Strictly technical: Matisse (Not really) - Page 20 - Overclock.net - An Overclocking Community
post #191 of 679 (permalink) Old 07-15-2019, 10:19 AM - Thread Starter
The Stilt's Avatar
Rep: 852 (Unique: 324)
Quote: Originally Posted by FlanK3r View Post
Roger @The Stilt
do u have some tip, how to fix this "issue"? Is it possible to manually fix it?
https://www.youtube.com/watch?v=tlUE8GlkbGA
As far as I know, yes.
My 3900X specimen now boosts to 4.625GHz, despite being limited to 4.575GHz even 1.0.0.3AB.
Based on a sample size of one, I cannot say if the method I use to fix it is the sufficient remedy on all specimens.
Technically it has nothing to do with AGESA version itself.
I'm confident that an official fix will be available at some point (soon).
The Stilt is online now
post #192 of 679 (permalink) Old 07-15-2019, 02:00 PM
Rep: 2 (Unique: 2)
That's big if true. Can you share more details ?
fursko is offline
post #193 of 679 (permalink) Old 07-15-2019, 02:41 PM
Rep: 0
Wow! Can you say what you are doing or what road to go down to to attempt this?
anethema is offline
post #194 of 679 (permalink) Old 07-15-2019, 03:30 PM - Thread Starter
The Stilt's Avatar
It is quite simple, but not something which an average user can do, partially due to the lack of equipment.
I'll let AMD to elaborate once they have investigated and fixed the issue.
And as I said, I've only tested it on a single specimen (3600 and 3700X had no issues). Other reviewers had samples which were limited to significantly lower frequencies than mine, which did 4.575GHz peak at stock.
So I have no way of knowing if the solution will completely fix the issue, or if it is simply an improvement. Mostly that's why I don't care to be more specific.
post #195 of 679 (permalink) Old 07-15-2019, 03:44 PM
Rep: 2 (Unique: 2)
Interesting! I've also saw some tests people undervolting their Ryzen and their clock speeds stay same or improves even more but the performance lose is big. You probably already know that. Why this happens ? Is it wrong clock speed reporting or what ? Same thing happened to me with my Vega's. One of them was reporting lower speeds and getting better results. Other one reporting higher speeds and even higher with the undervolt but still lacking behind.
fursko is offline
post #196 of 679 (permalink) Old 07-15-2019, 03:47 PM - Thread Starter
The Stilt's Avatar
Clock strechers are kicking in, when the CPU doesn't receive the voltage it requires.
It seems that it will increase the VID request until FIT limit is reached and then start stretching if its still in UV condition.
https://www.overclock.net/forum/28044514-post7.html
post #197 of 679 (permalink) Old 07-15-2019, 04:40 PM
DRAM Obsessor
CJMitsuki's Avatar
Rep: 7 (Unique: 6)
I have mine undervolted wit a -.0625v offset with 3733mhz cl14 memory 1:1:1 with a BCLK of 101.8mhz which boosts to 4.4ghz all core and 4.48ghz single core. No loss of performance from what i see and significantly lower temps, my fans barely run unless im running a benchmark.
CPU- AMD Ryzen [email protected] *
MOTHERBOARD- ROG Crosshair VII Hero
GPU- EVGA GTX 1080ti SC2 w/ XOC [email protected] (Morpheus Cooler)
RAM- G.SKILL TridentZ 32gb (4 x 8gb) @ 3800mhz (14-15-15-24-38-1T)
COOLING- CORSAIR Hydro Series H115i Pro w/ Noctua NF-A14 (x7)
CASE- Silverstone RL06 Pro (Modified)
MONITORS- VIOTEK GN34DB (x2)
CJMitsuki is offline
post #198 of 679 (permalink) Old 07-15-2019, 04:47 PM
⤷ αC
AlphaC's Avatar
Rep: 904 (Unique: 590)
https://www.phoronix.com/scan.php?pa...HAIR-VIII-HERO
BIOS 0702 actually is slower than 0066
It's usually a few percent swing if that in either direction, but the older BIOS was favored in a number of cases.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #199 of 679 (permalink) Old 07-15-2019, 04:49 PM
Rep: 17 (Unique: 9)
Clock Stretchers? Like in this older AMD slide?
Name:	AMD Clock Stretcher Slide.png
AMD Ryzen 2700X  |  Fractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  | G.SKILL TridentZ 3636MHz @ 14-15-14-28 2x8GB  | EVGA 1070 Ti SC GAMING ACX 3.0 Black  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3  | Thermaltake Core P3 Case |
nick name is offline
post #200 of 679 (permalink) Old 07-15-2019, 05:30 PM
Rep: 0
One thing to seemingly keep in mind is..while the old way seemed to be to undervolt a bit so it would clock higher without hitting the FIT voltage, undervolting seems to do very weird things on Zen2. Everyone is reporting that an undervolt actually got them consistently higher clocks, but when actually benching the machines, the scores go way down. Games too.
One thread on reddit: https://www.reddit.com/r/Amd/comment...formance_with/
EDIT:I see you have already addressed the downsides of undervolting. NVM
So it seems while undervolting may help clocks, it isn't the answer for actual overclocking.
As far as the 'solution' I'd still be curious to hear it even in a PM. I work in electrical engineering and can get my hands on a bit of equipment I mostly work in RF, but still.
anethema is offline
Closed Thread
