1090t hot idle, components toss up - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 04-03-2019, 05:42 PM - Thread Starter
Darkhaze's Avatar
Rep: 14 (Unique: 14)
Hi, I'm throwing together a basic system that I can sometimes use for streaming, but everyday ms word, firefox, maybe some picture and very maybe some video editing. Right now the cpu and cooler are on the gigabyte motherboard using igpu and idling at 38c in bios, cpu fan 400-500 of 1300rpm max, which seems hot to me and the fans seem slow. It's just sitting in bios, the ssd isn't connected yet.
I'm trying to decide how I want to build this system, advice would be appreciated.
1090t w/ Scythe Mugen 2 Rev b. on either
gigabyte 880gma-ud2h rev 2.0, or
msi 890fxa-gd70
16gb 1600 cl9 or less gbs
antec ea380, or cm gx450, or ea750
gtx 460, amd x550 or gigabyte mobo's onboard hd 4250
OCZ vertex 180 120gb ssd and wd2001fass 2tb
And lastly windows 7 pro 64 or 10 pro 64. If i go 10 I am totally unable to avoid spending hours gutting the spyware/telemetry but if it will be a significant improvement.. I hate MS enough to enjoy doing it.
Thanks
Edit: Drunkedness strikes again, I just found the phenom ii x4 965be i thought i gave away.. so i guess that's i the mix now, and my NT-H1 Remounting that pita to mount cooler soon for sure!
Do your own research and testing, both for peace of mind that (a) What you're reading is true, and that (b) Your gear ain't defective!
Darkhaze is offline
post #2 of 5 (permalink) Old 04-04-2019, 04:34 PM
Ore Wa Gundam
EvoBeardy's Avatar
Rep: 187 (Unique: 158)
Honestly, in terms of traditional BIOS, CPU temps are always pegged. I think it's to do with simply how old the BIOS code is.
Back when it was created, overheating wasn't really an issue as far as I know, and I'm certain when in the BIOS itself, a single core is pegged at a very high usage, hence the higher than normal temperatures.
Once you've installed the SSD and loaded the OS, I image your temps will be around 26c or so.
However, and not to scare you, but that particular motherboard didn't have great VRMs, so using the X6 at stock clocks at most, and undervolted would be highly recommended, if you did decide to use it. It'll be fine for OCing your X4 to 4Ghz though, however your usage scenario would require more threads, and the X6 should be better stock than an overclocked X4 with editing and streaming, so the choice is yours.
There was a huge fiasco about VRMs burning out with the introduction of the Phenom X6s, and MSI were plagued with using cheaper MOSFETs and phases on their boards at the time (capable of running X4's fine for the most part though), the GD65 and the Fuzion Power were the only two boards of their AM3 lineup that anyone would recommend using with X6s, especially when OCing.
Like I said, you should be fine stock (maybe disable turbo too), and especially if you undervolt the X6.
Unicorn SD
Astraea
(8 items)
l Intel® Core™ i7-5820K l
l MSI X99A SLI Krait Edition l
l MSI GTX 980Ti Gaming 6G l
l Corsair Dominator® Platinum (4x4GB) DDR4 3Ghz l
| Samsung PM951 M.2 PCI-e NVMe 512GB |
l Samsung 840 Evo 500GB l
l Toshiba X300 4TB 128MB Cache l
l Toshiba MD04ACA400 4TB l
l Toshiba DT01ACA300 3TB (x3) l
l Samsung F3 1TB l
Optical Drive
l Pioneer BDR-209EBK l
l EVGA SuperNOVA G2 850w l
l NZXT Kraken X61 (2x Noctua NF-A14-2000-IP67) l
l Phobya MaxGuide 6 Controller l
l CM Storm Stryker™ l
Operating System
l Windows 7 x64 Customised. l
l LG M2380D 1080p l
l Acer Predator XB240H 144Hz G-Sync l
Keyboard
l Logitech G19s l
Mouse
l Logitech G502 l
Mouse
l Razer Vespula l
Audio
l Steelseries Siberia V2 MSI Gaming Edition l
Audio
l Logitech Z506 5.1 l
Audio
l Creative Fatal1ty HS-800 V2 l
G3258 @4Ghz
MSI Z97I Gaming AC
MSI GTX 460
Crucial Ballistix Sport 1600MHz 8GB
Samsung 840 Evo 128GB
Toshiba DT01ACA100 1TB
Optical Drive
Optiarc 7170S
Cooler Master Silent Pro M2 520w Modular
Corsair H60
Cooler Master Elite 130
Operating System
Windows 7 x64
Keyboard
Logitech K400 Wireless Touch
Mouse
Logitech M187
i5 460m
MSI Intel HM55
Onboard Intel HD
Kingston PC3-8500F
Kingston PC3-8500F
Toshiba MQ01ABD100H [Hybrid]
Optical Drive
Optiarc AD-7580S
Operating System
Windows 7 X64 nVidia Ed.
EvoBeardy is offline
post #3 of 5 (permalink) Old 04-05-2019, 04:29 AM - Thread Starter
Darkhaze's Avatar
Oh my eek. The gd65 was the cheaper board.. so all that talk about military grade whatever and the big cooling pipe were just.. lies? lol.. I remember making an effort to get the gd70 I have the 965 and the 880 right now, 880 which can't run the ram at the right speed, partiot 1.65v 1600 cl9, runs at either 1600 cl11 or 1333 cl9 (PGD38G1600ELK). Should be able to use AMP or AOD to get it right on the 890... I hope. I'm going to put the 1090 on that. So far the 965 is running pretty cool(ish) using my old am2's Arctic Freezer Pro 64 with it's 92mm fan and not cover quite the full cpu heat spreader lol. Idles low 30s and barely saw it touch 50 (51max). Stock ofc. I'm running an old corsair h50 120mm pwm fan as the exhaust behind it at around 800 rpm (65% speedfan) cuz the 880 doesnt seem to ever change the speed from the board header on it's own.
Is there a way to additional cool the vrms so I don't have to underclock the 1090? It would feel bad haha... I don't suppose there's anything like VRM spread spectrum on that board?
Darkhaze is offline
post #4 of 5 (permalink) Old 04-10-2019, 10:18 PM
ssateneth's Avatar
Rep: 44 (Unique: 39)
38C is fine, you are overreacting. that's about as warm as the human body. if you were idling at 60c, i'd be concerned. 50c idle is ok, if airflow was congested and power saving features were turned off.
also, just in BIOS often does not enable more advanced cpu power saving, so you often will have higher temperatures in BIOS compared to idling in windows.
you have nothing to worry about for 38c idle temp.
OS choice, pick whatever you feel more comfortable with. Win10 may have a little more overhead compared to W7, but nothing that would severely impact your experience (aside from forced updates and bad start menu / UI, but thats just my opinion)
Intel Core i9-9900k (Silicon Lottery 5.1GHz @ 5.3GHz 1.36 VCore)
ASUS ROG MAXIMUS XI APEX
G.SKILL F4-4000C19D-32GTZSW (2x16GiB 4000MHz 19-19-19-39 2T, tuned to 4133MHz 14-17-17-31 2T)
EVGA NVIDIA GeForce GTX 1080 Ti FTW3
Seasonic PRIME 1300W 80+ Platinum
ssateneth is offline
post #5 of 5 (permalink) Old 04-16-2019, 03:48 PM
Ore Wa Gundam
EvoBeardy's Avatar
Yeah, while the GD65 was the cheaper board, the GD70 had more lanes for running higher than 2-way 16x SLI, plus the beefier looking VRM heatsink, that unfortunately harboured pretty meh VRMs.
I'll note that with boards that have sub-par VRM cooling, top-down blowers are better as they direct airflow over the VRMS, superior coolers which are typically front-back don't cover the VRMS, which then in-turn can lead to thermal throttling when pushed/OCd.
The issue with the GD70 isn't necessarily the lack of VRM cooling as such, like the 880 you could throw some aftermarket heatsinks on the VRMs if you get any throttling, the GD70 used poor quality MOSFETs, so they just blew. The GD65 had much better quality MOSFETS, as does the Gigabyte's 880, which has protection against them blowing, as well as better quality MOSFETs.
Obviously anything to keep the GD70's VRM cool is going to lead to less likelihood of them blowing under stress from the X6's consumption, but ultimately it's the consumption that is the cause of the blowouts, less than the cooling capacity itself.
For the record, I recommended undervolting the X6 and keep it at stock clocks, not underclocking it. Undervolting it will cause it to pull less voltage through the MOSFETs and keep the thing in its entirety cooler. Disabling turbo and undervolting would be the only way I'd recommend using the Thuban on the GD70, you'll still get your uses for editing etc, while operating under much safer limits.
The X6 will be fine in the 880 overall, you may need some aftermarket heatsinks for the VRM (incase of throttling), but you will get throttling and nothing more severe with some OCing at least. And you'll be able to OC it much safer than on the GD70
While you're not entirely incorrect, that's only true for Intel, at least with this era. The Deneb era all were best kept under 55c for stability under load, and a max operating temp of 62c IIRC. I think they actually cut out at something like 70c as their utter maximum, but you never really saw people operating these chips over 55-62c under load.
These chips typically idled between 26-32c in Windows (depending on factors), but yeah, as we both stated; 38c in BIOS isn't uncommon for reasons.
Unicorn SD
Astraea
(8 items)
l Samsung F3 1TB l
Optical Drive
Operating System
l LG M2380D 1080p l
Keyboard
l Logitech G19s l
Mouse
l Logitech G502 l
Mouse
l Razer Vespula l
Audio
Audio
Audio
G3258 @4Ghz
MSI Z97I Gaming AC
MSI GTX 460
Optical Drive
Optiarc 7170S
Corsair H60
Operating System
Windows 7 x64
Keyboard
Mouse
Logitech M187
i5 460m
MSI Intel HM55
Onboard Intel HD
Kingston PC3-8500F
Kingston PC3-8500F
Optical Drive
Optiarc AD-7580S
Operating System
Tags
amd 1090t , Cpu Fan , Motherboards , temperature , windows
