd have problems with the 5830 in my 890fx-ud5 and problems with the 6950 in the 870a-ud3.
i've raised a ticket with gigabyte so i'll see what they have to say
energy efficient
PowerCase
energy efficient
PowerCase
post #7 of 14
well it looks as if, from further google searching, that this is a bit of an issue with this MB, however i couldnt find anyone saying they could get 1 vid card to work and 1 not to work, even though both cards are fine. i'm going to try clearing the cmos and try putting the computer together on a bench with cardboard underneath just incase there is a shorting issue. will also hook up a speaker and see if i get any beeps.
any other suggestions?
energy efficient
PowerCase
energy efficient
PowerCase
post #8 of 14
further to this, i have put in a motherboard speaker - only 1 beep upon starting.
i have also tried both the x16 and x4 pcie slots and there is no difference in the outcome
does anyone have any ideas?
energy efficient
PowerCase
energy efficient
PowerCase
post #9 of 14
what psu are you using with the gigabyte and the 5830
i7
(14 items)
AMD
(10 items)
i7 2600k ASUS P8Z68-V Pro HIS 7870 IceQ X 4x4 Gskill Sniper 1600
Hard DriveHard DriveCoolingOS
Crucial m4 64gb ssd Samsung F3 1tb Corsair H80 Windows 7 x64
Gateway FHX2402L LED-LCD 24in 1080p Logitech K120 Corsair TX 850W NZXT Phantom White
Mouse
Rude Fierce Gaming Mouse
i7
(14 items)
AMD
(10 items)
Mouse
post #10 of 14
thermaltake litepower 600w - http://www.thermaltake.com.au/Produc...power600W.aspx - been using it on my other pc for about 1.5 years. but i'm certain it is fine anyway - as i've said, my 6950 card allows the computer to work, just not the 5830 (well the computer works, just not the monitor)
energy efficient
PowerCase
energy efficient
PowerCase
  Back to Forum: AMD Motherboards
