Strictly technical: Matisse (Not really) - Page 55 - Overclock.net - An Overclocking Community
post #541 of 679 (permalink) Old 08-10-2019, 12:33 AM
mongoled's Avatar
Rep: 25 (Unique: 20)
Quote: Originally Posted by lordzed83 View Post
You hears about new EXPERT waterblocks that 8pack is working on ??? Without cold plate just Direct mounted to IHS with 2 seal. So You loose TIM and COLDPLATE. Very interesting
Will look at the video below when I get a chance, but wanted to say, that this has/had been done before several years ago.
The issue then was that the PCB substrate of the CPU ended up absorbing moisture from the direct die cooling, so unless they have changed the substrate so that it does not absorb water im unsure how this is going to work....
SeaSonic X750 Gold 750W
MSI X370 XPOWER Gaming Titanium | Ryzen 5 3600 2010SUS @ 4400 mhz @ 1.325v (prime95 load)
Viper Steel Series PVS416G413C9K @ 3800/1900 mhz | 1.52v | 14-15-14-14-28-42-252-16-1T
Asus GTX 780 DCII OC @ 1332/3522 mhz | 1.3v | Samsung 960 EVO 500GB
EK-FB MSI X370 XPower RGB Monoblock 1/2" ID | Swiftech D5 MCP655 | EK-XRES 100
Alphacool NexXxoS UT60 280 | 4 x Scythe GT AP-15 @ 5v
Thermochill PA120.3 | 1 x NF-A12x15 | 2 x ML120 | PWM
mongoled is offline
post #542 of 679 (permalink) Old 08-10-2019, 02:47 AM
drmrlordx's Avatar
Rep: 75 (Unique: 52)
Hmmm looks interesting. Too bad I used LM on my CPU IHS. Getting that stuff off is not easy (without lapping, ugh already killed one 3900x doing that). Letting old LM deposits work their way into my loop would not be a good idea. Otherwise I like the concept.
The proposed product would seal onto the IHS. Water should never touch the PCB unless the seals aren't on there correctly. Or at least, that seems to be what's in the works.
I will say though, that multi-wall nanotubes have thermal conductivity in excess of 2000 W/mK:
https://www.sciencedirect.com/scienc...90072912000932
Using materials like that opens up a lot of possibilities. Eventually we're going to need stuff like that when we hit Zen4 on 5nm or . . . whatever.
Watch this space for future . . . uh . . . stuff! Yeah. That.
drmrlordx is offline
post #543 of 679 (permalink) Old 08-11-2019, 02:53 PM
Noctua Fanboy
polkfan's Avatar
Rep: 16 (Unique: 13)
Quote: Originally Posted by The Stilt View Post
It has been reported over three weeks ago.
Read all of the 55 pages here at this site and i guess 1 month later this issue is still happening as i never seen 4.4ghz on my 3700X yet
I would love to know the technical reason why this is happening a user said that AGESA 1.0.0.1 was boosting correctly but ever since then it hasn't
polkfan is offline
post #544 of 679 (permalink) Old 08-11-2019, 04:31 PM - Thread Starter
The Stilt's Avatar
Rep: 872 (Unique: 333)
AMD has made several changes to the SMU FW, which affects how the CPU boosts.
New temperature limits have been introduced and the existing ones have been adjusted, along with certain voltage related parameters.
So the behavior doesn't appear to be a bug.
The Stilt is offline
post #545 of 679 (permalink) Old 08-12-2019, 07:37 AM
Rep: 11 (Unique: 10)
I'm seeing much better boosting behavior on my 3800x. I've had five cores hit 4525.8 Mhz in one session. In the past usually only one or two cores would boost to this level.
With AGESA 1.0.0.3ABB, I'm also seeing longer sustained clocks at 4400 - 4450MHZ. I've had all 8 cores at or over 4450MHZ in one gaming session. Temps are also lower as CPU Package Power appears to be lower for Prime95 and other stress programs. I think they are matching current draw to high voltage better with this AGESA. In the gaming session mentioned above, average CPU Package Power watts was only 39 (peaks at 55-57), with voltage spikes of 1.5 on all 8 cores.
Always Searching for Perfection,
Bluesman
Last edited by Bluesman; 08-12-2019 at 07:46 AM. Reason: clocks were changed from 1525 to 4525;watts peaks added
Bluesman is offline
post #546 of 679 (permalink) Old 08-12-2019, 10:28 AM
Noctua Fanboy
polkfan's Avatar
Makes me wonder is their something wrong with my chip? I mean several cores jump to 4375mhz and they all boost to at least 4325mhz.
I tried stock too without PBO on. This is on a 360 rad so i wouldn't think temps would be a issue. I tried playing games that use only one core i even forced dolphin emulator to just use 1 core but 4375mhz is the max my CPU will go.
Granted when gaming its locked at 4250mhz anyways i mean we are talking 25mhz but still
Edit that picture is with PBO on x10 scaler and after 24 hours of my PC being on doing web browsing and gaming and watching movies
polkfan is offline
post #547 of 679 (permalink) Old 08-12-2019, 11:02 AM
Noctua Fanboy
polkfan's Avatar
I'm trying again with Auto OC at 200mhz and gonna see but last time i never got even 4375mhz doing that but i'm not sure i had PBO at 10X last time i tried i'll edit if i get lower frequency's again with auto OC on
polkfan is offline
post #548 of 679 (permalink) Old 08-12-2019, 11:14 AM
Just for fun, set your multiplier to 4x not 10x with the 200mhz setting. Also, if I recall you have set a thermal threshold of 85C; therefore, just for fun set your TDC to 83C. I am speculating that the voltage/current slope changes when you specify a TDC value lower, commensurate with you new low thermal threshold of 85C. I got much lower temps and higher clocks when I did this.
Good luck.
Bluesman
Bluesman is offline
post #549 of 679 (permalink) Old 08-12-2019, 11:41 AM - Thread Starter
The Stilt's Avatar
Setting the thermal limits below stock (95°C) make no difference, since the boost algorithm already uses lower limits.
The original limits for Ryzen 3000 SKUs were:
- 3600 = 4100MHz (80-95°C) / 4200MHz (< 80°C)
- 3600X = 4200MHz (80-95°C) / 4400MHz (< 80°C)
- 3700X = 4200MHz (80-95°C) / 4400MHz (< 80°C)
- 3800X = 4300MHz (80-95°C) / 4550MHz (< 80°C)
- 3900X = 4400MHz (80-95°C) / 4650MHz (< 80°C)
Since then, it appears that the HighTemperature limit has been reduced further to 75°C (from 80°C).
New SMUs also have introduced "MiddleTemperature" limit, but that gets disabled when PBO is enabled.
HWInfo is also able to display these limits (fused values).
post #550 of 679 (permalink) Old 08-12-2019, 11:49 AM
Noctua Fanboy
polkfan's Avatar
I give up lol simply put 101 for my APU-CPU bus speed now getting 4.4ghz with PBO on at X10 scaler i tried everything else that people where saying doesn't work. Not sure Amd will be seen in good light if they don't fix these issues their chips should be hitting max turbo with even their own cooler if not they shouldn't advertise it that way. I read others who had worse then me(as its not a big deal to me). iNeri is running a 102 bus speed and it seems fine but i'm gonna stick to 101.
polkfan is offline
Closed Thread
