Help: Overclocking FX-6100 with an Asus Sabertooth 990FX - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 01-16-2012, 05:22 AM - Thread Starter
TridentKeeper's Avatar
Rep: 0
Hi, I am new with this scorpius setup and I need assistance on reaching a stable 4.5ghz mark or better.
RIght now I am at 4.5ghz that can boot but experiencing hardware failures on Prime95 and AIDA64 benchtests.
On Cinebench 11.5 I usually get a 5.02 score.
On SuperPI it takes 15min to process a 32mb iteration.
Here are my specs for now. (please check RIG)
And here are my BIOS settings.
D.O.C.P = On
Multiplier = 22.5
Memory Frequency = 1600mhz
CPU/NB Frequency = 2200mhz
CPU Volts = 1.4500
The rest are set to AUTO.
With this noob overclock(I know I am a noob) setup I could POST and go to windows and perform simple tasks without any bluescreen either on Cinebench, LinX and or IBT.
BUT can't pass PRIME95, I am getting an error of "Illegal Sumout" - "Hardware Failure"
I need your help guys with my Setup. I know my RIG is adequate enough to pass a 4.5ghz mark FULL 24/7 Stable.
I really need your help.
If you have this similar motherboard and processor, please post your settings aswell let me copy it smile.gif if its okay.
Info:
Asus Sabertooth 990FX BIOS Update 0901 (latest from ASUS) from 0705.
RAM: Corsair Vengeance 4gbx2 1600Mhz C9
PSU: Seasonic Xseries X850
Cooling: Antec Kuhler H620 with DeepCool Z9 Thermal grease, Scythe Kaze Jyuni 1900RPM push pull config.
here are some of my UEFI Screenshots.
450
450
450
TridentKeeper is offline
post #2 of 18 (permalink) Old 01-16-2012, 08:32 AM - Thread Starter
Rep: 0
post #3 of 18 (permalink) Old 01-16-2012, 08:49 AM
IOSEFINI's Avatar
Rep: 331 (Unique: 255)
first of all you have to disable Turbo Core. --> test and see if you still get that error
Intel CPU:
3770K; QX9650; D930
Intel mobo:
ASUS Maximus V Gene; GIGABYTE X48T-DQ6
AMD CPU:
2x8350; 8320; 8300; 8120; 1090T; 960T; 840T; 955; 5800K; 3870K
AMD mobo:
ASUS Crosshair III, IV, V; F2A85-M Pro; F1A75-M Pro R2.0; GIGABYTE 990FXA-UD7; ZOTAC 890GXITX-A-E
IOSEFINI is offline
post #4 of 18 (permalink) Old 01-16-2012, 09:34 AM
Linux Lobbyist
garikfox's Avatar
Rep: 270 (Unique: 198)
We have the same memory, You have to manually set timings for it to be stable at 1600MHZ
AI Overclock tuner - Manual
Ratio - 22.5
AMD Turbo Core - Disabled
PCIE - Freq - 100
Spread Spectrum(s) - Disabled
CPU/NB Frequency - AUTO
HT Link - AUTO
Goto the Advanced CPU config tab and DISABLE all the power savings etc, Disable the whole list.
DRAM Timmings: (FYI: Make sure ECC mode is Disabled) = AUTO, AUTO, Disabled, Disabled, Enabled, Enabled
9
9
9
24
6
6
6
9
12
160
41
AUTO
AUTO
AUTO
AUTO
AUTO = 7.8ms
2T
CPU - Load LIne Calibration = High
CPU/NB Load Line = High
CPU Current Capability = 120%
CPU/NB Current capability = 100%
PWR Phase Control = Optimized
CPU Voltage Frequency = AUTO
VRM Spread SPectrum = Disabled
CPU Power Duty Control = T.Probe
Voltages: Manual Control
CPU - 1.3975v or around there.
DRAM Voltage - 1.50625
The rest AUTO
FYI: Idle Volts should be 1.380v , Under Load your Vcore should goto 1.360 Volts, AMD reccomends starting at 1.350v for 4500MHz
ASRock X99 Taichi / Intel i7-6800K / G.SKILL 4x4GB DDR4-2400 / Samsung SM961 128GB / RX Vega 56 / EVGA SuperNOVA G2 750W / Acer ED323QUR / Windows 10 Enterprise LTSC
"Humans aren't the only species on Earth, We just act like it..."
garikfox is offline
post #5 of 18 (permalink) Old 01-16-2012, 10:41 AM - Thread Starter
Rep: 0
Ratio - 22.5
PCIE - Freq - 100
HT Link - AUTO
9
9
9
24
6
6
6
9
12
160
41
AUTO
AUTO
AUTO
AUTO
AUTO = 7.8ms
2T
The rest AUTO
Thank you good sir for the insight, can't wait to go home from work to test this settings out. I knew it was my RAM settings, I am just scared of adjusting it. I'll try it our once I get home, let you know asap.
post #6 of 18 (permalink) Old 01-16-2012, 10:41 AM - Thread Starter
Rep: 0
Thank you for the reply. I will try that as soon as I go home from work, Ill let you know asap.
post #7 of 18 (permalink) Old 01-16-2012, 10:59 AM
Linux Lobbyist
garikfox's Avatar
FYI: Also make sure your Kuhler 620 is set as Intake, Not Exhaust.
http://blog.antec.com/cooling/asetek-air-flow-matters/
garikfox is offline
post #8 of 18 (permalink) Old 01-16-2012, 01:47 PM - Thread Starter
Rep: 0
Yep already did that from day one smile.gif thank you again!
post #9 of 18 (permalink) Old 01-16-2012, 02:11 PM
Linux Lobbyist
garikfox's Avatar
FYI: 4.5GHz might be a bit much for the FX-6100 so Ill put some different options on the table, Make sure to always use CPU LLC on High.
These setting should work for the FX-6100 since its what I tested my FX-6100 with.
My FX-6100 (VID 1.225v or 1225mv)
4.2GHz - In BIOS set Vcore = 1.3375v
4.3GHz - In BIOS set Vcore = 1.3500v
If you keep the voltage Below 1.35v it will dramitically increase the lifespan of the CPU
Heres a Good OC guide from AMD
http://sites.amd.com/us/Documents/AMD_FX_Performance_Tuning_Guide.pdf
Keep in mind that the green Voltage/Frequency chart at the bottom are "Under Load Voltages"
garikfox is offline
post #10 of 18 (permalink) Old 01-17-2012, 05:28 AM - Thread Starter
Rep: 0
HI,
Thank you for the tips and links smile.gif I really appreciate it.
I downloaded the AMD Overdrive software just to test the waters and to lessen by reboot time aswell. (once I get full stability on the clocks and settings I get from AMD Overdrive, i'll implement that on the BIOS.)
Here are the latest update.
1. Given with the settings you suggested, 4.2GHz - In BIOS set Vcore = 1.3375v or 4.3GHz - In BIOS set Vcore = 1.3500v, I cant get full stability without increasing my volts to 1.400v. (stable at 4.2ghz @ 1.4v)
2. Still trying to mix and match some settings to attain the 4.5ghz goal. (4.5ghz @ 1.4500v can boot but not pass PRIME95 blend test or the SMALL test)
3. What if I increase the NB speed, would that make a difference?
4. what If I increase by FSB speed(indeed it will affect my RAM speed)?
Ill post the screenshot of the AMD Overdrive soon once I get home.
Again thanks for the input.
