Strictly technical: Matisse (Not really) - Page 3 - Overclock.net - An Overclocking Community
Closed Thread
post #21 of 679 (permalink) Old 07-08-2019, 03:19 AM
Meddling user
gupsterg's Avatar
Rep: 786 (Unique: 360)
Currently I have a pre-order for R7 3700X, after reading OP, I'm thinking of getting a R5 3600. Especially as all I do is tinker with the setup than really use it. OP would suggest to be the non X R5 3600 has full PBO support or am I reading between the lines, anyone able to share info on this? or do I just order a R5 3600 which can be here tomorrow and try it .
gupsterg is offline
post #22 of 679 (permalink) Old 07-08-2019, 03:55 AM
VPII's Avatar
Rep: 16 (Unique: 11)
Quote: Originally Posted by rdr09 View Post
I'm not understanding this. Isn't that is what we are trying to avoid by staying at or up to 3733MHz or just use 3600MHz and lower?
Even in the x470 motherboards you'll get added options in the bios when dropping a Ryzen 3000 in with which you can set the IF speed hence higher memory clocks being possible. But the higher memory clocks won't help much if your IF is at 1000mhz.
My friend had the IF speed at 1900mhz on an Asrock x570 board. He struggled with both the Asus and GB board he has due to bios not really working as it should.
Sent from my SM-G960F using Tapatalk
AMD Ryzen 9 3950X
MSI Meg X570 Ace Bios V170
4 x 8GB G-Skill DDR4 3200 CL14 @ DDR4 3733 CL16
Palit Geforce RTX 2080 Ti
VPII is offline
post #23 of 679 (permalink) Old 07-08-2019, 03:58 AM
Jism's Avatar
Rep: 0
the safe voltage levels for the silicon are around 1.325V in high-current loads
and up to 1.47V in low-current loads
Really, take that advise for granted whenever your going to put in a manual OC. I've seen people degrade their 2x00 series chips to bits and even review websites sending out the wrong signal for putting 1.4 / 1.45v vcore. It will degrade your chip faster then you think.
Just as (my) 2700x; undervolting and good cooling is what gets the best out of XFR/PBO (4.1Ghz All core and 4.35Ghz single).
Jism is offline
post #24 of 679 (permalink) Old 07-08-2019, 04:23 AM
rdr09's Avatar
Rep: 891 (Unique: 643)
Yes, so we can read your findings soon! Then, sell it when the 16 core cores.
By Built-in Benchmark Queen:
My 2.5 years old delidded 7980xe @ 4600mhz all core with 49ns memorylatency (4000c16 twekaed) is faster than 3950x max overclocked on water in every scenario. Pretty good for a ancient cpu
In gaming it has no chance vs my new 10900k @ 5400mhz and 4600c16 tweaked memory. ~35ns memorylatency.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
post #25 of 679 (permalink) Old 07-08-2019, 04:25 AM
rdr09's Avatar
Looks like Asrock is on the ball this time. Thanks VPII. +rep.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
post #26 of 679 (permalink) Old 07-08-2019, 04:36 AM
Meddling user
gupsterg's Avatar
For those interested Anandtech article has nice info on constraints for 3xxx.
Spoiler!
Your pushing me over the edge man! , as forum member there it's FOC next day delivery...
Spoiler!
Hopefully the 3xxx SMU doesn't track negative voltage offset just like 2xxx.
gupsterg is offline
post #27 of 679 (permalink) Old 07-08-2019, 09:32 AM
Always Learning
finalheaven's Avatar
Rep: 76 (Unique: 39)
Quote: Originally Posted by chakku View Post
Awesome writeup and interesting analysis on the overclocking.
Is there a chance we could see some CCD latency testing and compare how data hopping from a core on one chiplet to the other compares to a single chiplet processor? Ie how a theoretical 2CCX/2CCX + 2CCX/2CCX 8 core processor would fare against the 3700X's 4CCX/4CCX? (I know this is probably outside the scope of your analysis but it's worth a try since Matisse does change the layout entirely)
Check this out: https://3dnews.ru/990367/obzor-amd-ryzen-9-3900x
finalheaven is offline
post #28 of 679 (permalink) Old 07-08-2019, 09:47 AM
Meddling user
gupsterg's Avatar
@finalheaven
Nice find/share (+rep).
@rdr09
I told the wife it was you who made me do it ...
Spoiler!
Now to get ready to be further hen pecked when I tinker tomorrow ...
gupsterg is offline
post #29 of 679 (permalink) Old 07-08-2019, 09:56 AM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
Quote: Originally Posted by finalheaven View Post
Seems Ryzen is at the mercy of the OS scheduler again. Maybe that is a selling point for 3950X over 3900X
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #30 of 679 (permalink) Old 07-08-2019, 10:08 AM
Always Learning
That is what I'm thinking as well. Apps/Games that utilize one ccx can be much more quicker. 3 cores/6 threads can be a limiting factor for those optimizing for 4 cores/8 threads in one ccx.
3950X looks much more enticing now. Or settle for a 3700X/3800X. All this assuming that windows and/or developers get better with scheduling.
Closed Thread
