Undervolting/Editing P-States For Piledriver using AMD MrsTweaker (Mini Guide) - Overclock.net - An Overclocking Community
post #1 of 28 (permalink) Old 07-02-2014, 11:36 AM - Thread Starter
Undervolter's Avatar
Rep: 516 (Unique: 254)
I stumbled upon this wonderful utility, an equivalent of K10Stat (which was for K10 architecture) and since i couldn't find an easily understandable guide and googled for long to solve all my problems, i decided to make a quick, hopefully easy to comprehend guide. This guide works for Win7 x64. It probably works for Win8 too. If it doesn't, too bad, you wanted tiles... biggrin.gif
The guide should work for NON overclocked configurations. So BIOS values must be at defaults. it MAY or MAY NOT work for overclocked configurations (not tested).
Utilities needed:
PSCheck 3.4.1 (AMD's tool):
http://www.filedropper.com/pst341
or http://s000.tinyupload.com/index.php?file_id=35414757528187612550
AMD MsrTweaker 1.1 (it's CLI, no GUI)
http://www.brightsideofnews.com/2013/04/09/amdmsrtweaker-v11-released2c-trinity-support-inside/ (author's site).
1) Install PSCheck.
2) Unzip AMDMsrTweaker to a folder with the name "AmdMsrTweaker" (preferably, you can use other name, but this is a convention name that will go on for this post). For 64 bit Windows, put the contents of x64 folder in the "AmdMsrTweaker" folder (delete the empty x64 folder).
3) Run the executable of AMDMsrTweaker and take a screenshot of it, save it. These are the default values, you 'd better keep them in case something goes wrong and as guidelines.
Example, this is default from my FX-6300 (except for P2 which i had already undervolted in BIOS):
4) Position the folder "AmdMsrTweaker" in C:
5) Create on your desktop an empty .txt file. Rename it as "AMDMsrTweaker". Open it. You need to input the P-States and voltages that you want to change. Those that you don't want to change, you can leave aside. You can also disable APM or Turbo, using 0 or 1, but it's better to keep things simple and leave that part to the BIOS. Inside the txt you must write as example:
C:\AmdMsrTweaker\AmdMsrTweaker.exe [email protected] [email protected] [email protected] [email protected]
The first part (up to .exe) is the path of your executable. Then you input the desired [email protected] voltage. In my case, i wanted to change only 4 P-states. The above settings are IBT-AVX stable for my FX6300, but each motherboard and chip is different. They aren't fully optimized, they can probably go lower, but it was a quick run i did last night and i like round numbers. Ideally you 'd want to stress test each P-State with Prime95, but since i was in a haste, i went away with IBT AVX. Besides, since these are intermediate P-States, they don't get too much stressed in real life before going to the highest P-State (that i didn't change here, since i have it undervolted through BIOS - see P2 in the previous screenshot). For someone who wants to undervolt the highest P-State, he must also input P2 values. P1 and P0 are turbo values, if you have turbo disabled in BIOS, they shouldn't concern you at all. In my case, i have turbo disabled in BIOS. However, one could edit these states too and undervolt them as well. There is though, ONE difference. If someone wants to edit and use the turbo-states, there are some conditions:
- APM MUST be enabled.
- The highest turbo value in BIOS must be the same as the one edited in the batch file.
- The voltage set in BIOS as manual, must be the same value that the highest turbo state needs to use.
In my tested configuration for example, the full string for turbo enabled, but reduced to 4Ghz, is:
C:\AmdMsrTweaker\AmdMsrTweaker.exe [email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected]
So in BIOS, i have: APM enabled, Turbo set manually to 4Ghz (multi 20), manual vcore 1.2875v. A bad conseguence though of having to enable APM, is that in very high stress, as in Prime95, your CPU at stock, will be mini-throttling. This is because Prime95 is very hard on the CPU and APM doesn't like it. So you will likely see 3.5->3->3.5 oscillation. With more "normal" programs, you shouldn't see that.
Once you 're done edited your P-States, save the values in the .txt and rename the .txt file in .bat. Move the bat to the folder where your executable of AMDMrsTweaker is. Run the batch file once as administrator to start stress testing.
Now, how to stress test each P-State. Open PSCheck and CPU-Z for verification. PSCheck has some blue arrows on top. These move between P-States and lock them while there. Once you locked a P-State, you can run stress test. Example stress testing [email protected]:
In case you want to change a value, go back to the bat file, rename its extension to .txt, edit, rename in .bat and repeat testing.
6) Go to start. Type "task scheduler". Fire it up. "Create New Task". Under "General" Tab: Name "AMD Mrs Tweaker". Tick "Run with highest Priviledges". Click "Change User or Group", type "SYSTEM" (without the ""). This is important, in order for the batch file to run hidden at boot, otherwise you see a command line window at every boot. It took me a while to find this solution.
Under "Triggers" : Begin the task: "At Log On". Make sure the "enabled box" is ticked.
Under "Actions" : Action: Start a Program. In the program/script field: C:\AmdMsrTweaker\AMDMsrTweaker.bat
Under "Conditions": uncheck every box.
Under Settings: Tick "Allow to be run on Demand", "Run task as soon as possible..."If the running task does not end as requested". UNTICK all the rest.
Now, make sure your task is "enabled" in the task scheduler list (shows as "ready") and reboot.
Hopefully, you should now have the batch file running in background at every boot. To verify use CPU-Z, or run the executable of AMDMsrTweaker or PSCheck.
At the end, you have something similar (see PS Check):
I hope it helps. It took me a while to figure everything out, since the original threads of the author that i found googling are a bit chaotic, but for reference and kudos, are here:
http://www.xtremesystems.org/forums/showthread.php?285742-AmdMsrTweaker-New-Versions
http://www.xtremesystems.org/forums/showthread.php?277724-New-tool-AmdMsrTweaker
DISCLAIMER : Please, if you don't understand anything in this topic, don't try it. Also, please understand that every motherboard/CPU is different. I am not responsible if you have instability problems. I posted my values only as example. This is why i can't stress enough, that you must do your own stress tests for EVERY P-State you want to change. The values above, work on my FX6300, but are NOT fully optimized for maximum undervolting. I used quick guesstimates based on my experience with K10Stat and i decided to keep them until i have more time, since they all worked on the first try.
A very big personal thanks to the program's author. I was almost suffering from the lack of a K10Stat equivalent.
OF COURSE, the program allows also to change the frequencies of the P-States to one's desire, by changing the multiplier. For example if instead of P6=7 , ones puts P6=6, the frequency will be 1200Mhz.
Good luck!
UPDATE
Here's a string line for [email protected] (with Cool N Quite enabled. In Giga UD3P, APM is OFF, Turbo is auto): [email protected] [email protected] [email protected] [email protected] [email protected]
Undervolter is offline
post #2 of 28 (permalink) Old 07-02-2014, 12:13 PM - Thread Starter
TO BACKUP YOUR SETTINGS (in case you want to format and reinstall and you 're bored to do this all over again):
1) Save the folder with the bat file included as is.
2) Go to task scheduler, right click on the task, click export. It will export an xml file, that after format you can import and the task will be ready to go, as long as you put the folder with the same name in the same place and the bat inside ready.
post #3 of 28 (permalink) Old 07-02-2014, 12:46 PM
Tivan's Avatar
Rep: 133 (Unique: 101)
First off, thanks for the guide!
Now not sure what I did but PSCheck only has Pb0 Pb1 P0 and P4 for me, but it's been like that beforehand already. Amd Msr Tweaker has all the states though.
edit: also word of warning regarding stability after stress testing successfully, keep in mind that any offset voltage tweaks from bios get applied on top of the p state voltage changes (at least on my asus). So if you go back to bios to fiddle with those, you'll have to think of your custom states.
~ Enjoy life, have a great day ~
Yes, I really am that tivvv3 guy from youtube who makes LoL videos by the same philosophy. Whoa!
Also Unconditional Basic Income advocate.
Tivan is offline
post #4 of 28 (permalink) Old 07-02-2014, 12:50 PM - Thread Starter
This is odd... Do you have Cool N Quiet enabled in BIOS? Also power profile "balanced" in Windows? The problem is, you can't stress test if PSCheck doesn't see the P-States. Cause if it can't see them, it can't lock them... I don't know why it doesn't see them. Your 8core should have probably similar P-states to my FX6300...
post #5 of 28 (permalink) Old 07-02-2014, 01:08 PM
MrPerforations's Avatar
Rep: 78 (Unique: 57)
hello,
is apm on or not please? this might be the problem as in its off or one of the other setting?
AMD Ryzen™ 1700 3.75ghz
MSI™ X370 Gaming Pro Carbon™
MSI™ Radeon™ Vega 56 Air Boost OC
Avexir™ Blitz™ 3200 CL16 @ 3200
Seagate™ 2TB Barracuda™
Optical Drive
ASUS™ DRW-24D5MT
EVGA™ Supernova™ 1000 G2
XSPC™ Raystorm™ 750 2x EX360 Radiators
Coolermaster™ Cosmos Pure Black
Operating System
Windows™ 10 x64
Electriq™ VM280UHD 4k
Keyboard
RII™ K66 Red Switch mechanical keyboard
Mouse
EasySMX™ Red Gaming mouse
Audio
Creative labs™ sb x-fi titanium
Audio
Logitech™ 540x 5.1
MrPerforations is offline
post #6 of 28 (permalink) Old 07-02-2014, 01:12 PM
Tivan's Avatar
Windows doesn't actually use any states but P0 and P4 for me, so that's that. I have it on Balanced and Cool N Quiet enabled. Maybe it's something I did with the registry sometime, though that was more about core parking and I presumably re-rolled that, oh well.
Tivan is offline
post #7 of 28 (permalink) Old 07-02-2014, 01:18 PM - Thread Starter
Ah, then it could be a problem in your Windows installation. Anyway, just for the history, i have APM off, turbo off, Cool N Quiet, C1, C6 enabled. Unfortunately, if you 've done something to your registry or something to your core behaviour, i don't know what to tell you. It's not normal to use only 2 P-states...
post #8 of 28 (permalink) Old 07-02-2014, 01:39 PM
Tivan's Avatar
One curious thing though, on initial readout, P3 through P5 were all identical to my P2, with P6 being the low power state and P 0/1 being boost states (in msr tweaker). I wonder what other people can report on this.
Tivan is offline
post #9 of 28 (permalink) Old 07-02-2014, 01:41 PM - Thread Starter
One curious thing though, on initial readout, P3 through P5 were all identical to my P2, with P6 being the low power state and P 0/1 being boost states. (msr tweaker)
Can you post a screenshot from msrtweaker and another from PSCheck? I 'd like to see them, it's easier to understand.
post #10 of 28 (permalink) Old 07-02-2014, 02:04 PM
Tivan's Avatar
http://puu.sh/9U7eq/888d011024.png that's what I got initially on msrTweaker. And PScheck was missing the rows for P1 2 3 but I got em back now! http://puu.sh/9U7gS/86e05934d4.png
So I got my issue solved, actually. All I did in bios was turn core multiplier and fsb back to auto. (And turbo, cause stock settings. but I doubt that matters) (maybe my 240 fsb caused the other states to not get used, considering fsb impacts em all, so that's less potential complications)
Tivan is offline
