Please help me with overclocking Ryzen 7 1800x / B350-F - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 05-02-2019, 03:10 AM - Thread Starter
Rep: 0
Hello,
please help someone with overclocking? I'm a newcomer to the new AMD CPUs. In my youth I timed in big (in those tiem, the CPU clockw was only about 100-400 MHz). But nowadays I have a problem with overclocking. I don't the new Ryzen CPU at all.
I've tried in BIOS to change the CPU ratio to 38.5x (from the default/auto ratio - i.e. 36x), the only one being stable and functional. If I use 39.0x, the CPU sometimes freezes and if I use 40.0x or more, the CPU freezes very often. I tried to raise Vcore but I don't know how to raise it. I've read a few tutorials, but I haven't done anything.
CPU cooler which I own is a massive aluminum with FAN. It is a quality and very large cooler. So with a higher CPU temperature, there would be no problem if a high CPU overclocking rate was reached.
I would like to achieve at least 4200-4300 MHz, with the ability to dynamically change both the frequency and volts in the CPU, to save energy and reduce heat in idle mode. I play games only occasionally. Rather, I use a PC for computational performance and rendering (SONY Vegas Studio).
How do I get at least 41.0x CPU ratio instead of the current 38x - 38.5x?
In my opinion the biggest problem is caused by my RAM modules. It's quite a problem to update them.
Does anyone already have a timing profile stored in a BIOS file that he would send me?
MoBo:
ASUS ROG STRIX B350-F GAMING
- BIOS ver .: 4602
CPU:
AMD Ryzen 7 1800X
- cooler: Noctua NH D15
VGA:
AMD Radeon R9 270X
- cooler: Accelero Twin Turbo II
DDR4:
Kingston KHX2666C16 / 8G (8GB x2)
"HyperX 16GB KIT DDR4 2666MHz CL16 Fury Black Series"
- current timing (tCAS-tRCD-tRP-tRAS): 16-18-18-39
PSU:
Corsair RM750i
(info powered by HWiNFO64)
Thanks.
ferkoslav is offline
post #2 of 10 (permalink) Old 05-03-2019, 10:54 AM
rdr09's Avatar
Rep: 875 (Unique: 637)
I'll try but if something goes wrong, please don't blame me.
First of all, I have the same motherboard and imho, it is not meant to oc an 8-core cpu, I did oc my R7 2700 to 4GHz with but only used for benching. You can try 4GHz but i doubt you'll get any higher.
Secondly, you need a good cooler like a Noctua DH-15 or a H100i AIO cooler. At idle using HWINFO64, your CPU temp at stock should be around 35-36c. Lower the better. At load, say using IBT, your temp should not exceed 50c (lower is better) at stock. If it does, then you won't have room to cool an oc'ed 1800X. Ambient temp will play a big role. You normally want to set an oc during warmer periods.
On the first SS (disregard the RAM settings), the CPU Core Ratio in your case would be 40 , which you already know. Scroll down and you to set CPU voltage to OFFSET MODE/+and add an amount to the base value of 1.237v making sure you do not exceed 1.42v. In that example, 1.237 + 0.1625 = 1.4v approx.
The second SS, you have to adjust LLC value to High under AI tweaker/ DIGI+VRM. Try High first and see if it works.
Save changes and boot. If it boots, open HWINFO64 and check your temps. Run some benches such as CPUZ bench, Cinebench 15 or 20.
In order to save energy, set Windows Power Plan to Balance and under Advance Power Options set Minimum Processor State to around 25%.
Try to do some work. GL!
[email protected] 6 http://valid.canardpc.com/show_oc.php?id=2211392 4.6 @ 4 http://valid.canardpc.com/show_oc.php?id=2216580
5.0 @ 8 http://valid.canardpc.com/show_oc.php?id=2511322
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #3 of 10 (permalink) Old 05-03-2019, 11:12 AM
rdr09's Avatar
BTW, the B350F, with a bios update, will accommodate a Ryzen 3000 cpu. Then, you don't need to oc. Stick with an 8-core. I don't think a 12-core will be appropriate for this motherboard.
As for the RAM, sell what you have and get some B-dies.
https://benzhaomin.github.io/bdiefinder/
Got some G.Skill FlareX 3200 CL14 and gives me no drama.
Either of these RAMs:
https://www.newegg.com/Product/Produ....+Skill+FlareX
https://www.newegg.com/Product/Produ...-217-_-Product
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #4 of 10 (permalink) Old 05-03-2019, 11:17 AM
Senior OCN Member
shilka's Avatar
Rep: 2787 (Unique: 1646)
What PSU do you have in your system and yes that matters if you are overclocking
And the H100i is not a good cooler by the way
Dumpster fire
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
EVGA SuperNova G2 750 Watt
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #5 of 10 (permalink) Old 05-04-2019, 12:06 AM
rdr09's Avatar
I missed it. Op, already has one of the best air cooler. What's a good alternative to the H100i? The Enermax, Swiftech, or other CoolerMaster AIO? An AIO that does not cost as much as custom cooling.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #6 of 10 (permalink) Old 05-04-2019, 02:13 AM
Senior OCN Member
shilka's Avatar
None of the CLC coolers are worth buying
https://www.overclock.net/forum/61-w...lc-cooler.html
The NH-U12A is cheaper more quiet and has better temps than any of the CLC coolers its compared to
Dumpster fire
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
post #7 of 10 (permalink) Old 05-04-2019, 03:48 AM
rdr09's Avatar
https://www.youtube.com/watch?v=23vjWtUpItk
What? Not even the Swiftech? That air cooler is indeed very well made and cools satisfactorily. Using it right now. It only comes with one fan.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #8 of 10 (permalink) Old 05-04-2019, 03:51 AM
Senior OCN Member
shilka's Avatar
Swiftech dont make CLC coolers CLC stands for closed liquid cooler and none of Swiftech coolers are closed as far as i am aware they are open so they would be OLC or open liquid cooler
AIO stands for all in one and all CLC coolers are AIO but not all AIO are CLC
By saying CLC and not AIO i was being specific
As for the NH-U12S that only comes with one fan but the new NH-U12A comes with two fans which are brand new fans
Dumpster fire
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
post #9 of 10 (permalink) Old 05-04-2019, 04:13 AM
rdr09's Avatar
Swiftech dont make CLC coolers CLC stands for closed liquid cooler and none of Swiftech coolers are closed as far as a am aware they are open so they would be OLC or open liquid cooler
+rep. Thank you.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #10 of 10 (permalink) Old 05-12-2019, 09:35 AM - Thread Starter
Rep: 0
Hello.
Sorry I haven't been here long. But I also waited long enough to approve my first question for discussion .
Thank you all for your advice. I'll try. I probably buy better RAM DDR4 modules with good overclock support - G.SKILL 16 GB KIT DDR4 3200 MHz CL14 Flare X for AMD.
PSU:
Corsair RM750i
Tags
overclocking help , ryzen 7 1800x
