Undervolting/Editing P-States For Piledriver using AMD MrsTweaker (Mini Guide) - Page 2 - Overclock.net - An Overclocking Community
post #11 of 28 (permalink) Old 07-02-2014, 02:08 PM - Thread Starter
Undervolter's Avatar
Rep: 521 (Unique: 256)
Originally Posted by Tivan View Post
http://puu.sh/9U7eq/888d011024.png that's what I got initially on msrTweaker. And PScheck was missing the rows for P1 2 3 but I got em back now! http://puu.sh/9U7gS/86e05934d4.png
So I got my issue solved, actually. All I did in bios was turn core multiplier and fsb back to auto. (And turbo, cause stock settings. but I doubt that matters) (maybe my 240 fsb caused the other states to not get used, considering fsb impacts em all, so that's less potential complications)
Ah, glad you found it. Yes, unfortunately undervolting and overclocking don't go well together. You actually gave me the idea to edit and add that this guide is intended for non overclocked configuration.
Ryzen 2600 - MSI B450 Gaming Plus - 16GB Corsair 3000Mhz C15 - GTX 1650 Super
Undervolter is offline
post #12 of 28 (permalink) Old 07-02-2014, 02:15 PM
Tivan's Avatar
Rep: 133 (Unique: 101)
Hey the tool does offer customization for the full load and half load turbo, so those might actually see some more use with this c;
~ Enjoy life, have a great day ~
Yes, I really am that tivvv3 guy from youtube who makes LoL videos by the same philosophy. Whoa!
Also Unconditional Basic Income advocate.
Tivan is offline
post #13 of 28 (permalink) Old 07-02-2014, 02:24 PM - Thread Starter
Well, the turbo applies when not all cores are fully loaded. However, you can edit the max P-state (non turbo), to an overclocked value. As long as you keep bus at "auto", MAYBE it could work. A benefit with the turbo values, is that you can undervolt those too. 1.42v is too high. Mine does 4Ghz at 1.34v. But i have turbo disabled.
post #14 of 28 (permalink) Old 07-02-2014, 02:40 PM
Tivan's Avatar
P1(msrtweak)/Pb1(pscheck) is the full load turbo (the one that can kick in when all cores are working) which you can't adjust in bios, but I heard there's other software that can fiddle with it too. Also strangely all my states work now even though I went back to manual fsb. Maybe I broke something and fixed it by turning things off and on c;
But yeah I'll stay away from things I can't stresstest for now, my psu over current protection is a bit sensitive on the cpu rail (had this issue over 2 boards and cpus so pretty sure it's that and it's been consistent past certain voltage ever since I got it really, so I don't feel too pressed to replace it c;)
Tivan is offline
post #15 of 28 (permalink) Old 07-02-2014, 03:04 PM - Thread Starter
The 3.8 turbo, works with all cores unparked, but i don't think with all cores fully loaded. The reasoning is this: as long as the TDP is below the limit, then all cores will remain active. BUT, if you stress test them all together, i don't think it will hold...It will probably fall to the previous (non turbo) state, because all cores at 100% is above TDP. i think... So how do you stress that for stability?
post #16 of 28 (permalink) Old 07-02-2014, 03:24 PM
Tivan's Avatar
Well, you'd still have to test it in a regular state first. Or maybe selectively force different turbo/high level states through PScheck, it MIGHT be assumable to be stable with half the cores at your desired turbo and half the cores at max regular state clocking, applied to lower states for stress testing, repeat with cores swapped.
Quick test seems to indicate that PScheck applies mixed states nicely http://puu.sh/9Uesf/4315129ba9.png (both cores of a given module require the same clock though)
Of course it's hard to verify that the theory works c; Nice to have easy access to the full load turbo either way!
edit: also, I have turbo off now but I seem to remember it was possible to actually force turbo states with PScheck when I had turbo enabled. maybe 50% sure on that c;
Tivan is offline
post #17 of 28 (permalink) Old 07-03-2014, 01:02 AM - Thread Starter
RIght. Besides, there is a workaround. You can just overclock for a while, stress test at 3.8, find the voltage and then go back and put it in the bat file.
post #18 of 28 (permalink) Old 03-16-2015, 02:41 PM
Rep: 35 (Unique: 29)
Thanks for the guide, I've been thinking about exactly this for a while now! thumb.gif
BruceB is offline
post #19 of 28 (permalink) Old 03-16-2015, 02:44 PM - Thread Starter
EDIT: Since you dug out the thread, i took the opportunity to update the 1st post with a new indicative string of values for [email protected]
post #20 of 28 (permalink) Old 03-21-2015, 12:20 PM
Turtle Lives Matter
damric's Avatar
Rep: 433 (Unique: 333)
Is this similar to the old PhenomMSRTweaker?
Borg Cube
(15 items)
Ryzen RGB AF
(17 items)
Polaris AF
R5 3600
X470 TAICHI
Gigabyte RX Vega 56 Gaming OC
Ripjaws V 4x8GB
Silicon Power A80 NVMe
EVGA SUPERNOVA G3 750W
TCP-612
2x EVGA FX 120mm Fan
2x Cooler Master MasterFan Pro 140 Air Flow
HAF XB
Operating System
10-64 PRO
Samsung 4K 60Hz
Keyboard
Logitech G105
Mouse
Devastator II
Audio
Logitech Z623
Ryzen 5 1600 (12nm)
X470 Pro Carbon
Vega 64
OLOy WarHawk RGB 4x8GB
SUPERNOVA G3
Wraith Prism
Metallic Gear Skiron 120mm x4
Metallic Gear Skiron 140mm x2
Phankteks Eclipse P400A
Operating System
10 Pro
Samsung 58" UHD
V7 L238E-2N
Keyboard
Rosewill NEON K85 RGB
Mouse
Logitech M570
Audio
Vintage Sony
R5 1600 (12nm)
B450 Steel Legend
XFX RX 570
OLOy WarHawk 2x8GB
Silicon Power A80
Rosewill CAPSTONE
Wraith Prism
Cooler Master Jet Flow 120mm x2
Cougar MX330-G
Operating System
10 Pro
ASUS 1080p 23"
Audio
Xonar SE
Audio
Logitech
damric is offline
