OC help 7850k - Overclock.net - An Overclocking Community
OC help 7850k
post #1 of 22 (permalink) Old 05-05-2014, 08:32 AM - Thread Starter
iceman595's Avatar
Rep: 9 (Unique: 9)
Specs:
IMAG1303.jpg 1760k .jpg file
Asus A88X-Pro
7850k
G.SKILL Trident X Series 16GB (4 x 4GB) 2400
corsair 760i psu
corsair h100i
500gb ssd
APU is @ stock igpu is @ stock
memory went right in @ 2400 shows in cpuz and hcct
need help with overclocking, seems that this apu is way more involved as far as oc'ing goes compared to my 4770k
what is recommended? where should I start?
iceman595 is offline
post #2 of 22 (permalink) Old 05-06-2014, 08:53 AM - Thread Starter
iceman595's Avatar
Rep: 9 (Unique: 9)
i would like to try and get the cpu to 4.3 if I could
also get the igpu up decently high as well
what are the steps I should take?
the cpu is stock
the ram is running @ 2400mhz
post #3 of 22 (permalink) Old 05-06-2014, 10:08 AM
FlailScHLAMP's Avatar
Rep: 141 (Unique: 77)
Unless things have changed in a few months there is very little point on overclocking the CPU if you are going to use the igpu as your main gpu.
cpu cores will down clock themselves to give the igpu head room. (not the same as throttling, tdp + node process limitation)
If this is no longer the case then cool but after the first month and a half after release it was like this.
4.3 is very doable only point to mention is that VRM need to be cooled for anything really beyond that. and it would be wise to cool them regardless.
these chips don't get that hot, an Air cooler or a very small 120mm AIO will suffice. (i've got mine under a h90 and have thermal headroom for days)
also...
rig builder.. it helps
top right hand corner, then add it toy o ur signature in your profile setting..
you mean the a88x pro from asus right? z88x isn't a thing..
FlailScHLAMP is offline
post #4 of 22 (permalink) Old 05-06-2014, 10:26 AM - Thread Starter
iceman595's Avatar
Rep: 9 (Unique: 9)
hmmm welli want to get this thing as good as I can get it without going crazy
ive got a h100i in push right now and that's probably not going to change
also I have latest bios and drivers, all seems to be working fine in gaming/editing/etc
post #5 of 22 (permalink) Old 05-06-2014, 10:34 AM - Thread Starter
iceman595's Avatar
Rep: 9 (Unique: 9)
I also noticed in the bios that there are a lot more options
for example what is the difference between the APU and the cpu frequency? seems like they would be the same
post #6 of 22 (permalink) Old 05-06-2014, 05:47 PM - Thread Starter
iceman595's Avatar
Rep: 9 (Unique: 9)
CPU @ stock
mem 2400
NB freq auto
igpu clock 847
How's this so far?
Unigine Valley Benchmark 1.0
FPS:
10.9
Score:
454
Min FPS:
6.4
Max FPS:
18.3
System
Platform:
Windows 8 (build 9200) 64bit
CPU model:
AMD A10-7850K Radeon R7, 12 Compute Cores 4C+8G (3700MHz) x2
GPU model:
AMD Radeon(TM) R7 Graphics 13.301.1001.0 (2048MB) x1
Settings
Render:
Direct3D11
Mode:
1920x1080 2xAA fullscreen
Preset
Custom
Quality
Ultra
post #7 of 22 (permalink) Old 05-06-2014, 05:56 PM
post #8 of 22 (permalink) Old 05-06-2014, 06:06 PM
soulwrath's Avatar
Rep: 90 (Unique: 75)
I am curious as to what kind of performance you would get with the R9 70 or 265 in xifre while that chip is clocked @ 4.7 (both the APU + GPU OC'd ofcourse)
soulwrath is offline
post #9 of 22 (permalink) Old 05-07-2014, 10:53 AM - Thread Starter
iceman595's Avatar
Rep: 9 (Unique: 9)
I'm eventually going to get a 290x but atm I'm just seeing what I can get out of this. even @ stock I'm getting 80-100fps in LOL on medium so its not really THAT big of a deal.
I don't play many graphically intensive games anyway and I don't mind turning them down a little to make them run well
post #10 of 22 (permalink) Old 05-07-2014, 11:05 AM
Gomi's Avatar
Rep: 78 (Unique: 62)
Regarding the Whole business about the cores downclocking themselves when you are using the iGPU, there is a fix for that - You simply use AmdMsrTweaker v. 1.1 and set the P5 state to whatever you like (Your primarely overclock) - That way you are tricking the APU into "Downclocking" into an overclocked state - It Works, I tested it and can confirm it personally.
Make sure your NB frequency is as high as it will allow you too - Easy way to do this is simply to Work your way up - Start from 2000 then 2100, 2200, 2300, 2400 etc. at some point it will not let you boot at which point you just enter BIOS Again and take the NB frequency that is just below the one that crashed - This one should boot and enter Windows just fine - Do a few GPU benchies and a game or two - Should be bulletproof. I am running a NB Vcore at 1.20.
You have alot of room on your iGPU - Aim for a 1000Mhz at least and Work your way up there.
As for the CPU - Set your Vcore to whatever your cooler can handle - 1.4 Seems to be what most people use and just start adding a multiplier - Boot - Enter Windows - Run 20 minutes of Prime and a 3D benchmark, if this holds just go back to the BIOS and add another multiplier and keep doing that till it crashes - Then back Down one notch and enjoy your OC Kaveri smile.gif
wheee.gifwheee.gifstun.gif Phase Change Owners Club stun.gifwheee.gifwheee.gif
Gomi is offline
