CaseLabs "Goliath" on the loose
31K views 247 replies 57 participants last post by  TorathKal
#1 ·
Apparently, the lab chimps were doing unauthorized experiments on a TH10A and things got out of control and now "Goliath" is on the loose. This is the only known photo. Other cases should consider it armed and dangerous. Last seen, it was packing four 560's...
** UPDATE **
Case Features:
  • All Aluminum Construction
  • The Flex-Bay System
  • The Accessory Mounting System
  • Integrated Horizontal Radiator Mounting
  • Dual Chamber Construction
  • Quick Release Exterior
  • Anti-Vandal Switches with Black Sleeved Cables
  • Removable Motherboard Tray and Mini Tech Station
Technical Specs:
5Flex-Bays (5.25 bays): 26 (2 x 13)
PCI Slots: 10
Motherboard tray size (width x height):
XL-ATX: 10.63" x 13.69" (270 x 348mm)
HPTX: 15.13" x 13.69" (384mm x 348mm)
Native HDD Locations: 3-4
Native SSD Locations: 0-2
Total possible HDD locations with extra HDD cages (using additional mounts, purchased separately) 32
Total possible SSD locations with extra SSD mounts (using additional mounts, purchased separately) 64
PSU Mounting locations: 2
Weight: 34 lbs (15.5 Kg)
Optional Front I/O Panel: Yes
Compatible Motherboard Form Factors:
mITX: Yes (with XL-ATX Tray)
mATX: Yes
ATX: Yes
E-ATX: Yes
E-ATX (dual CPU):Yes (with HPTX Tray)
XL-ATX: Yes
HPTX: Yes (with HPTX Tray)
SSI-CEB: Yes
SSI-EEB: Yes (with HPTX Tray)
Dimensions:
Exterior (width x depth x height. Dimensions shown are for the case only. Rubber feet add .75'' (19mm) to height, optional standard casters add 2.6'' (67mm) and HD Casters add 3'' (76mm)): 17" x 26" x 25.5" (432mm x 662mm x 650mm)
Motherboard chamber dimensions (width x depth x height): 7.6" x 25.4" x 24.4" (194mm x 646mm x 621mm)
PSU chamber dimensions (width x depth x height): 7.6" x 25.4" x 24.4" (194mm x 646mm x 621mm)
Maximum Radiator/Fan clearance above motherboard tray with standard height top cover: 126mm
Maximum Radiator/Fan clearance below the motherboard tray: 126mm
Cooling Tower Clearance (air cooler): 180mm
#2 ·
Flex bays on BOTH sides? Oooh!
#7 ·
At the risk of being unreasonably reasonable, I understand that if you have a computer operating in an area where the ambient temperature is exceptionally high, very large radiators are advised to maintain an acceptable operating temperature. I remember some Australian build logs where this was a design decision in choosing a CaseLabs case.
#8 ·
I love ridiculous things like this
. I can see needing four 560mm radiators in this case since it can host two machines, each with four GPUs and dual CPU boards all water cooled and overclocked
. I would probably still order the additional pedestal for the case and throw another two 560mm rads in it as well.
#11 ·
I'm also not that surprised to see this design, it is not a stretch to think of flex bays on both sides of this case. The design of the TH10A allows for this modification to the existing case. I think it resembles a smaller version of the TX10 but without the upper and lower radiator chambers. I would like to see is a smaller version of the TX10 - take this mod and add the upper and lower cooling chambers and then that's what I want in a case.
#12 ·
Also, every case should have the drop in top/bottom ability and not be locked to one particular setup. There's no reason why a case that can support a 480 shouldn't be able to also support a 420 (TH10A) (and if the pedestal for it can support a 560, why can't the case itself?). I guess there's some reason for this "deficiency" that I as a non-engineer doesn't see or understand, but from a "wish stance" the drop in ability should be a default.
#15 ·
#18 ·
I can share a few more details, but keep in mind the design is still a little fluid, so things could change
  • "Goliath" will be officially designated as the THW10
  • It will have 4X (2 upper and 2 lower) removable radiator mounts.
  • It will have dual Flex-Bay stacks (2 x 13)
  • Size: (W x D x H): 17" x 26" x 25" (432mm x 662mm x 637) - essentially 2" wider than the current TH10
More information and photos to come late next week
#21 ·
So THW10 essentially doubles the space for mounting optical drives, fan controllers, etc. That indeed is a very welcome change. From my experience with TH10A, I ended up sacrificing an optical drive for a 140.3 mount. Attaching radiator-fan "sandwiches" to top and bottom surfaces was a bit tricky, too - something that removable mounts improve on. I wonder if the middle plate is now right in the middle?
However, how does it accommodate 560 radiators if it is the same depth as TH10A? 480 ones take most part of that with not much left.
#22 ·
Sounds great to me! (A TX10 junior
By removable radiator mounts I assume you mean drop in mounts? Since there are 2 at each end, do they use the single wide one and you can mix and match the mount types? (makes sense from a production view if you can use the same part over a range of products).
#25 ·
They have the same clearance as they do in the pedestal or STH10/SMA8. It is close and you would likely use the use of the adjacent Flex-Bays (except maybe for fans). The 480 mount is offset, like the others, so you have a better chance of making use of the Flex-Bays if needed.
The radiator mounts are different than any other design largely because of the issues of getting 560's to work in a TH10 frame. The mounts are universal and interchangeable.
