Would like advice on an AIO vs Air cooler. - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 04-27-2019, 01:56 PM - Thread Starter
Melted Cheese
Exostenza's Avatar
Rep: 251 (Unique: 217)
First off let me set out that I am an extreme overclocker and want every last drop of juice I can squeeze out of everything I buy without degrading the performance of it. I also am very price to performance conscious so if something is objectively the best at what it does, but it disproportionately priced compared to other choices I am going to go for one of the other choices even I could afford the technically "best". I'd like to hit 4ghz on my ryzen 1600 which is possible and soon enough I will most likely get either an X470 or an X570 board with zen 2 to run my RAM at its rated speed and well, you know... Ryzen 2!!!!!
I am coming from the bias that air cooling just makes more sense, it is cheaper, usually cools as goof or is in the range of AIO cooling that makes the difference negligible, while it is generally quieter as well, not to mention never having to worry about a pump going or a tube leaking; it just makes more sens to go air. With that being said, I have not been able to find a suitable air cooler for my setup and in my frustration I decided to buy the EVGA CLC 280 on a really good sale with 2 Arctic Cooling static pressure fans which are very quiet and overall great build quality for very cheap as well. I planned to either switch out the fans that it comes with or use them with the Arctic Cooling fans for a quieter setup. I was fine with all this until I stumbled across the Enermax T50 Axe CPU Cooling ETS-T50A-BVT which is around 1 degree hotter than the NH-D15 (the holy grail of air coolers) AND it fits with my RAM while being significantly cheaper plus all the upsides of air over AIO. I am wondering if it is worth my time to return the items to Amazon and buy the air cooler instead or should I stick with my AIO considering I got it for such a great price. I was able to get the AIO and 2 Arctic cooling static pressure optimized PWM CO fans for $151 CAD after taxes.
All the reviews seem to say the same thing; AIO is mostly for show or if you have room restrictions while air is generally the better option due to all the point previously discussed although if one could get a well reviewed AIO at a very good price then the AIO is probably worth it. Generally, since AIOs are much more expensive than air they are just not worth it if you can find a good air cooler that fits fine. First I thought I was in that category but now, after finding the Enermax T50 Axe CPU Cooling ETS-T50A-BVT, I seem to no longer be in that category albeit I did get it for a very good price putting me back into the probably should go for it position.
I don't really know what to do. I hear EVGA has great warranty customer service and the AIO comes with a 5 year warranty which might be longer than I plan to have the setup. If I got air I would probably keep it during an upgrade because it lasts forever and if I get an AIO I would be inclined to sell it when upgrading because of the limited lifetime of the product.
So, what do you all think?
»The Intel Crapper•24/7 RØCK SØLIЫ
i7 80806k»5ghz16GB G.Skill Trident Z 3866C18D»MSI MEG Z390 ACE»MSI RTX 2080 Gaming X TrioSamsung 27" QLED»1440p 144hzThermaltake Toughpower Grand RGB 1200W Platinum»EVGA CLC 280•Arctic Cøøling P14 PWM Static Pressure Optimised Fans Black»Windøws 10 x64 Pro 1903"Decent Editiøn"»2TB NVMe M.2 ∑ størage
Exostenza is offline
post #2 of 8 (permalink) Old 04-27-2019, 02:02 PM
Senior OCN Member
shilka's Avatar
Rep: 2787 (Unique: 1646)
There are open loops coolers and AIO kits available from EK, Swiftech, Alphacool and others and all of those are much better than the CLC junk
Buy one of those or build your own loop dont buy some Assetek garbage
Otherwise stick with air cooling
https://www.overclock.net/forum/61-w...lc-cooler.html
Dumpster fire
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
EVGA SuperNova G2 750 Watt
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is online now
post #3 of 8 (permalink) Old 04-27-2019, 02:10 PM
The last VRM burner
Rep: 42 (Unique: 25)
Kraken X60 is getting outperformed by Raijintek Tisis, freshly tested on my rig.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #4 of 8 (permalink) Old 04-27-2019, 02:37 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1282 (Unique: 691)
If you want price : performance then why are you even considering an AIO? A good air cooler costs at least half as much as an AIO that performs comparably.
Best bang for buck cooler is something along the lines of a Thermalright Le Grand Macho RT for $60 or a Noctua NH D15.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #5 of 8 (permalink) Old 04-28-2019, 02:29 AM
poah's Avatar
Rep: 7 (Unique: 6)
for ultimate cooling with no care for sound then an AIO will out perform and air cooler particularly if you are using it in case. I probably wouldn't bother with 4ghz on a 1600 unless you get a golden chip. The performance increase over 3.9 is nothing but the exponential increase is volts produces a lot of heat. If you are currently using a B350 board with your 1600 then your VRM is going to get very toasty. Keep the current AIO with the arctic fans (P14?). also I would ignore people that say AIO's are junk there is a place for custom, aio's and air coolers.
just to point out I can run 3200mhz CL14 ram on my B350 board with a ryzen 1700. On my X470 I can run 3400mhz
poah is offline
post #6 of 8 (permalink) Old 04-28-2019, 02:46 AM
Meep
Gilles3000's Avatar
Rep: 318 (Unique: 229)
Considering you already own the CLC and the resale value probably won't be great. I'd say keep it.
A 280mm CLC is still going to be a solid performer, and more than plenty to cool a R5 1600, I wouldn't focus as much on 4Ghz, like Poah said, most 1000 series ryzen chips don't like going over 3.9, neither did my 1600X I had a while back.
I'd recommend spending less time overclocking the cpu and more on the ram, go for 3200Mhz and then tighten your timings as much as possible. That will net you a lot more performance than overclocking the CPU past its voltage wall.
Gilles3000 is offline
post #7 of 8 (permalink) Old 04-28-2019, 10:24 AM
curmudgeon
miklkit's Avatar
Rep: 307 (Unique: 178)
That Enermax cooler has 5 heat pipes and one fan and is rated at 250 watts. Plus it has lots of RGB bling! That's plenty for a 1600 but it might struggle later with more powerful Zen2. It also doesn't look too upgradeable with more fans.
Since you are predisposed to air cooling, return that clc and get a big air cooler just so you feel better about your system. If you want RGB then you can add fans later. I have two air coolers bought in 2013 that are still running fine plus one from 2014 also doing fine. The 2014 one is running on this current rig as the AM4 adaptor cost $6.
IOKIYAR
Junkyard Dog
(18 items)
Blackie
(17 items)
AMD Ryzen 1700
Biostar X370 GT7
Sapphire Nitro+ Radeon Vega 64
G. Skill Ripjaws ddr4 3200 16 GB 4x4
Samsung 850 EVO 500gb SSD
Western Digital 500gb
Samsung 860 evo 1tb ssd
Optical Drive
Memorex Lightscribe dvd
Seasonic 850 watt
Thermalright Silver Arrow IB-E Extreme
Silverstone Redline RL05
Operating System
Win 10 64bit
Pixio 27" 1440P
Keyboard
yes
Mouse
Evoluent vertical mouse
Mouse
yes
Audio
Creative X-FI
Other
Sennheiser headphones HD 599
AMD FX8370 @ 5 ghz
ASUS Sabertooth
Sapphire Fury
G Skill F3-14900CL9Q-16GBXL
Western Digital
Samsung 850 EVO
Optical Drive
Seasonic SS-850KM Active PFC F3
Silverstone Redline RL02b
Operating System
Win X 64 bit
Pixio 27" 1440P
Keyboard
yes
Mouse
Evoluent VM4
Mouse
yes
Audio
Creative Soundblaster Z
Audio
Sennheiser 428 headphones
miklkit is offline
post #8 of 8 (permalink) Old 05-03-2019, 06:22 AM - Thread Starter
Melted Cheese
Exostenza's Avatar
Well, I kept the EVGA CLC 280 because I got it for such a cheap price and my Trident Z RAM really limits my options for serious air cooling. I replaced the original loud AF fans with these 10 dollar fans which are so quiet all you hear is the air whooshing through them while the are made specifically for static pressure. The and result is that I now have a completely stable 4ghz Ryzen 1600 that never goes above 56C. I was very skeptical when it came to AIOs although with the fan replacement (the originals sound like a vacuum, no joke) it cools tremendously well and most important it is about as quiet as I could have ever possible hoped for. EVGA has a very good 5 year warranty which I have read a lot of people with glowing reports regarding their customer and warranty service. I am confident this thing will last and it is so much better than I ever could have predicted. For less than the price of a Noctua NH-D15 I have a cooler that hardly takes up any space, this is important because my VRMs are a lot cooler now, that cools better than it. The NH-D15 has always been my point of reference, as I absolutely love that beast, and being able to say that for less I got a much better setup than I could have every hoped for makes me happy and quite proud too considering I figured out using those Arctic Cooling fans rather than some expensive 30-40 dollar fan which would have totally blown the budget as I needed two. Since I am on the topic I just don't get the fan market with Arctic cooling having fans which you can't hear the bearings, push more air than the competition, have 6-10 year warranties, and usually cost a quarter of what the competition is asking for. I am so happy I found Arctic Cooling and now every single fan in my system is an Arctic Cooling fan and this thing is quiet considering I am pushing 6 fans; all I can hear is the air - no sounds of bearing or juddering what so ever.
Anyways, thanks for the input and I am super happy with these results. Now to just hope the CLC doesn't leak!
