Strictly technical: Matisse (Not really) - Page 57 - Overclock.net - An Overclocking Community
post #561 of 679 (permalink) Old 08-13-2019, 12:12 PM
Meddling user
gupsterg's Avatar
Rep: 786 (Unique: 360)
gupsterg is offline
post #562 of 679 (permalink) Old 08-13-2019, 12:43 PM - Thread Starter
The Stilt's Avatar
Rep: 873 (Unique: 334)
No idea.
Those (like anything else) has not been documented at any level.
The Stilt is offline
post #563 of 679 (permalink) Old 08-13-2019, 05:31 PM
BOINC Cruncher
Keith Myers's Avatar
Rep: 32 (Unique: 22)
@The Stilt , can you explain why Cpu Voltage in the BIOS is locked to 1.093V whenever you keep Cpu Voltage in Auto and simply change to a manual multiplier? And yet Cpu Voltage never changes when you change multiplier?? Why is that so different from any other ASUS BIOS I have used. Cpu voltage always used to scale in Auto with increasing requested clocks. I can set a manual multiplier from 36 to 43, yet the Cpu Voltage never changes.
For me to run my desired 41.5 multiplier, I have to put Cpu Voltage to Offset and add 0.1875V to that locked 1.093V to achieve my desired operating voltage or 1.27V for my normal workload. That sags down to around 1.24V under my load. If I don't add an offset, the cpu always tries to run at 1.093V and fails at 4150Mhz.
Never saw this behavior on the 1002 BIOS or any earlier.
Serenity
(16 items)
Numbskull
(17 items)
Ryzen 3950X
ASUS ROG Crosshair VII Hero
EVGA RTX 2080 Hybrid
G. Skill F4-3200D-16GTZ TridentZ DDR4
Crucial MX100
Samsung 970 EVO M.2
Corsair AX1200
Optimus Foundation AMD cpu block
XSPC RX 360 radiator/Optimus Water Cooling D5 pump/reservoir/6X Noctua NF-A12X25 fans
Thermaltake Level 20 XT
Operating System
Ubuntu 20.04 LTS
HP 27xw
Keyboard
Logitech G613 mechanical keyboard
Keyboard
Logitech G603 mouse
AMD 2920X Threadripper
Asrock X399 Fatality Pro Gaming
EVGA GeForce RTX 2070 Black Gaming
EVGA GTX 1080Ti FTW Hydro Copper
EVGA RTX 2080XC Hydro Copper
G. Skill F4-3200C14-16GTZ
Samsung M.2 960EVO
Crucial MX200
Optimus Water Cooling Threadripper 3 block
XSPC RX360 Radiator times two
Noctua NF-A12x25 fan times six
Thermaltake Core X5 Black E-ATX
Operating System
Ubuntu 18.04 LTS
AOC 2367F
Keith Myers is offline
post #564 of 679 (permalink) Old 08-13-2019, 06:02 PM - Thread Starter
The Stilt's Avatar
The voltage only increases automatically during manual OC, if the motherboard manufacturer has implemented an "auto-rule" (pre-defined behavior, e.g. if ratio >= 40.0x set vcore 1.300). Its ODMs own doing, not something what the CPU itself is doing.
If no auto-rule is present, the CPU should use P0 voltage (which can be seen in CBS PStates) during manual oc.
post #565 of 679 (permalink) Old 08-13-2019, 06:44 PM
BOINC Cruncher
I don't understand the comment
I don't understand what you mean that only doing a manual OC, the voltage changes. I AM doing a manual OC. I take the CPU Multiplier off Auto and input a manual multiplier for manual OC. The cpu voltage never changes.
Serenity
(16 items)
Numbskull
(17 items)
Ryzen 3950X
Crucial MX100
Samsung 970 EVO M.2
Corsair AX1200
Operating System
Ubuntu 20.04 LTS
HP 27xw
Keyboard
Keyboard
Logitech G603 mouse
Samsung M.2 960EVO
Crucial MX200
Operating System
Ubuntu 18.04 LTS
AOC 2367F
post #566 of 679 (permalink) Old 08-14-2019, 12:49 AM
eXteR's Avatar
Rep: 4 (Unique: 2)
Read the whole sentence...
eXteR is offline
post #567 of 679 (permalink) Old 08-14-2019, 02:47 AM
Meddling user
gupsterg's Avatar
No idea.
OK, cheers .
Quote: Originally Posted by crakej View Post
Interesting that SoC is 0.02v lower than what RM reports, and also that what RM shows as 'CPU Core' is actually showing something closer to VID, so when people are seeing high voltages, they're not that high on VCore - and the watts are so low when voltage is 'high' that they're not a problem.
In regard to SOC and most other voltages RM shows set value not actual effective.
On ComboPi-AM4 1.0.0.3AB only way to have idle voltage as ComboPi-AM4 1.0.0.2 is to enable Global C-State Control, regardless if CPU is stock or PBO OC.
ECO Mode: [Enabled] Global C-State Control: [Auto]
Spoiler!
ECO Mode: [Disabled] Global C-State Control: [Enabled]
Spoiler!
OS fully updated, using Chipset driver pack 1.07.07.0725, RM is current latest version.
Quote: Originally Posted by Bluesman View Post
I'm seeing much better boosting behavior on my 3800x. I've had five cores hit 4525.8 Mhz in one session. In the past usually only one or two cores would boost to this level.
With AGESA 1.0.0.3ABB, I'm also seeing longer sustained clocks at 4400 - 4450MHZ. I've had all 8 cores at or over 4450MHZ in one gaming session. Temps are also lower as CPU Package Power appears to be lower for Prime95 and other stress programs. I think they are matching current draw to high voltage better with this AGESA. In the gaming session mentioned above, average CPU Package Power watts was only 39 (peaks at 55-57), with voltage spikes of 1.5 on all 8 cores.
I felt I had a good CPU until I used UEFI with AGESA ComboPi-AM4 1.0.0.3AB. PBO+150MHz on every prior UEFI yield always nice ACB of 4.3GHz to 4.34GHz depending on room ambient. Same settings are pants on this UEFI, compare data in WMV within this ZIP.
AMD has made several changes to the SMU FW, which affects how the CPU boosts.
New temperature limits have been introduced and the existing ones have been adjusted, along with certain voltage related parameters.
So the behavior doesn't appear to be a bug.
Oh my, I do hope they bring back SMU FW with similarities of boost as AGESA 1.0.0.2.
I also find how strange it is that on ComboPi-AM4 1.0.0.3AB I have to set Global C-State Control as on even when CPU default to get like down volting as AGESA 1.0.0.2 where I left this setting on [Auto].
Seems a total fad of AGESA to me.
I see PState 0 ceiling VID as 1100mV on my R5 3600 when I check PState menu.
If I only change ratio to 36.25x CPU goes to 1.2V.
Spoiler!
gupsterg is offline
post #568 of 679 (permalink) Old 08-14-2019, 05:37 AM
Meddling user
gupsterg's Avatar
R5 3600 (Batch: BF 1922SUT)
ASUS ROG Crosshair VII Hero Wifi (UEFI 2602, AGESA ComboPi-AM4 1.0.0.3AB)
F4-3200C14Q-32GVK
CPU Stock
RAM/IF: 3800MHz/1900MHz
SOC: 1.093V VDDG: 1.025V CLDO_VDDP: 0.901V VDDP: 1.05V
VBOOT: 1.4V VDIMM: 1.4V VTTDDR: 0.7V
ProcODT: 34.3, RTT/CAD Bus drive strength/timings [Auto]
Changed only MR6VrefDQ Control in PMU Training menu.
1h, 2h, 10h, 24h, 36h, 48h, 56h all result in Q-Code: F9, 3x board would try to POST, each time it would fail, settings would reset and board would then POST.
Meddling with setting has not proved what is default. Meddling with setting clearly destroyed POST ability of profile.
*** edit ***
This info seems right for this setting IMO...
Name:	DDR4 SDRAM info 2.jpg
Source link.
Reading this line:-
The VrefDQ can be set using mode registers MR6 and it needs to be set correctly by the memory controller during the VrefDQ calibration phase.
Does not seem as if this can be a fixed value, as may change on training...
gupsterg is offline
post #569 of 679 (permalink) Old 08-14-2019, 07:22 AM
Yoizhik's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by Medusa666 View Post
My motherboard is an ASUS X370 CH6.
I have Vcore set to 1,25v in BIOS, and it also shows in BIOS during boot.
I don't understand why the VID values are 1,1v, while the Vcore value is still 1,25v?
I've the same issue mate, how did you fix this?
Goblin Slayer
(10 items)
Ryzen 7 3800x
Asus Crosshair VI Hero
Asus Strix 1080ti
Gskill F4-3600C15D-16GTZ
Samsung 850 Evo
ADATA XPG SX8200 Pro
Evga 850P2
Currently Stock cooler (Noctua NH-D15 ordered)
Phanteks Evolv X
Asus PG278Q
Yoizhik is offline
post #570 of 679 (permalink) Old 08-14-2019, 07:35 AM
BOINC Cruncher
I still don't understand. Are you saying that ASUS has set an "auto-rule" that never changes vcore now when cpu frequency changes? How would they ever expect the cpu to run without adequate voltage?
Serenity
(16 items)
Numbskull
(17 items)
Ryzen 3950X
Crucial MX100
Samsung 970 EVO M.2
Corsair AX1200
Operating System
Ubuntu 20.04 LTS
HP 27xw
Keyboard
Keyboard
Logitech G603 mouse
Samsung M.2 960EVO
Crucial MX200
Operating System
Ubuntu 18.04 LTS
AOC 2367F
Closed Thread
