Ryzen Essential Info with link to owners info DB - Page 2 - Overclock.net - An Overclocking Community
post #11 of 359 (permalink) Old 03-11-2017, 07:24 AM - Thread Starter
Meddling user
gupsterg's Avatar
Rep: 786 (Unique: 360)
@Undervolter
Cheers, +rep mate thumb.gif .
@Mr Splash
Welcome aboard mate thumb.gif .
I received my C6H yesterday wheee.gif . The AM4 bracket was stuck on (front clips removed) redface.gif . After verification from Elmor that I wouldn't damage the board by using a hairdryer to warm the plate up. I can confirm it will remove very easily using that method, just take you time getting it warm (didn't go for toasty tongue.gif ), in my case it left no residue of the adhesive on the PCB either smile.gif .
So I carefully kitted out board for launch aGMXnd I had failure to launch frown.gif , the information is in this post. So today grabbed some CMK8GX4M2A2400C14 and now my Ryzen rig has risen biggrin.gif .
Currently installing Win 7 Pro, the integrated USB drivers have worked as I had functioning mouse wink.gif . I'm also going for a UEFI install of Win 7 Pro, using similar method to my thread on M7R. After verification will post screenies smile.gif .
gupsterg is offline
post #12 of 359 (permalink) Old 03-11-2017, 08:05 AM
majestynl's Avatar
Rep: 98 (Unique: 48)
Great Thread gupsterg !!
+rep
majestynl is offline
post #13 of 359 (permalink) Old 03-11-2017, 08:47 AM - Thread Starter
Meddling user
gupsterg's Avatar
Welcome smile.gif , no worries smile.gif .
Got to do some more to OP. My spare time yesterday and some today has been used up by the RAM fault issue and getting OS on/setup.
Anyone installing Win 7 this is how it went on my C6H:-
i) Win 7 Pro x64 ISO, this did not have "to date" updates integrated but only the USB drivers.
ii) After OS install, I installed the AM4 chipset drivers from AMD site.
iii) WiFi card's driver, GC-WB867D-I, I use Intel driver from Intel site and not Gigabyte.
vi) Crimson driver for Fury X, then ICC profile for monitor.
And no "unknown" devices in device manager biggrin.gif .
I have onboard LAN disabled as don't use it, that does require driver. Onboard sound was picked up, but that will be disabled later as use the GPU's audio output over DP to monitor, then plug my headphones in to it.
So far very smooth install of OS and a few less drivers than my i5/Z97 setup smile.gif . Like how the AMD AM4 driver had SMBus, etc as "all in one" package smile.gif . Keeping "bloatware" at bay so far wink.gif .
gupsterg is offline
post #14 of 359 (permalink) Old 03-11-2017, 09:04 AM
majestynl's Avatar
gupsterg,
After a successful oc on 4000mhz im testing lowering the voltage and speeds when IDLE on ryzen. So far no success.With editing Pstates i get lower voltage on idle, that's great but the speed is messed up. It doesn't speed up to 4000mhz.
See more info and screenshots @ : https://www.overclock.net/t/1624603/rog-crosshair-vi-overclocking-thread/970#post_25912710
Your section on the Pstates probably need to be updated with a bit more info. Will help you with that after successful tests.
post #15 of 359 (permalink) Old 03-11-2017, 05:47 PM
Always Learning
finalheaven's Avatar
Rep: 76 (Unique: 39)
Great thread, will submit info once I finalize specs.
finalheaven is offline
post #16 of 359 (permalink) Old 03-11-2017, 08:35 PM
RWGTROLL's Avatar
Rep: 10 (Unique: 8)
Ryzen 7 1700x - 3.8ghz @ 1.352v Max temp 74c
Coller H80i
MSI B350 Tomahawk
G.skill 3200mhz @ 2666 16 18 18 38 1T
Validation - http://valid.x86.fr/mkepu3
Made in China
YD170XBCM88AE
UA 1707SUT
RWGTROLL is offline
post #17 of 359 (permalink) Old 03-11-2017, 10:19 PM - Thread Starter
Meddling user
gupsterg's Avatar
@majestynl
I found at stock UEFI and balanced windows power profile I was hitting only 3.2GHz (idle 1.55GHz), if I changed power plan to performance, one core would hit 3.7GHz and idle was 3.3GHz. I was aiming to have an OC the same way as on my i5/Z97, ie down clocking/volting on idle and all boosting the same on load.
Playing with the settings Elmor highlighted and using balanced windows power profile has given me 1.55GHz idle and all core max at 3.7GHz @ 1.1875V in UEFI (not seeing 1.35V spike in UEFI or OS biggrin.gif ).
So here is my settings:-
Warning: Spoiler! (Click to show)
ExT 1 (defaults kept)
ExT 2 (defaults kept)
Digi + (VRM Spread spectrum only changed)
CBS 1 (Global C State Control set to Enabled)
CBS 2
Quick stability test on RB stress mode (had earlier tested profiles from 3.3GHz to 3.6GHz)
3.8GHz @ 1.187V BSOD under RB redface.gif , 3.75GHz @ 1.187V WHEA error but no BSOD. Both of these down volt/clock so CPU is not going into OC Mode on my R7 1700 smile.gif .
Plan to later today do longer testing of this setup.
@finalheaven
No worries smile.gif .
@RWGTROLL
Cheers will update DB ASAP smile.gif .
gupsterg is offline
post #18 of 359 (permalink) Old 03-12-2017, 06:39 AM - Thread Starter
Meddling user
gupsterg's Avatar
gupsterg is offline
post #19 of 359 (permalink) Old 03-12-2017, 07:28 AM
Sgt Bilko's Avatar
Rep: 354 (Unique: 199)
Originally Posted by gupsterg View Post
@Sgt Bilko
OP FAQ Windows 7 updated with video of creating ISO with USB driver. Post 13 has pretty much what I did for my OS after install.
AMD Community Manager for ANZ
Sgt Bilko is offline
post #20 of 359 (permalink) Old 03-12-2017, 07:52 AM
majestynl's Avatar
@@gupsterg
I see, thanks for sharing your results. Mine is doing reallt strange. I have a 1800x, so i dont see where he gets the 3200mhz from.
P states are in hex and calculated so they need to hit 4000Mhz! But is doesn't...
Im thinking its something with windows 10..
Going to test today, will start from scratch again.. update will follow!
