Am I Suffering From A Bottleneck
1K views 21 replies 7 participants last post by  Manooloo
#1 ·
Hi guys. I have an Athlon x3 and 6850. In games such as Counter Strike: Source the FPS will drop from a constant 100+ down to ~50.
In Black Ops it just plain out runs poorly. It kind of lags, i will be walking along and then sudden freeze, game pops back in and I am dead. It doesn't feel like connection lag because I don't suffer these sort of problems in CoD4, and because you can pretty much feel when it is poor connection.
In Team Fortress 2 the FPS will sometimes drop to ~20-30 for a couple of minutes. It's really annoying.
What I'm wondering is am I suffering froma bottleneck?
My RAM is 4GB-Kit GEIL Black Dragon PC3-8500 DDR3-1066 CL7 incase that is important.
#5 ·
An Athlon X3 445 should be more than enough for an HD6850, I'd be confident to stay it is not a bottleneck issue, but more like a driver problem.
I'd try uninstalling your current drivers via the Control Panel, then boot the PC in Safe Mode (F8) to run Driver Sweeper and clean all ATI drivers.
Once that is done, restart, and install these;
http://support.amd.com/us/kbarticles/Pages/AMDCatalyst115ahotfix.aspx
Once you're done installing and restarted the computer, try gaming again, and report back to this thread to tell us if it's any better.
#7 ·
Originally Posted by Manooloo
Ok, i used it and no other nVidia drivers were on the PC, just my ATI drivers. The games still run the same.
Are you on the 11.5a Hotfix now?
#9 ·
Run down:
1. Check if the GPU is on the top PCI Slot, closet to the CPU
2. Check for bad drivers
3. Uninstall all of your graphic card drivers and reinstall them
4. Check to see if there is any programs running in the background when you are gaming
5. Make sure there is no Antivirus scanning, that goes hand and hand with 4. hat includes protection software with it that scans files in real time.
6. Make sure your computer is on High Performance mode in the Power Settings. You can find it in the Control Panel, it's a big green battery icon.
7. Do some cleaning, sometimes junk builds up in the computer and causes file access to be slow.
Download CCleaner [Download Page]
Download Auslogics' Defrag [Download Page]
Run the file cleaner and the registry cleaner in CCleaner and check start up items and disable ones you know you don't need. The start up items are in the Tools tab.
Run Auslogics and check the settings before you run it.
Set defrag priority to High (option in the SETTINGS DROPDOWN Menu)
Go to the PROGRAM SETTINGS in the SETTINGS Dropdown menu
Go to the Algorithm tab. Everything should be check marked, if not, check them. Set the fragment sizes to 100MB instead of 10MB.
8. Make sure you're not using ReadyBoost USB's. I've tried, they make FPS worse in games, at least for me it did.
9. Your motherboard is a 870 AMD chipset, have you considered using AMD's Overdrive and doing a small overclock on your CPU if you're worried it's a bottle neck?
Those are tips from everyone in this thread and many from my personal experience from trying to squeeze as much FPS out of TF2 as I can on my poor pc
#10 ·
I did what you said and the same thing still occurs in Black Ops and CS:S.
And yes I am using the 11.5a hotfix. GTA IV used to run perfectly for me but it now lags like a piece of ****. Should i revert back to older drivers?
#11 ·
Have you looked at my post?
(I'm assuming you haven't yet since it was only 15 mins ago)
#12 ·
I deleted the drivers and am going to restart the PC and install them again, but after my Defrag completes. I am using the top PCI slot. My antivirus is not scanning or anything in the background. I do not run any other programs in the background apart from Steam. I always have my PC on Hih Power mode. Have't got a clue what Readyboost is. Will it be OK to apply a small overclock with the Stock Cooler?
#15 ·
I can definitely assure you THAT is not a bottleneck. -.-
#16 ·
While I don't think you are running into a bottleneck(something is wrong with your system), an Athlon II x3 can easily limit a 6850/460, without question. Both my 460 and 6850 were horrible on my 3.5Ghz x3.
Did Black ops ever run good on it? I didn't try it on my old x3 because I got the game after replacing it with an x4. The x4 ran it ok.
#20 ·
The game seems to be running much better since i maxed out every setting. I qas running at lower settings and the frames were much lower, around 80FPS which constantly dropped to 30.
Now i get 90FPS which, when in a lot of action drops to 50FPs. Is this normal for a game to perform better when the settings are maxed out?
NVM, the frames seemed to have dropped again, down to 30-50
#21 ·
I think that you may have settings enabled that you shouldn't or maybe worst your hardware could be damaged or aging which is unlikely.
have you messed with the voltages?
