Ryzen 2600 does boost when already overclocked? - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 01-30-2019, 03:14 AM - Thread Starter
rul3s's Avatar
Rep: 1 (Unique: 1)
Hi mates!
I have a Ryzen 2600 (my signature rig) and when on stock settings was always boosting to it's max, 3.9GHz on stock voltage 1.35v.
I saw that already on stock voltage, it does 4.1GHz, setting it on BIOS multiplier 41 and FSB 100 fixed.
The thing is that I have two monitor softwares, HWMonitor and HWInfo, and the first one reports a maximum core clock of 4.7GHz and the second one reports maximum core clock of 4.1GHz, so I don't know which one is lying.... I understand that if HWMonitor is right, 2600 can boost from oced speed as it does from stock speed, is this right? Or HWMonitor is wrong and there is no boost speed when manually ocing from UEFI?
THanks!
PhanteksR7
(16 items)
Ryzen R7 3700x
Asus x470 Strix F
RTX 2070 Windforce OC
KFA2 HOF Extreme DDR4 4000CL19 BDie
Samsung 970EvoPlus 500GB NVMe
Samsung 850Pro 512GB
Samsung 860QVO 2TB
Seasonic Focus+ 650W Platinium
Noctua NH-U12P
Phanteks Enthoo Pro M SE
Operating System
Windows 10 PRO
Samsung C24FG70
Keyboard
Corsair K70 RGB
Mouse
Zowie FK2
Mousepad
Razer Goliathus Cosmic Speed
Audio
Asus Xonar STX
rul3s is offline
post #2 of 8 (permalink) Old 01-30-2019, 03:23 AM
white owl's Avatar
Rep: 136 (Unique: 103)
4.7ghz is wrong, HWinfo is the only software you can really trust as it gets constant updates. Also using lots of software polling your sensors together can cause issues.
Manually overclocking past your boost speed obviously negates the lower stock boost speed.
If you have something manually set to 4100mhz and something reports 4700mhz it's probably safe to say that it's an incorrect reading.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #3 of 8 (permalink) Old 01-30-2019, 03:23 AM
The last VRM burner
Rep: 46 (Unique: 27)
HWMonitor is plain garbage, always was. How can you even consider 4.7GHz a legit score?
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is online now
post #4 of 8 (permalink) Old 01-30-2019, 03:26 AM
white owl's Avatar
I had to carefully word my post to make it nicer but yeah pretty much.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
post #5 of 8 (permalink) Old 01-30-2019, 03:39 AM - Thread Starter
rul3s's Avatar
Rep: 1 (Unique: 1)
Thought that maybe, for some miliseconds and only for one core (only one reported 4.7GHz) XFR and PBO where doing it's thing!
So, with Ryzen 2600 on stock, max speed is 3.9GHz, yes? Because on stock I was reading 4.2GHz on HWMonitor.... but now I understand that maybe it's the same thing.
PhanteksR7
(16 items)
Ryzen R7 3700x
Asus x470 Strix F
Samsung 860QVO 2TB
Noctua NH-U12P
Operating System
Windows 10 PRO
Samsung C24FG70
Keyboard
Corsair K70 RGB
Mouse
Zowie FK2
Mousepad
Audio
Asus Xonar STX
rul3s is offline
post #6 of 8 (permalink) Old 01-30-2019, 04:07 AM
The last VRM burner
It's boosting to 4.1GHz due to XFR2.
Never mind the other part, just reread that you used HWGarbage.
PC for all
(21 items)
Iris Pro 6200
Corsair MP510
Samsung Evo 860
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Mouse
Mousepad
Artisan FX Raiden
Audio
Audio
AKG M220
Other
NZXT Hue+
Other
post #7 of 8 (permalink) Old 01-30-2019, 04:09 AM
rdr09's Avatar
Rep: 891 (Unique: 643)
Just use the recommended app - HWINFO64. Uninstall others. Our non-X Ryzens do not have PBO. When OC'ed it boosts to the highest value set in BIOS. In your case, 4.1GHz. Better than stock. Set Windows Power plan to Balance and Minimum Processor State in Advance setting to around 25%, so that both Clocks and Vcore downclock. My 2700 downclocks to 1.5GHz/0.8V or about 13W at idle. I keep mine at stock cos it boosts to 4.1GHz.
You got a nice motherboard. It can easily take a 7nm cpu.
By Built-in Benchmark Queen:
My 2.5 years old delidded 7980xe @ 4600mhz all core with 49ns memorylatency (4000c16 twekaed) is faster than 3950x max overclocked on water in every scenario. Pretty good for a ancient cpu
In gaming it has no chance vs my new 10900k @ 5400mhz and 4600c16 tweaked memory. ~35ns memorylatency.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
post #8 of 8 (permalink) Old 01-30-2019, 04:23 AM - Thread Starter
rul3s's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by rdr09 View Post
....You got a nice motherboard. It can easily take a 7nm cpu...
Yes, that was my idea from the first day!
PhanteksR7
(16 items)
Ryzen R7 3700x
Asus x470 Strix F
Samsung 860QVO 2TB
Noctua NH-U12P
Operating System
Windows 10 PRO
Samsung C24FG70
Keyboard
Corsair K70 RGB
Mouse
Zowie FK2
Mousepad
Audio
Asus Xonar STX
rul3s is offline
Tags
2600 , boost , Overclock , ryzen
