Undervolting/Editing P-States For Piledriver using AMD MrsTweaker (Mini Guide) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 28 (permalink) Old 03-21-2015, 01:04 PM - Thread Starter
Undervolter's Avatar
Rep: 521 (Unique: 256)
Originally Posted by damric View Post
Is this similar to the old PhenomMSRTweaker?
Yes, exactly. I was using K10Stat with AM3s and i was desperate to find a solution for AM3+. The downside is that it doesn't have a GUI. But it works well, at least in Win7. From testimonies in this thread, Win8 becomes more problematic, if i remember from inability to run PSCheck. I guess if MsrTweaker otherwise works in Win8, a solution would be to go to BIOS and underclock manually to all the P-State frequencies and manually stress test each one once back in Windows.
But in Win7 works like a charm.
Ryzen 2600 - MSI B450 Gaming Plus - 16GB Corsair 3000Mhz C15 - GTX 1650 Super
Undervolter is offline
post #22 of 28 (permalink) Old 05-02-2015, 04:54 AM
Rep: 0
I can't seem getting PSCheck 3.4.1 on a a win 7 home premium install proper functioning. I've downloaded the tool, so when i did install this tool and wil so on loaded the program, theres no sign of activity. It doesn't start.
Do you guys know about this issue?
Borellie is offline
post #23 of 28 (permalink) Old 05-02-2015, 07:19 AM
xKrNMBoYx's Avatar
Rep: 19 (Unique: 15)
Since there is nothing to do on my OCed 8350 I might try this to undervolt any of the lower pstate frequencies. May work or not as CPUs OCed.
xKrNMBoYx is offline
post #24 of 28 (permalink) Old 08-17-2015, 08:53 AM
MechanimaL's Avatar
Rep: 0
hey, has anyone had issues? i don't get my pc to use P2 correctly. i entered 22x with 1.425 vcore, but it won't use the correct multiplicator or only uses lower states.
but the voltage of p2.
ga 990 ud3 (4.0 f3)
fx 8350
win7
turbo = off
i tried with apm on / off
and stock values for freq+multi
win energy scheme is "balanced"
also i did not get pschecker to run on a state definied via MSR Tweaker, excecpt boost states, but i dont want to use them, or i need further measures to ensure its working like overclocked P2.
MechanimaL is offline
post #25 of 28 (permalink) Old 05-17-2018, 08:06 PM
nick01's Avatar
Rep: 0
Hi everyone ,
on a HP 15-ba061dx laptop (A12 9700p with R7) with win10 on it ,when i run the tool i get the following :
"AmdMsrTweaker v2.0
.:. General
AMD family 0x15, model 0x65 CPU, 4 cores
Default reference clock: 100 MHz
Available multipliers: 1 .. 63
Available voltage IDs: 0 .. 1.55 (0.0125 steps)
.:. Turbo
enabled
unlocked
Max multiplier: 36
.:. P-states
8 of 8 enabled (P0 .. P7)
Turbo P-states: P0 P1 P2
P0: 36x at 1.2375V
NorthBridge in NB_P0
P1: 30x at 0.9V
P2: 27x at 0.725V
P3: 25x at 0.6V
P4: 21x at 0.4V
P5: 16x at 0.225V
P6: 13x at 0.15V
NorthBridge in NB_P1
P7: 8x at 0.05V
* PsiVidEn = 0, PsiVid = 1.55 V
NB_P0: 11x at 0.325V [NBPStateHi] [NBPStateLo]
Memory in M0
NB_P1: 10x at 0.275V
Memory in M0
NB_P2: 10x at 0.275V
Memory in M0
NB_P3: 7x at 0.125V
Memory in M1
* NbPstateDis = 0, NbPstateGnbSlowDis = 0, StartupNbPstate = 0
* NbPsi0VidEn = 0, NbPsi0Vid = 1.55 V
* NBPStateHiCPU = 0, NBPStateLoCPU = 0
* NBPStateHiGPU = 0, NBPStateLoGPU = 0
M0: 933.3 MHz
M1: 666.6 MHz
* MemClkFreqVal(M0) = 1, FastMstateDis(M1) = 0
GPU_P0: StateValid = 0, LclkDivider = 0, VID = 1.55 V
GPU_P1: StateValid = 0, LclkDivider = 0, VID = 1.55 V
GPU_P2: StateValid = 0, LclkDivider = 0, VID = 1.55 V
GPU_P3: StateValid = 0, LclkDivider = 0, VID = 1.55 V
GPU_P4: StateValid = 0, LclkDivider = 0, VID = 1.55 V
GPU_P5: StateValid = 0, LclkDivider = 0, VID = 1.55 V
GPU_P6: StateValid = 0, LclkDivider = 0, VID = 1.55 V
GPU_P7: StateValid = 0, LclkDivider = 0, VID = 1.55 V
* GpuEnabled = 1, SwGfxDis = 0, ForceIntGfxDisable = 0
* LclkDpmEn = 0, VoltageChgEn = 0, LclkDpmBootState = 0
Press any key to exit..."
Would just like to know if it's possible to tweak anything on my rig and how much ...Anyone?
Tnx in advance
nick01 is offline
post #26 of 28 (permalink) Old 06-16-2018, 02:36 PM
Linux Lobbyist
ocyt's Avatar
Rep: 2 (Unique: 2)
can this work alongside CCC (catalyst control centre) cpu power profiles?
"i live in a swamp, i put up signs, i'm a terrifying ogre, WHAT DO I HAVE TO DO TO GET A LITTLE BIT OF PRIVACY"
ocyt is offline
post #27 of 28 (permalink) Old 08-29-2018, 08:03 AM
Linux Lobbyist
Rep: 0
New L|nks
openload.co/f/OdjywBmURh8/AmdMsrTweaker_1.1.zip
depositfiles.org/files/ja7142zpd
www.share-online.biz/dl/RDFF78EP65X
uploaded.net/file/noigd9th
turbobit.net/vn7mld3t1fse.html
www93.zippyshare.com/v/dBA2PxdG/file.html
rapidgator.net/file/bb2b6ad02a4b671136d150586802e9d7/AmdMsrTweaker_1.1.zip.html
www.solidfiles.com/v/2ARVmVzw7md5r
http://www.ortofiles.com/l9ug089noa9...weaker_1.1.zip
MD-5 62DE4F1D2CAF26FC83E28F5B74AA14E2
SHA-1 2F37CCA5F53F82CBEBD98AE3C0854CA59CC4006C
SHA-256 5375599FFE02A53FA9FF83A58AFCE5DF40A9469D0457481BE0 22E3D47792A88A
eurek is offline
post #28 of 28 (permalink) Old 09-01-2018, 06:06 AM
ssateneth's Avatar
Rep: 44 (Unique: 39)
I know these look shady as all hell, but I checked the attachment (I didnt click any of the links above). The attached zip is legit, has the same files and checksums as my amd a10-5750m based laptop's amdmsrtweaker
x86 .exe CRC32 D03EA72F
x86 .dll CRC32 616F5119
x86 .sys CRC32 9E43AFF2
x64 .exe CRC32 ADA2E3AB
x64 .dll CRC32 561A1B49
x64 .sys CRC32 6B0323EB
Intel Core i9-9900k (Silicon Lottery 5.1GHz @ 5.3GHz 1.36 VCore)
ASUS ROG MAXIMUS XI APEX
G.SKILL F4-4000C19D-32GTZSW (2x16GiB 4000MHz 19-19-19-39 2T, tuned to 4133MHz 14-17-17-31 2T)
EVGA NVIDIA GeForce GTX 1080 Ti FTW3
Seasonic PRIME 1300W 80+ Platinum
ssateneth is offline
