Problems with ryzen 5 2400g and ASRock B450M-HLD R4.0 - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 05-23-2019, 02:23 PM - Thread Starter
Rep: 0
Hi, I just bought a new PC with the following things:
ASRock B450M-HLD R4.0 (BIOS P1.0)
RYZEN 5 2400G 3.9GHz + Radeon Vega 11 AM4 STOCK Cooler
(stock settings, XLP profile for RAM, and 2gb allocated graphics memory)
2x8GB RAM Team DDR4 2666MHz T-Force Vulcan Red
Power Supply Corsair 450W CX450M Semi Modular 80 Plus Bronze
SSD Kingston A400 240gb 2,5'' Sata3
HHD Seagate 1TB Barracuda 64MB SATA 6GB/s
and also I already had a wifi card
TPLINK PCI Express Dual band AC AC1300 - Archer T6E
The problem only happends during games
I just tested the following games
GTA V
CS GO
The division 2
the system just Bricks. It shows black screen and I can't do nothing to restart the system. If I press and hold the power button, nothing happends, I also tried to press ctrl + win + shift + B to reset graphics drives but it doesn't work (I have the last recommended drives). The PC keep working but it shows black screen.
I have reinstalled windows 10 3 times and I tested it with different drives for the APU, I pulled off the wifi card and I change the SSD with other I have but it keeps doing the same.
So, I believe that you are going to recommend me to update the BIOS because the asrock web had a lot of BIOS updates
https://asrock.com/MB/AMD/B450M-HDV R4.0/index.es.asp#BIOS
so I would like and advise before upgrading the BIOS,
What should I do to prevent a fail during the BIOS upgrading?
And also the asrock webpage says that I need to upgrade to 1.4 before upgrade o the last version 2.3
and other thing that I don't understand is Why the page says that I need to install the VGA driver before upgrading the BIOS?
Thanks.
Leonardo.
leonardom57 is offline
post #2 of 4 (permalink) Old 05-23-2019, 06:35 PM
Da Boss
NexusRed's Avatar
Rep: 140 (Unique: 121)
Welcome to OCN.
Follow what Asrock says to do. Upgrade the bios following whatever path they deem proper. Once that's done, report back.
NexusRed is offline
post #3 of 4 (permalink) Old 05-27-2019, 06:54 PM
CravinR1's Avatar
Rep: 982 (Unique: 748)
I had that board with 2200g
I used the 2.2 bios from https://www.asrock.com/MB/AMD/B450M-...index.asp#BIOS (2.3 wasn't available i'd get the newest one)
Before I'd upgrade, especially with a unstable system, I'd load bios defaults
R7 [email protected] EVGA GTX1070ti https://valid.x86.fr/f8vusi
R7 [email protected] XFX 390X https://valid.x86.fr/4kmsxd
[email protected] Sapphire Tri-X 290http://valid.x86.fr/0lv27p
Finally Ivy
(16 items)
Intel 3770K 4.5 ghz 1.29v
Gigabyte GA-Z77X-UD3H
Sapphire Tri-X 290
G.Skill SNiper Gaming Series 16 gb (2x8gb) 1866mhz
G.skill Ares 8 gb (2x4gb) 2400mhz
Samsung 840 EVO 250
Toshiba 3tb x2 (6tb)
Optical Drive
LIte-On 20X DVDRW
Seasonic X-1050
Corsair H90
Cooler Master HAF 912
Operating System
Windows 7 Pro x64
HP w237ld 23" 1080P
Viewsonic VG2230wm 22"
Keyboard
SK-1788
Mouse
Logitech G400
CravinR1 is offline
post #4 of 4 (permalink) Old 06-05-2019, 05:50 AM - Thread Starter
Rep: 0
Quote: Originally Posted by NexusRed View Post
Welcome to OCN.
Hi!, thanks for reply, I've updated mi BIOS to 1.4 version and the problems have gone, now I can run my RAM to 2666MHz without problems but there is a new problem.
Because of the graphics drivers requirement to boot into windows after update the BIOS, you can not boot ANYMORE with generics graphics drivers, so you can not format your system ANYMORE unless you have a dedicated grapichs card or unless you downgrade you BIOS back to 1.0 version. So becarefull with that because I tried to install windows in other HDD to test it, but after the first restart windows can not finish the installation, it stays loaded with the asrock logo
I can not found a way to reinstall windows without a dedicated graphics card or a BIOS downgrade.
Tags
asrock b450m-hld r4.0 , bios updeate , black screen , Bsod , ryzen 2400g
