Ryzen Essential Info with link to owners info DB - Page 35 - Overclock.net - An Overclocking Community
post #341 of 359 (permalink) Old 08-01-2017, 04:05 AM
zGunBLADEz's Avatar
Rep: 103 (Unique: 76)
i got my 3600 kit i cant boot it at the current speed yet.
I manage so far 3333 14/14/14 tho im playing with procodt and touching this have gave me some results.. Leaving this on auto the pc wont turn and it will default to 2133..
Put 60ohms it boots just fine @ 3333/14/14/14 but it will give me some errors on hci... Going any higher than 60 it default to 2133.
Now im lowering it below 60 to see if i can iron out the hci errors.. want a hci errror free 200% for defaults then see what happens after that.
This kit 3600 was made on May 2017 and the 3200 m-die hynix one was made mar 2017.
Hynix one work fine @ 3200 16/16/16/32/1T from 16/18/18/38/1T i cant touch nothing on her lol
zGunBLADEz is offline
post #342 of 359 (permalink) Old 08-07-2017, 04:44 AM
Martin778's Avatar
Rep: 16 (Unique: 16)
So looking at the previous posts my 1800X is actually better than average as it does 3925MHz <1.4V and all those 4.0GHz samples are myths.
Threadripper 3960X PBO | Aorus TRX40 Xtreme | Enermax Liqtech II 360 TR4 + EK Clear flush + 3x Noctua A12x25 | 4x8GB G.Skill TridentZ Royal Gold @ 3733 CL16 | EVGA Kingpin 2080Ti @ 2100MHz + Noctua A12-25 | 4x1TB 970 PRO raid0 | Corsair MP600 2TB | Seasonic Prime Platinum 1300W | In Win D-Frame 2.0 Gold | ASUS PG349Q
Martin778 is offline
post #343 of 359 (permalink) Old 08-07-2017, 05:08 AM
Scotty99's Avatar
Rep: 72 (Unique: 56)
Im curious what average is for a ryzen 7. My 1700 will do 3.9 with 1.36 but it just wont do 4.0 without getting hardware errors, even at over 1.45v.
Gaming pc
(9 items)
HTPC
(8 items)
Intel Core i7 8700k
Rog Strix z370-F
Nvidia Founders Edition RTX 2060
Gskill Trident-z RGB 3000
Samsung 960 evo 1tb
EVGA 750 G3
NZXT Kraken x62
NZXT S340 elite
Dell S2417DG
AMD Athlon 5350
Asrock AM1B-ITX
4GB crucial 1600mhz
OCZ Agility 3 60gb
Linkworld 920-01
Vizio Smartcast E55
Keyboard
Logitech K400
Audio
Vizio 3.1 Soundbar
Scotty99 is offline
post #344 of 359 (permalink) Old 08-07-2017, 05:52 AM
MynRich's Avatar
Rep: 2 (Unique: 2)
You're joking, I assume? My 1700 does 4GHz stable at 1.3875v manual vcore in BIOS. Don't get me wrong, I'm not ignorant to the fact it was total luck of the silicone draw. I've even gotten my system to POST and boot into windows at that core OC and 3600Mhz ddr4 16-16-16-36 1.4v... not much I do seems to keep that ddr4 freq stable in HCI MemTest for more than 10 seconds lol
MynRich is offline
post #345 of 359 (permalink) Old 08-07-2017, 06:36 AM
zGunBLADEz's Avatar
I do 4ghz at 1.375v llc1 which a heavy load will net 1.4v with the 1800x my 1700 in the other hand was 38.25x at same voltage and 4ghz @ 1.530v for suicide benchs.
I have seen better ones out there i mean if they are really stable at what they claiming. We dont know as 10min run on prime is not an initiative of stability.
post #346 of 359 (permalink) Old 08-10-2017, 05:01 AM - Thread Starter
Meddling user
gupsterg's Avatar
Rep: 786 (Unique: 360)
I have come to the conclusion that on the 1800X it is "optimal" to use at stock.
Once or twice I have posted in the C6H thread that I felt on the R7 1700 3.7GHz all cores OC was pretty sweet for voltage/cooling requirement and performance. At some point I would probably assess for my uses if 3.7GHz AC OC lost me anything against the 3.8GHz AC OC. Now on the R7 1700 stock AC is 3.2GHz, single core it will go max to 3.75GHz. So 3.7/3.8GHz OC got me a real nice boost over stock setup and I matched/beat max XFR single core.
Now on the 1800X gunning for 3.9GHz really pulls so much power from the wall when running some stress tests. I have noted worst case constant 300-350W for total rig inc screen when only CPU is under load. 3.9GHz needs VID: 1.425V on my sample, LLC: [Auto], cooling requirement under stress tests is also really at the edge for my air cooler IMO. I have noted with ambient temperature changes, that like stress tests will increase the max CPU temp, as the cooling really can't keep up with ambient air temp change. So basically WC is the route to improve that.
Now if I run it at stock I have 3.7GHz ACB at 1.25V MAX, which is similar to what R7 1700 use when OC'd to that level. It is so easy to cool, power usage is substantially lowered. I saw max ~250W in similar case tests as the 3.9GHz OC. Also running at stock the CPU does boost to 4.1GHz and at times between 3.7GHz to 3.9GHz on multiple cores (will be checking in more apps closely).
So am I just going for RAM OC/tweak only now on 1800X. I feel I should keep this vs the R7 1700 to run daily, as it's the best of both world.
First up some HCI Memtest.
I had picked arbitrary SOC: 1.05V and VDIMM: 1.375V as this seemed right for 3333MHz Fast on several of the CPUs I have used. I went for ProcODT: 53.3 ohms and VDDP: 900mV, with PLL/SB manually set as 1.8V/1.05V.
AIDA64 with 3333MHz Fast I have lost nothing.
Cinebench is also where I'd expect to be.
Next IBT AVX custom 13312MB GFlops, is ~180 at stock with 3333MHz Fast, 3.8/3333 Fast is ~185 and 3.9 / 3466 Stilt is ~188.
Power usage from the wall has dropped by upto 30%, temps are well even for when ambient raises, the quietness of the rig was astounding. Now one core did go to 4.05GHz, I will check log how long this was and when, but I believe for majority of the test CPU did not boost above 3.7GHz.
Now this same profile failed Y-Cruncher within 30min.
I noted a core went to 3.975GHz, after repeat testing it become clear that Y-Cruncher was a better test than IBT AVX custom 13312MB when at stock set up but RAM OC'd. As some cores were boosting above stock ACB of 3.7GHz which in IBT AVX they will not due to power draw, etc.
I am currently at ~10.5hrs of pass on 3333MHz Fast on Y-Cruncher, again power draw is lower, cores have been boosting up to 4.1GHz at times. SOC bumped to 1.1V, I felt this amount was needed as at stock cores will be boosting to 4.1GHz in other uses. ProcODT I went for 60ohms and also increased CAD bus from stock [Auto] of 24/24/24/24 to 30/30/30/30. I also bumped VDIMM to 1.39V again like SOC I have seen a tendency of this needing a bump with increased CPU speed and CPU oriented tests.
HWINFO is at a polling rate of 1000ms, AFAIK the CPU can change frequencies at 2ms, so logs will not really show the truest 'picture'.
All in all I reckon if OC'ing then 1700/1700X are best, as you have highest/higher chance of beating the maximum single core frequency at stock. On 1800X I reckon stock is best with RAM OC/tweak. I have done some wPrime and SuperPi, stock 1800X is so close to 3.9/3466MHz OC but the ease of setup for stock 1800X 3333MHz Fast is way easier and efficient on power usage, cooling requirement, temps, etc.
gupsterg is offline
post #347 of 359 (permalink) Old 08-10-2017, 05:27 AM
Scotty99's Avatar
1800x is the chip for people that dont know what a bios is, the real takeaway here tho is why does AMD not let us overclock per core like intel does?
Gaming pc
(9 items)
HTPC
(8 items)
Intel Core i7 8700k
Rog Strix z370-F
Samsung 960 evo 1tb
EVGA 750 G3
NZXT Kraken x62
NZXT S340 elite
Dell S2417DG
AMD Athlon 5350
Asrock AM1B-ITX
4GB crucial 1600mhz
OCZ Agility 3 60gb
Linkworld 920-01
Vizio Smartcast E55
Keyboard
Logitech K400
Audio
Vizio 3.1 Soundbar
Scotty99 is offline
post #348 of 359 (permalink) Old 08-10-2017, 01:08 PM
Martin778's Avatar
I'm perfectly serious, if it won't do 2-4h+ P95 then it's not stable but benchable, point.
post #349 of 359 (permalink) Old 08-10-2017, 09:14 PM
MynRich's Avatar
Rep: 2 (Unique: 2)
Which my 1700 OC does. Not at anything higher than 3200MHz on DDR4. CPU and my 1080Ti are custom loop cooled. Never see higher than 65c on my 4GHz 1700. That's with the 1080Ti OC'd too. My assumption of a joke was at expected OC's of 4GHz being a myth, as mine does fine.
MynRich is offline
post #350 of 359 (permalink) Old 08-10-2017, 09:23 PM
MynRich's Avatar
Rep: 2 (Unique: 2)
To clarify, which version of P95? I haven't tried the later versions known to be a "power virus", but I can definitely conduct that if I know which p95 version you're referring to? I tested with 29.1...
MynRich is offline
