Originally Posted by
DiGiCiDAL
Even without delidding it - it shouldn't get anywhere near that temperature with that low an OC... that would definitely cause problems with the stock cooler (were it to be used) at stock clocks!
If it's a bleeding problem, it should be resolved fairly quickly without requiring the torture test. Just let it idle and keep and eye on the temps... if you're hearing air noises in the loop... they should stop fairly quickly since you've already run the system for awhile. For reference, my 3580K at 4.7GHz & 1.42V vCore had idle temps around 38C and peaked with one core at 87C after 10 minutes of IBT running (all cores were under 75C with Prime95 running).
It was horrible prior to delidding (the differences between core temps under load was nearly 15C!) - but it still never got hot like that.
It seems like either the mounting is bad (so try remounting the CPU again and check to make sure that you didn't leave the plastic protective label on the block (it happens apparently). When you pull it to remount clean and reapply the TIM - but before that make sure there's a good impression in the TIM from the last mount. Also make sure when you tighten the block down that you tighten the bolts a little bit in a circle... i.e. do 1 turn of one bolt, then 1 turn of the next bolt and so on, going around and around until it's fully tightened. Doing one side all the way at first can lead to uneven pressure on the chip which can cause bad temps.
If all of that fails to make a difference - which I think it probably will - then take the block apart and confirm that the cooling lanes aren't blocked by something or poorly milled.
And while you're at it... take a picture of your loop so we can look at it... it's possible that we can spot something that's not apparently from just your description (i.e. if you're using a
directional block like the XSPC Raystorm - the water must flow in a particular direction for the block to work optimally). In any case, we need pics and more information.
