Ryzen 3900x power cycle when running AVX workloads - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 07-11-2019, 01:44 PM - Thread Starter
Rep: 0
I have been posting about this on Reddit and have decided to move this saga to a full thread. Hopefully this will lead to a solution and everyone else having issues can see this.
I waited on launch day to get my 3900x and an x570 Taichi motherboards. I then configured my rig as follows;
3900x
X570 taichi
4x8gb G.skill Flare X 3200cl14(running bios stock NO xmp)
2080ti FE with EVGA hybrid kit
Corsair H115i RGB Pro
1tb 970 Evo NVME, top slot
Seasonic X 750w (only the 8 pin CPU, the 4 pin is OTW)
Ryzen master for temps
The computer booted fine and passed userbench and some other light workloads. But upon running Prime 95 or cinabench, the entire system would power cycle. I then tried different voltages and overclocks as well as plenty of different ram speeds and timings. Nothing would work.
First HW change: I then took my CPU cooler off and saw that the thermal paste(AS5), rather than spreading to the entire CPU, had stayed relatively in the middle. I wiped it off, and reapplied. I then updated bios from 1.1 to 1.4. This configuration passed cinabench but could not do any CPU overclocking as a power cycle was imminent on any OC. I started paying attention to the CPU temps and noticed upon running P95 (the only one at this point unable to run without power cycle) the temps would immediately hit 95 degrees, while the AIO temps would rise by 4 or 5 degrees to 33/34. This concerned me as it seems that the h115i had a contact issue.
Second HW change. I then swapped the h115i out for the stock cooler, and now the stock settings will "pass" prime 95. Taking a straight edge to the 115i reveals some wobble, or bowing in the cold plate. But with the stock cooler, the temps still hit 95 immediately, but the clock throttles down to 3.9 GHz. My idle temps are around 40c with this setup.
Few questions/ things to consider
1. With the RMA of the cooler I will be able to find out if that was an issue, but has anyone with a corsair AIO run into this? And with the offset chiplets, are there certain brands that are better as cooling potential is not "focused" in the center?
2. Jayz2cents released a video about the stock bios's overvolting, what should I try to get better temps/ stability? Also did anyone have my issues and this is what fixed it?
3. Could there be a variance large enough in the solder where it does not have proper contact with the lid?
4. Could this be symptoms to other issues?
I will post again when I can either get the RMA'd cooler or get a new one with temps/other data.
Garrett4 is offline
post #2 of 8 (permalink) Old 07-12-2019, 08:56 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1431 (Unique: 725)
Did you use the H115i on a system before the 3900X? Hard to imagine the cooler is faulty if temps were solid on the other system.
Yes, manually set voltage and properly set LLC. Auto voltage and LLC at stock on my 9900K gives my CPU ~1.35v when it needs less than 1.15v.
If you get your AIO back and you have the same issue then you know either the solder is bad on your CPU or that the H115i isn't cut out for an off-set die. If the latter I'd imagine Corsair would have had day one parts that worked better for it.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is online now
post #3 of 8 (permalink) Old 07-12-2019, 09:40 AM
BeeDeeEff's Avatar
Rep: 2 (Unique: 2)
Could try shimming over the ccx with a layer or two of silver or copper leaf. There's been a lot of talk about mounting pressure potentially not being high on the edge of the IHS.
AMD Ryzen 9 3950X
Gigabyte X570 AORUS MASTER
Radeon VII
G.SKILL TridentZ RGB F4-3200C14D-32GTZR
ADATA XPG SX8200 Pro M.2-2280
Corsair HX
Watercool ​HEATKILLER​® IV PRO (​AMD proces​sor) BLACK​ COPPER
Phanteks Glacier for Radeon VII
Hardware L​abs SR2 42​0mm Radiat​or
Thermaltake Core P5 ATX Mid Tower Case
Operating System
Windows 10 Pro
BeeDeeEff is offline
post #4 of 8 (permalink) Old 07-12-2019, 10:44 AM
⤷ αC
AlphaC's Avatar
Rep: 913 (Unique: 592)
You shouldn't be using Arctic Silver 5 if you can help it as it's electrically conductive. You're better off with Arctic MX-4 or a higher end paste such as Thermal Grizzly Kryonaut, Gelid GC extreme, Noctua NT-H2.
Anyway before RMA I would try to spread the paste out instead of using a pea in the middle. Likely your prior CPU made the Corsair cooler's surface changed.
The R9 3900X on AIOs is going to perform worse than R7 2700X did due to heat density per area and the CPU die placement.
P.S. new 1.60 BIOs is up https://www.asrock.com/mb/AMD/X570%20Taichi/#BIOS
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #5 of 8 (permalink) Old 07-14-2019, 06:56 AM
upgraditus's Avatar
Rep: 8 (Unique: 6)
I've seen a lot of reports now of high temps and a lot are using expensive AIO's, meanwhile I'm here with my "budget" HSF and while idle is high this seems normal for Ryzen 3000 (used to seeing 20-30°C with 7700K); load temps are good. I didn't check my IHS for flatness but it's not uncommon for them to have high points toward the corners. The contact plate for mine and similar thermalrght coolers are ever so slightly convex which helps get around this somewhat. AIO coldpates are typically machined flat with the microfinned section centrally positioned.
= Ryzen 7 3700X 4.3GHz @ 1.3v / Thermalright TS140 BW / Prime X470-Pro / 16GB Crucial BSLT 3733 MT/s cl16 / 1080Ti Amp Extreme 2GHz @ 0.987v / Aerocool Project7 P650 / Fractal Define XL =
upgraditus is offline
post #6 of 8 (permalink) Old 07-19-2019, 05:30 PM - Thread Starter
Rep: 0
Well I seem to have figured it out, it 100% was an overheat shutdown. I took out my CPU cooler, rigorously cleaned it, applied some thermal grizzly and now my prime95 temps are sitting around 85 tops.
Garrett4 is offline
post #7 of 8 (permalink) Old 07-19-2019, 05:38 PM
Martin778's Avatar
Rep: 17 (Unique: 17)
Prime95 SmallFFT and with AVX/AVX2 enabled throttles the 3900X hard, I'm seeing drops to 3800MHz and 80*C Tdie. When I run Aida64 FPU the clock remains at 4025-4125 but the temps jump to 91 occassionaly.
Threadripper 3960X @ broken PBO EDC=40 | Aorus TRX40 Xtreme | Enermax Liqtech II 360 TR4 + EK Clear flush + 3x Noctua A12x25 | 4x8GB G.Skill TridentZ Neo 3800C14 @ 3733 CL14-15-15-30 CR1 | EVGA Kingpin 2080Ti @ 2115MHz / 8250MHz + Noctua A12-25 | 4x1TB 970 PRO raid0 | Corsair MP600 2TB | Seasonic Prime Platinum 1300W | In Win D-Frame 2.0 Gold | ASUS PG349Q
Martin778 is offline
post #8 of 8 (permalink) Old 07-20-2019, 06:32 AM
upgraditus's Avatar
Rep: 8 (Unique: 6)
Glad you got it sorted
