Ryzen 3000 Cinebench TEMPS - Page 2 - Overclock.net - An Overclocking Community
post #11 of 84 (permalink) Old 07-15-2019, 07:57 AM
kamil234's Avatar
Rep: 29 (Unique: 27)
@SsXxX how difficult is it to install the kraken on x570? I assume you just take off the 2 plastic braces around the CPU and put in the screws provided by nzxt, then mount the cooler?
That deserves the ROFL copter!
kamil234 is offline
post #12 of 84 (permalink) Old 07-15-2019, 08:14 AM
Overclocker & Enthusiast
ComansoRowlett's Avatar
Rep: 2 (Unique: 2)
CPU: 3900X @4.5GHz
Cooler: H150i
temps Idle: 35-40
Temps Cinebench: 81
Score: 3503
Single thread: 212
This is actually an overshoot for what voltage this CPU requires but I haven't bothered to lower it and do the proper testing yet so I'll just submit this. But this was at LLC 1 1.325v, it was almost stable at 1.306 after vdroop (1.325 with LLC2) which would give me a maximum temp of 72C. I should think around 1.312v it should stabilize again.
Ryzen 9 3900X
MSI X570 ACE
2080Ti FE (Buildzoid edition + waterblock)
G.skill Trident Royal 4800MHz CL18 (F4-4800C18D-16GTRS)
Samsung 860 EVO
Leadex Superflower 1000W platinum
Corsair H150i Pro
240mm + 240mm + 140mm MLC phoenix rads with pumps integrated into both.
Phanteks Enthoo Evolv
ASUS PG278QR
ASUS MG28U
Keyboard
Corsair K70
Mouse
Corsair Schimitar
Other
Samsung 970 pro 1TB
ComansoRowlett is offline
post #13 of 84 (permalink) Old 07-15-2019, 04:51 PM
kamil234's Avatar
Update:
Installed a AIO, kept everything else same from my previous post - normal voltage, -.102 offset, overclocked RAM to 3600CL14, everything else auto/normal
Score Single core score improved to 202 (from 197).
Temps improved from 80-85C to 65-70C.
Idle temps improved from 50C to 37-40C
As a added bonus, my CPU now downclocks, downvolts, and boosts properly. (before it wouldnt downclock lower then 3.4-3.6ghz, and wouldnt downvolt past 1.4v). Also now it boosts to 4.5ghz, up from 4.25ghz
Cooler: 280mm EVGA CLC AIO
EDIT: Spoke too soon. It looks like the downvoltage/downclock is related to RAM OC
kamil234 is offline
post #14 of 84 (permalink) Old 07-15-2019, 05:13 PM
thomasck's Avatar
Rep: 7 (Unique: 7)
CPU: 3900X
Cooler: Custom Loop 3x360
temps Idle: 30-40C
Temps Cinebench: 68-73C
Score: 3158
PCDEBAIANO
(7 items)
Ryzen 3900X
Taichi X370
AMD Radeon VII
HyperX Predator 4000
3x360mm
Lian Li o11d
HANNspree HG324
thomasck is offline
post #15 of 84 (permalink) Old 07-15-2019, 06:01 PM
jhatfie's Avatar
Rep: 5 (Unique: 5)
Have not done a ton of messing around yet. PBO thus far seems to only give me 4.2Ghz all core with single core peaks around 4.45Ghz.
Ram: 4x8GB DDR4-3600 16-16-16-35 (might be able to get timings tighter, still testing)
Manual OC 43x100 @ 1.2v (1.19v after vdroop)
CPU: 3900X @4.3GHz
Cooler: EVGA CLC 280
temps Idle: 30-32C
Temps Cinebench: 63C
OCCT small data set (2 hour): max temp 74C
R20 Score: 7485
4.4Ghz I think I might be able to get stable, but requires a good chunk more voltage
jhatfie is offline
post #16 of 84 (permalink) Old 07-16-2019, 05:31 AM - Thread Starter
SsXxX's Avatar
Rep: 11 (Unique: 10)
Quote: Originally Posted by kamil234 View Post
Here;s my results with a few benches from Ryzen 3900x, Aorus Elite motherboard, 3200cL14 b die ram (tuned to 3600c14)
CPU-Z showing the memory speeds:
CPU @ 'normal' voltage preset, offset -.102v
EDIT: ran another one with PBO enabled in BIOS instead of AUTO, the results are identical.
Temps: idle: 45-55c
Load: ~80C (stock cooler)
Probably gonna buy a AIO as the stock cooler is loud AF
your temps are great for a stock cooler! i get to 80's in some avx loads and thats with a 360mm AIO (kraken x72)
can you tell me your all core clocks and voltages during cinebench run?
Gaming is a Passion . . . Overclocking is an Art . . . I'm a Passionate Artist.
Fusion
(20 items)
5930k @ 4.4GHz v1.282
Rampage V Extreme
Gigabyte GTX 1080TI Aorus Xtreme
Corsair Dominator Platinum DDR4 2800MHz C16 v1.20
Intel Solid-State Drive 750 Series 1.2TB
Intel Solid-State Drive 750 Series 400GB
Corsair AX1500i
NZXT Kraken X62
Corsair Obsidian 650D
Operating System
Windows 10
Samsung Plasma TV PS60F5000 60inch
Keyboard
Corsair K95 Platinum RGB
Mouse
Corsair M65 RGB
Mouse
Corsair MM800 RGB Polaris
Audio
Asus Strix RAID DLX
Audio
Edifier S730 2.1
Other
Xbox One Elite Controller
Other
Steam Controller
Other
Thrustmaster T500RS
Other
Thrustmaster TH8RS
SsXxX is offline
post #17 of 84 (permalink) Old 07-16-2019, 05:59 AM - Thread Starter
SsXxX's Avatar
its just as easy and straight forward as any other platform, x570 is an am4 after all ...
and i highly recommend going for the best cooling possible within your budget/case ... pbo will thank you, with higher and more sustained clocks ofcourse
now back to subject, lets keep this going, post your results friends!
Fusion
(20 items)
Rampage V Extreme
Corsair AX1500i
NZXT Kraken X62
Operating System
Windows 10
Keyboard
Mouse
Corsair M65 RGB
Mouse
Audio
Asus Strix RAID DLX
Audio
Edifier S730 2.1
Other
Other
Steam Controller
Other
Thrustmaster T500RS
Other
Thrustmaster TH8RS
SsXxX is offline
post #18 of 84 (permalink) Old 07-16-2019, 06:05 AM
Reikoji's Avatar
Rep: 55 (Unique: 23)
Idle temp:
CPU 24C
CPU Package 27C
Max temp:
CPU 73C
CPU Package 80C
Cooling is Split EK Velocity block + WC VRM attatched to 3 560mm radiators.
Don't forget to ground yourself
https://valid.x86.fr/9ly8hi
Reikoji is offline
post #19 of 84 (permalink) Old 07-18-2019, 10:24 AM - Thread Starter
SsXxX's Avatar
Quote: Originally Posted by Reikoji View Post
Idle temp:
CPU 24C
CPU Package 27C
Max temp:
CPU 73C
CPU Package 80C
amazing single core score here! how did u get that? manual overclock or pbo?
Fusion
(20 items)
Rampage V Extreme
Corsair AX1500i
NZXT Kraken X62
Operating System
Windows 10
Keyboard
Mouse
Corsair M65 RGB
Mouse
Audio
Asus Strix RAID DLX
Audio
Edifier S730 2.1
Other
Other
Steam Controller
Other
Thrustmaster T500RS
Other
Thrustmaster TH8RS
SsXxX is offline
post #20 of 84 (permalink) Old 07-18-2019, 10:30 AM
Unoid's Avatar
Rep: 4 (Unique: 4)
3800X stock no PBO
Corsair H110i Extreme
Cinebench R20 average 4.2ghz all core 68C scores 5000
Unoid is offline
