Are my temps all right for FX 8350 and Corsair H80i cooler? - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 07-04-2014, 09:56 AM - Thread Starter
DarkRadeon7000's Avatar
Rep: 5 (Unique: 5)
I just installed a Corsair H80i cooler for my fx 8350 and my idle temps are around 30-34 and while playing BF3 go to around 51 at stock clocks.The room temperature is 29 and I am using Quiet Mode in Corsair Link.Are these temps normal?Thanks in advance
DarkRadeon7000 is offline
post #2 of 4 (permalink) Old 07-04-2014, 10:15 AM
Razzaa's Avatar
Rep: 25 (Unique: 20)
Sounds normal to me. Quiet mode isnt going to do alot on the cooler. I would run it in balanced mode if you are worried about temps.
Razzaa is offline
post #3 of 4 (permalink) Old 07-04-2014, 10:32 AM
ktony's Avatar
Rep: 0
That seems reasonable, given the ambient + the Quiet setting. My 8350 is running at 47 C with the room at 24 C. This is running 100% with Prime 95, on an H100i cooler. The fans are running at about 1530 RPM, controlled by the BIOS. I gave up on Link software.
Note that this was with my 2 GPUs at idle. They are normally running flat out doing Prime-related factoring work. With a single GTX 580 running at 98% usage, the CPU goes up to 50-51 C, and the radiator fans rev up to 1720-1800 RPM.
ktony is offline
post #4 of 4 (permalink) Old 07-05-2014, 05:02 PM
new to OCN?
PontiacGTX's Avatar
Rep: 1537 (Unique: 925)
Try different programs to test since the cpu temperature is based off a formula with the socket temp
PontiacGTX is offline
