Overclock.net › Forums › Graphics Cards › NVIDIA › NVIDIA Cooling › 560ti
560ti
post #1 of 13
I purchased a 560ti and don't intend on making any modifications to the card but was thinking that perhaps placing a fan blowing down on the PCB would help with cooling. Also this wouldn't require any modifications that would void my warranty. Anybody have thoughts on this or tried this?
My System
AMD 1090T asus ma489td pro/usb3 560ti gskill 12 gb
vertex 2 80gb (25nm nand I think) generic spare I found around the house windows 7 64 bit dell 23" lcd
PowerCaseMouse
ocz modxstream pro 700watt xclio blackhawk color microsoft wireless mouse
My System
PowerCaseMouse
post #2 of 13
Depends, what are your temps?
AiryBox
(15 items)
Intel i7 3770k Gigabyte GA-Z77X-UD5H Sapphire 7950 Vapor-X Corsair Vengeance 8GB
Hard DriveHard DriveCoolingOS
Hitachi Desktar 7200RPM 1TB Samsung 830 128GB Corsair H100i W10 Pro
BenQ 24" Qpad Mk-50 Cherry MX Red CM V700 NZXT H440
AiryBox
(15 items)
post #3 of 13
It wouldn't really as the fan isn't choked at all. If the card is in SLI then sometimes the top card can block the bottom's intake.
The Butthurt Box
(21 items)
Intel Core i5 2500K P67 Professional AMD Radeon HD 6950 unlock NVIDIA GeForce GTX 460 2gb
RAMRAMHard DriveHard Drive
G.Skill Ripjaws G.Skill Ripjaws Intel X25-V Seagate Barracuda
WD Goflex USB 3.0 24x DVD R/W DL Win7 Ultermate 64 Acer 20in 1600x900
MonitorMonitorMonitorKeyboard
Compaq 20in 1600x900 17in Dell 1280x1024 19in Gateway 1280x1024 Razer Blackwidow mech w/ cherry MX blues
PowerCaseMouseAudio
Kingwin LZ-750 HAF 932 + sound activated lights Logitech G500 Rosewill USB headset
Pentium 4 3.2ghz w/ HT HP Intel IGP 4gb Mushkin DDR2
Hard DriveOSPowerCase
80gb sata WinXP Pro HP OEM HP Small form factor
The Butthurt Box
(21 items)
PowerCaseMouseAudio
post #4 of 13
If you have the twin frozr II the card already runs cool. I would angle the fan so it can blow across the memory chips and so forth.
My System(s)
(15 items)
5820k MSI X99S PLUS MSI Lightning GTX 780 3GB Team Group 2x4GB 2400MHz Ordering new ram soon.
Mushkin Enhanced Chronos Deluxe LG 22X DVDRW XSPC 240mm kit Windows 8.1
Qnix QX2710 (96Hz) Logitech G15 Corsair HX850 Azza Hurrican (R)
Audio
Creative Labs Titanium X-FI
My System(s)
(15 items)
Audio
post #5 of 13
Its a galaxy card. Here are pictures. I don't have temps yet since I don't have my rig up and running. I had a VRM on my motherboard burn out and it Killed both my CPUs. Since the Sempron was only 32 bucks it wasn't worth the RMA but now I have a cool Heat spreader key chain. Waiting on the Phenom X6 to get shipped back form AMD. The Phenom passed V/M inspection and they said it was shipped Friday.
My System
PowerCaseMouse
My System
PowerCaseMouse
post #6 of 13
My current max temp is 47 degrees Celsius while playing GTA IV with Fan speed 100%. It only hovers around 20-30% GPU usage while playing.
My System
PowerCaseMouse
My System
PowerCaseMouse
post #7 of 13
If you're going to supplement your cards cooling with independent fans, then place on perpendicular to the fan on the card. Some cases (such as the HAF series from Cooler Master) have a mounting point on the case door specifically assisting the cooling of graphics cards. Note however, that you won't see a huge decrease in temps.
EDIT: BTW those temps are excellent, might want to just throttle the fan speed down a bit. Do you have the fan in a manual mode?
Intel Pentium G2020 Ivy Bridge 2.9GHz ASRock H61M-DGS Integrated Intel HD Graphics (Don't Laugh!) G.SKILL Ripjaws Series 4GB (2 x 2GB)
Samsung P3 500GB 7200RPM LITE-ON DVD Burner Intel Stock CPU Cooler Windows 7 Home Premium
Acer G226HQLBbd Black 21.5" Razer Lycosa SeaSonic S12II S12II 380B 380W COUGAR Spike Black Steel / Plastic MicroATX Min...
post #8 of 13
I tend to agree with Kaosuonline.
I have a UK 2000 sitting on the side of my case, blowing cool air across the side of the card. It went from 32c to 28c idle. Under load (folding) it went from 68c to 59c. (ambients 24c). Id recommend trying it.
post #9 of 13
What is a safe maximum for these 560TI GPUs? I used MSI afterburner to set the temp to 100%
My System
PowerCaseMouse
My System
PowerCaseMouse
post #10 of 13
Dial it down around 78ºC (if you ever hit that...)
Do you mean you set the fan speed to 100%? It is fine to leave it on AUTO, don't get me wrong, if you can take the noise that it gives off then you can leave it. The fans reliability lifespan is rated with them running @ 100%
I would leave it on auto tho, Afterburner will adjust graciously!
  Back to Forum: NVIDIA Cooling
