2700x overclocking help - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 12-23-2018, 11:21 AM - Thread Starter
cgi2099's Avatar
Rep: 0
Hardware: 2700x, crosshair vii, 32gb ram, nvme SSD Samsung, 1060 ftw, 750 g3 psu, a240g water cooling (x2 240 rads)
Hey guys I am new to overclocking but right now my settings are 100blck, 41 CPU ratio, vcore 1.3v, soc 1.025v. Everything is very stable and I am getting 28c idle, 50-55 gaming and 60-65 rendering/aida64
I have been reading and I see a lot of people saying I'll get better performance if I let xfr2 do the work.
My question is how do I set this up properly on the CH7, I have followed a few how toos but the processor just shows 3.7ghz @1.4v(to high) in the motherboard specs? I just don't know what options to select on and off for my board specifically. Ive also read to do and offset voltage to lowers temps but get a higher boost, where is this option??
Any help would be awesome!
Thanks everyone
cgi2099 is offline
post #2 of 8 (permalink) Old 12-23-2018, 11:29 AM
Should be thinking more like 4.3ghz. They run pretty good around that Level. Was thinking about going back to Airrrr...Something bigger than the Box Cooler the Spire could cool that better EZ....like I can pass cb at 1.4125v...but I think it's board pass that keeps freezing past that. Think I got a bad binned chip or just average? someone was at 4.6 with the 2600x they said....
Jspinks020 is offline
post #3 of 8 (permalink) Old 12-23-2018, 12:04 PM
gerardfraser's Avatar
Rep: 96 (Unique: 75)
Thanks everyone
I do not own this board but I would first try this.
Set all settings to auto in BIOS then go to
Advanced/AMD CBS/NBIO Common Options/Precision Boost Overdrive Configuration/Accepted and select Enable for Precision Boost Overdrive.
Save and restart machine and in light loads CPU will reach 4350Mhz on some threads and heavy loads CPU will vary depending on heat/voltage.
After you got that I would suggest CPU offset voltage EG: start with (-0.05) and test until you fine stable clocks with lower CPU voltage.
I just google off set for the board and this is what I got over on reddit.
Most people undervolt -0.075 via the offset and use Core Enhancer level 2 to get 4.15 all core and 4.35 single core for gaming FPS
gerardfraser is offline
post #4 of 8 (permalink) Old 12-23-2018, 01:16 PM - Thread Starter
cgi2099's Avatar
Rep: 0
Okay thank you! I'll look for this setting, do you know if people generally get lower temps this way of overclocking?
cgi2099 is offline
post #5 of 8 (permalink) Old 12-23-2018, 05:17 PM
Riding on the edge
The Sandman's Avatar
Rep: 356 (Unique: 249)
Thanks everyone
Yes you "should" see lower temps and voltage using a similar PE OC.
I run a PE3 OC, 4200MHz all core under load @ 1.26xv and 4350MHz single core with 3466MHz (16GBs) memory c14 on a C6H.
I highly recommend you try OffSet voltage, + sign, and first try Auto Vcore and CPU LLC. A manual SoC voltage and set memory to spec.
See what this gives you for starters and adjust from there.
Don't panic if you notice Vdroop and see how stress tests perform. You may be very surprised.
Here is a Bios text file just to give you an idea of how mine is set up PE33466121518_setting.txt
I also have Bios snips if ness, let me know.
Here's what a quick run on IBT AVX looks like and a few other tests I ran recently if your interested can be found here https://www.overclock.net/forum/27772288-post39689.html
Ryzen Build
(20 items)
Bruce
(14 items)
R7 2700x
Crosshair VI Hero
Diamond 7970
GSkill FlareX F4-3200C14D-16GFX
Samsung 960 EVO NVMe
Samsung 840 SSD
Corsair GT SSD
WD 2TB Black
WD 4TB Red
EVGA 850 G2
XSPC GPU Razor WB
XSPC RX 360
XSPC RS 360
D5 Vario
Gentle Typhoon AP-15 1850 rpm
EK-FB Asus C6H Monoblock
XSPC EX140
Xigmatek Elysium
Operating System
Win 10 Pro
Asus VE248H x2
FX 6350
Asus CHV-Z
PNY GT 710
G.Skill Trident X 16GTX 1866MHz 8-9-9-24-33-1T
Samsung 840 Pro
WD20EFRX 64M Red x4 raid 10
WD5001AALS Blk
Optical Drive
Asus DRW-24B1ST
Corsair HX500
Hyper 212 Evo R2
Corsair 330R Titainium
Operating System
Windows Server 2008 R2 Standard
Asus
Keyboard
Logitech MK300
The Sandman is offline
post #6 of 8 (permalink) Old 12-23-2018, 07:37 PM - Thread Starter
cgi2099's Avatar
Rep: 0
So here is what I have done: turned on all the xfr2 stuff to auto except blck and it is at 100.00
I then offset vcore -0.06875v and soc set to 1.025v.
Idle is 27-28c
Aida64 CPU is 45-48c
Aida64 CPU & GPU is right at 50c
Aida64 fpu is 63-65c
Cinebench 55c (score is 1811)
Gaming is around 45c
I get 4 cores to boost to 4.3 in game and autocad
Aida64 cpu stress I get all core 4.1
Aida64 fpu stress I get all core 4.0
Cinebench I get all core 4.1
Memory is 15-15-15-34 @3200 1.35v. idk much about memory timings, my kit is rated at 16-18-18-38 @3200 so maybe I can improve here?
Could I improve this anywhere? Maybe raise blck to 101 or 102?
I was able to offset vcore to -0.100 with the old chipset drivers but the new ones make me unstable all the way to -0.075
cgi2099 is offline
post #7 of 8 (permalink) Old 12-23-2018, 07:40 PM - Thread Starter
cgi2099's Avatar
Rep: 0
I tried to do my settings like this but I wasn't stable and my temps were pretty high, 40-45c at idle
cgi2099 is offline
post #8 of 8 (permalink) Old 02-02-2019, 03:47 PM
Rep: 0
2700x 4.44Ghz
I thought my limit on this CPU was 4.2 wen manually overclocking, so for ages I just left XFR to do its work but recently I have been having a play and now have stable 4.44ghz, voltage is at 1.46. Im running watercooler and under stress test I get about 68c after 10 minutes... I think there is room to overclock a little more than is commonly stated but you got to push those volts beyond the 1.35.. Ive tried for the life of me to squeeze this chip up to 4.5 with no luck though.. any higher and Im not stable for longer than a few minutes. My ram is set at 3400mhz c13 also at 1.46v
Mighter is offline
